1 Reply Latest reply on May 24, 2012 11:37 AM by flyingj481
    Adobe Connect Pro vs SCORM
      There were no results for What is the difference between Adobe Connect PRO and connectivity as SCORM within Presenter? Does it impact an LMS system in anyway if you select Adobe Connect Pro?
        • 1. Re: Adobe Connect Pro vs SCORM
          flyingj481 Adobe Community Professional (Moderator)
          Adobe Connect is, technically, an AICC compliant reporting server.
          However, when you enable reporting for Presenter (any of the settings), it outputs both the AICC reporting files and the SCORM reporting files. You can verify this by looking for files labled scorm in the output. Just be sure you select the appropriate SCORM settings when you are going to be placing the output on a server that is expecting it.
