2 Replies Latest reply on May 25, 2012 7:27 AM by SeanJM1960
    Compostion settings question
    SeanJM1960 Level 1
      I am creating HD content that will be played on a display with a resolution of 1366 x 768, so do I create the comp at the 1080 setting or create a custom size of 1366 x 768?
      Sean
        • 1. Re: Compostion settings question
          And exactly how will it be played? That's all that matters. If it's bound to a specific playback device or format, then it will probably require moving with in the HD specs. If it only requires desktop playback from a PC in fullscreen mode via a standard media player software, then an arbitrary resolution should work just the same. Still, even then it's probably better to work in a standard full HD comp and only scale the output on encoding. You know, your client could change his mind and want this on a full HD screen, after all and then you'd be in all kinds of trouble having to redo it...
          Mylenium
          • 2. Re: Compostion settings question
            SeanJM1960 Level 1
            Thanks Mylenium,
            The content will be played on on 32" ad player in the mp4 format with the 1366 res. So the best idea would be create at 1080, like you said I only want to do it once.
            Sean
