I created a form using LiveCycle, opened it in Adobe X Pro, and imported XLM data into it. The data was for 6 cases. After the import, my pdf was 6 pages long. There were 6 forms populated by the data from the 6 cases. This is what I expected and wanted. I saved the pdf and sent it to a coworker. When the recipient opened the pdf with Adobe Reader, there were 11 pages. The first 6 pages were the form with the data from the 6 cases in it. The remaining pages repeated the form over and over again without data. How do I get rid of the pages with the blank forms? I tried to delete them using Adobe X Pro, but couldn't. Why is this happening? I'm new to LiveCycle, Adobe X Pro, and creating interactive forms.
Thank you,
AnneLL
Views
Total Likes
you have activated the option "repeat ... for each data item" for a page or a subform where it isn't neccessary.
If you can share your form, post a link here so we can check it.
Views
Total Likes
Thank you very much for the help. On my subform I had the Repeat Subform for Each Data Item checked and the Min Count set to 1. When I unchecked the Min Count, most of the blank forms went away. Now, I only have one blank form at the end of the document. Is there a way to get rid of the last blank form? Online it says entering a zero in the Min Count field will eliminate the blank form, but when I put a zero in the field, I get a message indicating the field must be populated with a number. The zero is automatically removed when I save the document.
Views
Total Likes
