4 Replies Latest reply on Jun 4, 2012 9:38 AM by GerrardLFC
    Import clips from Sony HXR-NX5E missing sound
    GerrardLFC
      Hi!
      Thanks to Adobe for bringing us Premiere, but in 2012 I feel that importing clips shouldn't be so annoyingly difficult.
      I have imported clips using "import" and "media browser. Both ways leave me with image but the audio is "not there", or sometimes very "crispy/digital". Same clips view in VLC player works fine, but the sound is not coming from my headphones. For some reason it's using the internal speaker, but it sounds OK. I use sony HXR-NX5E, Premiere CS 6 and I'm on win 7 64bit. Not sure what soundcard I'm using.
      Update: In prelude (never used it before) I can see soundwaves and hear the sound?!? It's low, but can be used. Now....what can I do to get it into Premiere and keep the sound intact?
      Thanks for any insights....
      G
        • 1. Re: Import clips from Sony HXR-NX5E missing sound
          vipul vaibhav Adobe Employee
          Hi gerrard
          In what format have you captured? HD or SD ? what's the video specs?
          • 2. Re: Import clips from Sony HXR-NX5E missing sound
            GerrardLFC Level 1
            Her is the info from MediaInfo. Ring any bells?:
            General
            Complete name                    : D:\PRIVATE\STREAM\00019.MTS
            Format                           : BDAV
            Format/Info                      : Blu-ray Video
            File size                        : 3.04 MiB
            Duration                         : 991ms
            Overall bit rate mode            : Variable
            Overall bit rate                 : 24.5 Mbps
            Maximum Overall bit rate         : 24.0 Mbps
            Video
            Menu ID                          : 1 (0x1)
            Format                           : AVC
            Format/Info                      : Advanced Video Codec
            Format profile                   : High@L4.0
            Format settings, CABAC           : Yes
            Format settings, ReFrames        : 2 frames
            Codec ID                         : 27
            Duration                         : 960ms
            Bit rate mode                    : Variable
            Maximum bit rate                 : 22.0 Mbps
            Width                            : 1 920 pixels
            Height                           : 1 080 pixels
            Display aspect ratio             : 16:9
            Frame rate                       : 25.000 fps
            Color space                      : YUV
            Chroma subsampling               : 4:2:0
            Bit depth                        : 8 bits
            Scan type                        : Progressive
            Audio
            Menu ID                          : 1 (0x1)
            Format                           : PCM
            Format settings, Endianness      : Big
            Format settings, Sign            : Signed
            Muxing mode                      : Blu-ray
            Codec ID                         : 128
            Duration                         : 1s 35ms
            Bit rate mode                    : Constant
            Bit rate                         : 1 536 Kbps
            Channel(s)                       : 2 channels
            Channel positions                : Front: L R
            Sampling rate                    : 48.0 KHz
            Bit depth                        : 16 bits
            Delay relative to video          : -80ms
            Stream size                      : 194 KiB (6%)
            • 3. Re: Import clips from Sony HXR-NX5E missing sound
              Jeff Bellune Level 5
              1. Did you copy the entire folder structure from the camera's memory card to your hard drive, or did you just copy the video files themselves?
              2. The duration of your sample clip is interesting -- is it correct?
              3. Are any of the clips long enough to be spanned -- are they stored across multiple files?
              4. The rest of your clip specs are similar to the specs of my NX5U video clips.
              Jeff
              • 4. Re: Import clips from Sony HXR-NX5E missing sound
                GerrardLFC Level 1
                Hi!
                Thanks Jeff for your help. I found out that upgrading from MasterCollection (Premiere) 5.5 to 6 made a difference regarding this problem. The files now import correctly. Under MC 5.0 and 5.5 they don't. Annoying!
                For others still struggeling with 5.5 and the same problems I have no solution, but in reply to Jeff:
                1 Tried both:
                a) Copy all folders and files from the card
                b) Imported only the main mts file
                2 It's correct. Bad examplefile, but same problem on the other files with longer duration (check Media Info below from another file)
                3 No, but the camera have two card bays. All content was recorded on this one card. I can't believe something was recorded on the other card. That would be ackward and the files collected from one card work in Prelude (poor audio) and VLC as they are.
                4 So that rules out the media. Problem is the software/hardware/OS?
                General
                Complete name                    : D:\PRIVATE\STREAM\00026.MTS
                Format                           : BDAV
                File size                        : 109 MiB
                Duration                         : 38s 463ms
                Overall bit rate                 : 23.8 Mbps
                Video
                Menu ID                          : 1 (0x1)
                Format                           : AVC
                Codec ID                         : 27
                Duration                         : 38s 400ms
                Bit rate                         : 21.3 Mbps
                Color space                      : YUV
                Bit depth                        : 8 bits
                Bits/(Pixel*Frame)               : 0.412
                Stream size                      : 97.7 MiB (89%)
                Audio
                Menu ID                          : 1 (0x1)
                Format                           : PCM
                Codec ID                         : 128
                Duration                         : 38s 475ms
                Bit depth                        : 16 bits
                Stream size                      : 7.04 MiB (6%)
