11 Replies Latest reply on Oct 25, 2012 1:28 AM by Mihai_Tica
    Let customer Submit Web App item classification
    Ray Wundebar
      I know it's probably not a standart thing but can there be some workaround to let customers classify web app items that they submit. I'm aware of the ability to clasify in admin console for users.
        • 1. Re: Let customer Submit Web App item classification
          MikeHometchko
          If you want to do this for sorting purposes, you should just create lots of generic classifications and give them a dropdown list to select from.  In theory, creating your own classification is cool...but like communism, this idea sucks.  How would you go about managing a page that has 1million classification types?
          Although I may be wrong, I'd say the answer is NO anyway.  If you could dynamically populate classifications from webforms, there is still no inherent way to select these new classifications for a list view module parameter.
          You COULD do it manually with an input field called "Classification", once the webapp is submitted:
          1. Find the classification name
          2. Create a new classification
          3. Go to your list view page (or wherever you'd like all your webapps to show)
          4. Insert new webapp for only this new classification
          This would be viable if you had like 6 users, maybe 7.  But realistically this wont work for most cases.
          • 2. Re: Let customer Submit Web App item classification
            gregory_manoj2000
            <tr>
            <td><label for="CAT_Category">Category</label><br />
            <select name="CAT_Category" id="CAT_Category" class="cat_listbox">{module_categorylist}</select></td>
            </tr>
            Add this code to the webapp customer input form and check. You will get result.
            • 3. Re: Let customer Submit Web App item classification
              Enjin Powerhouse Level 1
              Hi Gregory
              I know we could do a test, but thought I'd ask you first
              That snippet of code renders the category list as a drop-down select box.  That implies one can only select a single category on the input form?  Could it be changed to a multi-select listbox, for example, and then assign the webapp item to multiple categories?
              Gavin
              • 4. Re: Let customer Submit Web App item classification
                gregory_manoj2000 Level 1
                Hi Gavin
                You can use this :
                <select name="CAT_Category" id="CAT_Category" class="cat_listbox" rows="4" multiple="multiple">
                </select>
                Gregory
                • 5. Re: Let customer Submit Web App item classification
                  Mihai_Tica Adobe Employee
                  Here is what you can use to select multiple categories for user submitted webapps:
                  <tr>
                       <td>
                            <select multiple="multiple" name="CAT_Category" id="CAT_Category" class="cat_listbox">{module_categorylist}</select>
                       </td>
                  </tr>
                  Message was edited by: LiamDilley - Just put the code in a code formating for you
                  • 6. Re: Let customer Submit Web App item classification
                    Thanks, yes, that's what I meant by can we change it to a multi-select   Just wanted to know if the prcocessing acepted that
                    Many thanks, very helpful!
                    • 7. Re: Let customer Submit Web App item classification
                      David Camerotto Level 1
                      Hi there, I have the same requirement for adding news items for a multi location company, however, when I add the code from above a new item is not created.
                      This is the code I am using.
                      <form name="catcustomcontentform79350" onsubmit="return checkWholeForm79350(this)" enctype="multipart/form-data" method="post" action="/CustomContentProcess.aspx?A=EditSave&amp;CCID=8210&amp;OID={module_oid}&amp;OTYP E={module_otype}">
                          <table class="webform" cellspacing="0" cellpadding="2" border="0">
                              <tbody>
                                  <tr>
                                      <td><label for="ItemName">Item Title</label>
                                      <input class="cat_textbox_small" type="text" name="ItemName" id="ItemName" maxlength="255" /> &bull;</td>
                                  </tr>
                                  <tr>
                                      <td><label for="Upload_Photo">Upload Photo</label>
                                      <input class="cat_textbox_small" type="file" name="{tag_image}" id="{tag_image}" /></td>
                                  </tr>
                                  <tr>
                                      <td><label for="ItemDescription">Item Description</label>
                                      <textarea name="ItemDescription" id="ItemDescription" cols="10" rows="4" class="cat_listbox"></textarea></td>
                                  </tr>
                                  <tr>
                                      <td><label for="CAT_Category">Location</label>
                                  </tr>
                                  <tr>
                                      <td><input class="cat_button" type="submit" value="Submit" id="catcustomcontentbutton" /></td>
                                  </tr>
                              </tbody>
                          </table>
                          <script type="text/javascript" src="/CatalystScripts/ValidationFunctions.js"></script>
                      //<![CDATA[
                      var submitcount79350 = 0;function checkWholeForm79350(theForm){var why = "";if (theForm.ItemName) why += isEmpty(theForm.ItemName.value, "Item Name");if (why != ""){alert(why);return false;}if(submitcount79350 == 0){submitcount79350++;theForm.submit();return false;}else{alert("Form submission is in progress.");return false;}}
                      </script>
                      </form>
                      • 8. Re: Let customer Submit Web App item classification
                        Thanks so much for all the feedback!  Most helpful
                        • 9. Re: Let customer Submit Web App item classification
                          Can you please let me know the URL I can see this form on? If you want you can send me a PM an dI will look into this.
                          • 10. Re: Let customer Submit Web App item classification
                            tinymill
                            Hi Gregory,
                            Do you know if there's any way to create a dropdown list of a few category lists? Using the code above works great, but it inserts all categories across entire site. We'd like the cull the site on a per-web app basis so narrow down the choices a user has when classifying in the edit view.
                            • 11. Re: Let customer Submit Web App item classification
                              Do it like so:
                              -put the module in the form like David Camerotto did above
                              -view the form in the front-end
                              -get the HTML code outputted by the form
                              -replace the {module_categorylist} in the back-end with the code you copied from the front-end
                              You can now remove the unneeded categories.
