4 Replies Latest reply on May 24, 2012 3:06 PM by mcallit82
    Command Line and Resource Manager
    mcallit82
      When using the command line to compile a Robohelp project, is there a way to update the shared resources within the project before generation?
      For example, say you have Project1 and it is using snippet1 in that project. However, snippet1 has been modified in the resource manager (just say, for argument's sake, that snippet1 is also used in Project2, and you modified the snippet there and synced it to the resource manager). When you do a regular command line compile, the snippet is not updated.
      Is there a way to sync the snippets and images from the resource manager in the project before doing the command line compile (other than opening the project and syncing manually)? After all, if I have to open the project, there's no reason to command line compile since I'm already there and can just compile it from the project.
      Thanks!
