2 Replies Latest reply on May 24, 2012 6:02 AM by Steve Werner
    Eyedropper Tool CS6
    vividi Level 1
      Adding a new colour swatch using the eyedropper tool not working.
      Vividi
        • 1. Re: Eyedropper Tool CS6
          I wasn't actually aware that you COULD add a swatch using the eyedropper....
          Do you have some documentation that says you should be able to, or were you able to do so before?
          • 2. Re: Eyedropper Tool CS6
            Steve Werner Adobe Community Professional & MVP
            There are several ways to add a new swatch from something on the page but it doesn't work quite that way. If an object isn't selected, you can use the Eyedropper to sample its color. Then click the New Swatch button at the bottom of the Swatches panel to add a swatch.
            If you have the Color panel open, you can drag a swatch from the Fill or Stroke box (upper left) onto the Swatches panel. (Or you could choose Add to Swatches) from the Color panel menu.
