2 Replies Latest reply on May 24, 2012 12:39 PM by ShutterDug
    APE-10 Video does not play in WMP
    ShutterDug
      I created a video in HD 720p/30 MPEG-2 format, but it will not play in Windows Media Player 11 or Windows Media Center.
      WMP reports: 'This video will not open. It may have been created with a codec that is not supported by WMP. Contact codec provider'. So here I am.
      Video/audio plays fine in DivX player.
      I created the same video in MPEG-2 Std DVD, and it played fine, just not the quality I wanted.
      Are there codecs for this format available for WMP that are not included in APE-10, or Windows 7 Ultimate? If so how do I get and install them so the video will play in WMP.
      Doug
        • 1. Re: APE-10 Video does not play in WMP
          That leads me to think that you somehow used divx inside that mpeg wrapper
          But, to be sure, analyze the file and report back
          For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
          • 2. Re: APE-10 Video does not play in WMP
            ShutterDug Level 1
            I do not use DivX for anything. It is just a player on my computer, I use when I can't open something in WMP. DivX usually opens anything.
            Here is the report file from Mediainfo on the file in question. Not sure what 'MPEG-PS' is but I do not see any reference to DivX.
            Can you tell anything from this?
            DN
            General
            Complete name                            : Y:\Videos\Jessie\Jessica- Le Danse (HD).mpg
            Format                                   : MPEG-PS
            File size                                : 2.71 GiB
            Duration                                 : 49mn 46s
            Overall bit rate mode                    : Variable
            Overall bit rate                         : 7 787 Kbps
            Video
            Format                                   : MPEG Video
            Commercial name                          : HDV 720p
            Format version                           : Version 2
            Format profile                           : Main@High 1440
            Format settings, BVOP                    : Yes
            Format settings, Matrix                  : Default
            Format settings, GOP                     : M=3, N=15
            Duration                                 : 49mn 46s
            Bit rate mode                            : Variable
            Bit rate                                 : 7 248 Kbps
            Maximum bit rate                         : 18.5 Mbps
            Width                                    : 1 280 pixels
            Height                                   : 720 pixels
            Display aspect ratio                     : 16:9
            Frame rate                               : 29.970 fps
            Standard                                 : NTSC
            Color space                              : YUV
            Chroma subsampling                       : 4:2:0
            Bit depth                                : 8 bits
            Scan type                                : Progressive
            Compression mode                         : Lossy
            Bits/(Pixel*Frame)                       : 0.262
            Stream size                              : 2.52 GiB (93%)
            Color primaries                          : BT.709
            Transfer characteristics                 : BT.709
            Matrix coefficients                      : BT.709
            Audio
            Format                                   : MPEG Audio
            Format version                           : Version 1
            Format profile                           : Layer 2
            Duration                                 : 49mn 46s
            Bit rate mode                            : Constant
            Bit rate                                 : 384 Kbps
            Channel(s)                               : 2 channels
            Sampling rate                            : 48.0 KHz
            Delay relative to video                  : 24ms
            Stream size                              : 137 MiB (5%)
