8 Replies Latest reply on May 25, 2012 4:20 AM by Muppet Mark
    Script: print to PostScript
    Flavien.06 Level 1
      Hello
      I need help to complete a script.
      I must regularly convert. Have to. Ps
      I would like to make a batch on a folder.
      I tried recording an action script illustrator but always select the default print.
      I find this script on the forum
      But I still have the same problem it selects the default printer, how to force it to use the PostScript printer
      Thank you
      var docs = app.documents;
      var docCount = docs.length;
      // if there are opened documents, print them, otherwise ask for a folder to batch print
      if (docCount>0) {
          alert(docCount);
          printOpenDocs(docs);
      else {
      var folder = Folder.selectDialog("Select Source Folder..."); // select folder
      printFolder(folder);
      // Prints and closes each open document
      function printOpenDocs(docs) {
                  for (j=docCount-1; j>=0; j--) {
                      var jdoc = docs[j];
                      jdoc.print(options);
                      jdoc.close(SaveOptions.
      DONOTSAVECHANGES);
      function printFolder(folder) {
          if (folder==null) {
                  alert("Good Bye");
          else {
              var files = folder.getFiles ("*.ai"); // get files
              var fileCount = files.length; // count them
              if (fileCount>0) {
                  for (i=0; i<fileCount; i++) {
                      var idoc = app.open(files[i]);
                      idoc.print();
                      idoc.close();
              else {
                  alert("There are no Illustrator files in this folder.");
        • 1. Re: Script: print to PostScript
          Muppet Mark Level 5
          Have you tried creating a print preset in AI then passing it to print as options… This can also be done by script but print options are more complex…
          • 2. Re: Script: print to PostScript
            Flavien.06 Level 1
            Yes I created  print preset PostScript but I can not use them in a batch processing.
            • 3. Re: Script: print to PostScript
              Muppet Mark Level 5
              Your line of syntax…
              idoc.print();
              Contains no options as a parameter so it's just going to default…
              You can get the options just the once then pass on each print() in the loop?
              • 4. Re: Script: print to PostScript
                Larry G. Schneider Adobe Community Professional & MVP
                Sure you can. Here's a page from the JS Reference (as displayed from Jongware's OMV reference) which should give you a start
                • 5. Re: Script: print to PostScript
                  Flavien.06 Level 1
                  thank you,
                  but I don't know how to use the "jdoc.print" syntax  ?
                    var jdoc = docs[j];
                    jdoc.print(options:printerName.'PostScript');
                  • 6. Re: Script: print to PostScript
                    Muppet Mark Level 5
                    This should give you a decent enough start…
                    #target illustrator
                    printPostScript();
                    function printPostScript() {
                        app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
                        var docPath, docs, inFolder, opts, psPath;
                        jobOpts = new PrintJobOptions();
                        opts = new PrintOptions();
                        opts.printPreset = 'PostScript';
                        opts.jobOptions =  jobOpts;
                        if ( app.documents.length > 0 ) {
                        } else {
                           inFolder = Folder.selectDialog( 'Select Source Folder...' );
                            if ( inFolder != null ) {
                                docs = inFolder.getFiles( '*.ai' );
                        for ( i = docs.length-1; i >= 0; i-- ) {
                            if ( docs[i] instanceof File ) {
                                app.open( docs[i] );
                            } else {
                                app.activeDocument = docs[i];
                            docPath = decodeURI( app.activeDocument.fullName );
                            psPath = docPath.replace( /.ai$/, '.ps' );
                            jobOpts.file = File( psPath );
                            app.activeDocument.print( opts );
                            app.activeDocument.close( SaveOptions.DONOTSAVECHANGES );
                        app.userInteractionLevel = UserInteractionLevel.DISPLAYALERTS;
                    • 7. Re: Script: print to PostScript
                      Flavien.06 Level 1
                      Thank you it works perfectly
                      • 8. Re: Script: print to PostScript
                        Muppet Mark Level 5
                        As is… It presumes any open documents are saved and are of *.ai filetype too… But you can adjust to suit your needs…
