12 Replies Latest reply on Jun 20, 2013 1:57 AM by Radar323
    InDesign CS6 + Justify Text Frame Option = crash
    thewtb@me.com
      I work at a newspaper, and we have upgraded the newsroom and layout computers to Adobe CS6. We've stumbled across an odd bug it seems when using InDesign CS6 with Text Frame Option set to Justify. The newsroom and layout computers are Windows-based - the layout computer is Windows 7 64-bit. Here's the scenario in which the crash happens:
      1) Text box is vertically justified in Text Frame Options
      2) A graphic/photo with a text wrap around it.
      If you move the text box or the photo, causing the text justifcation to change, InDesign will crash. This only seems to occur when the spacing between justified text lines increases too much.
      We attempted to cause the crash on another Win7 64-bit machine with CS6 using the same .INDD document (our pages are stored on a local Windows server), and it crashed again in exactly the same manner.
      Here's the interesting part: I use Mac OS X Lion with CS6. I opened the same .INDD file as before, and InDesign crashed just as it did on Windows 7.
      To rule out some form of corruption with that particular .INDD file, we created a new document with the same characteristics, and InDesign crashed again.
      Here is a screencap video of the issue occuring. You can see, toward the end, how the text spacing becomes too much and it just crashes.
      http://www.screenr.com/MyR8
      Here is the error report from Windows 7:
      Problem signature:
        Problem Event Name:          APPCRASH
        Application Name:          InDesign.exe
        Application Version:          8.0.0.370
        Application Timestamp:          4f72c3ee
        Fault Module Name:          TEXT.RPLN
        Fault Module Version:          8.0.0.370
        Fault Module Timestamp:          4f72c802
        Exception Code:          c0000005
        Exception Offset:          0029202c
        OS Version:          6.1.7601.2.1.0.256.48
        Locale ID:          1033
        Additional Information 1:          0a9e
        Additional Information 2:          0a9e372d3b4ad19135b953a78882e789
        Additional Information 3:          0a9e
        Additional Information 4:          0a9e372d3b4ad19135b953a78882e789
      Solution: Change Text Frame Options to "Top", not Justify.
      Is this a known bug in InDesign CS6?
