4 Replies Latest reply on May 27, 2012 1:11 PM by lilia@
    Help Spell-checking
    rik_1962
      I used to create multi-language books with the layers (Indesign CS5.5).
      Each layer contains the texts of a specific idiom.
      The problem is that when I use the Spell-checking, it acts on all the layers.
      I wish that the control involves only the active layer (i.e. German version).
      I'm not able to find a setting which permit me to select the Spell-checking only on the active layer.
      Pls. can someone help me.
      Sorry for my weak english.
      Riccardo
        • 1. Re: Help Spell-checking
          Manish-Sharma Employee Moderator
          You have multiple layers with different idiom.
          Use this !!!
          Hide all the layer except one , run the spell check , Ideally it will run the spell check on all the layer but because they are hidden you will not see it .
          Correct the text in that layer , hide it and unhide other layer and repeat the steps for all the layers one by one.
          The best I can think of without using any third party script or plugin as I dont know any.
          • 2. Re: Help Spell-checking
            rik_1962 Level 1
            Thank you for your suggestion, unfortunately I've already tried this strategy.
            I don't understand why but the spell check runs also on the hidden layers.
            In the previous version of Indesign I haven't this problem.
            The only complicated (and uncomfortable) solution that I found it is to duplicate the doc and cancel all the layers except one language. When I find an error in the cloned doc I have to correct in source file.
            In my opinion it's a bug of Indesign. In the spell check it'd be useful an option relating the layers.
            Thanks in any case.
            Riccardo
            • 3. Re: Help Spell-checking
              If ALL text on every of your layers have the SAME language assigned to them, it could be scripted:
              1. For every hidden layer, store its language.
              2. Set all of the text on that layer to [No Language]. That way, the spell checker will ignore it.
              3. Do your spell check.
              4. Restore the original languages on hidden layers.
              This method will ONLY work if all of the text is actually set to the same language (yeah I know, I said it at the start; but it's a crucial point!)
              • 4. Re: Help Spell-checking
                lilia@ Level 2
                Use dynamic spelling, it might be quicker considering the layers.
