5 Replies Latest reply on May 30, 2012 12:36 AM by -hans-
    Image Name Caption CS5.5-Please Help
    Danny Noonan Level 1
      Hello,
      Does anyone have a script or know of an application that can apply the image caption over and image, on it's own layer. I've looked all over and all I can find is the new image caption function. Has anyone successfully script this? I need help and if anyone has done this or is willing to help, I would greatly appreciate it.
      Here's what I am trying to do:
      Go throught the document and put a caption containing the name of each image in the document
      Fill the caption text box with a color so it stands out
      Center the caption on the image so a person can clearly identify what image the name belongs to
      Put all captions on their own layer
      I'd appreciate any help or assistance with this.
      Thank you in advance!
      Danny
        • 1. Re: Image Name Caption CS5.5-Please Help
          absqua Level 4
          I used to use an old Applescript that I think does most of what you want. Here it is if you're on a Mac: http://mac.softpedia.com/get/Utilities/ImageNameTag.shtml . It says it was written for CS2, but it may very well still work in CS5.5.
          Jeff
          • 2. Re: Image Name Caption CS5.5-Please Help
            Hi absqua,
            Do you happen to have the script? I can't download it from the link you provided. If you could post it so I can give a try, that would be awesome!
            Thank you,
            Danny
            • 3. Re: Image Name Caption CS5.5-Please Help
              absqua Level 4
              I PM'd you a Dropbox link.
              • 4. Re: Image Name Caption CS5.5-Please Help
                Thanks absqua,
                This is helpful but I was looking for somthing we could add to an existing script, meaning I was hoping I it wouldn't have any of the boxes pop up with the options. This was helpful though! Thanks for your assistance!
                Danny
                • 5. Re: Image Name Caption CS5.5-Please Help
                  -hans- Level 4
                  set the appearence of the caption by setting properties of the named objectstyle ....
                  --Tested: ID CS 5.5; OSX 10.7.4
                  property myObjectStyleName : "myCaption" --Name of Object Style for the caption. You can set the properties whenever you want ... Appearance is set here
                  property layerName : "captionLayerTest" --Name of the layer of the captions
                  tell application "Adobe InDesign CS5.5"
                      tell active document
                          set saveViewPreferences to properties of view preferences
                          set properties of view preferences to {vertical measurement units:millimeters, horizontal measurement units:millimeters}
                          if exists object style myObjectStyleName then
                              set myObjectStyle to object style myObjectStyleName
                          else
                              set myObjectStyle to make object style with properties {name:myObjectStyleName}
                          end if
                          if exists layer layerName then
                              set destLayer to layer layerName
                          else
                              set active layer to layer 1 whose index is 1
                              set destLayer to make layer with properties {name:layerName}
                          end if
                          set theLinks to every link
                          repeat with i from 1 to count of theLinks
                              set theLink to item i of theLinks
                              set {thePage, {y1, x1, y2, x2}, theName} to {parent page of parent of parent, geometric bounds of parent of parent, name} of theLink
                              set tfBounds to {(y1 + (y2 - y1) / 2) - 5, x1, (y1 + (y2 - y1) / 2) + 5, x2}
                              set tf to make text frame at thePage with properties {geometric bounds:tfBounds, applied object style:myObjectStyle, layer:destLayer}
                              set contents of tf to theName
                          end repeat
                          set properties of view preferences to saveViewPreferences
                      end tell
                  end tell
                  Hope it'll work
                  Have a nice day
                  Hans-Gerd Claßen
