1. Re: Applying Form Fields
BobLevine May 25, 2012 7:22 AM (in response to rsukhram@tgioa.com)What version of InDesign?
CS6 allows you to create PDF forms directly. For earlier versions, please visit the Acrobat forum for details about Acrobat’s form field recognition capability.
Bob
2. Re: Applying Form Fields
rsukhram@tgioa.com May 25, 2012 7:24 AM (in response to BobLevine)using cs6. I am trying to use the buttons and forms function but it does not seem to work for tabbed lines.
3. Re: Applying Form Fields
Steve Werner May 25, 2012 7:31 AM (in response to rsukhram@tgioa.com)Form fields are rectangular.
When you use the Form Field Recognition feature of Acrobat, it looks at the lines and turns them into rectangular form fields.
In InDesign, create rectangles, and then use the Buttons and Forms panel to turn them into form fields.
If you still want a line, put in the background, maybe on a separate layer.
4. Re: Applying Form Fields
rsukhram@tgioa.com May 25, 2012 7:32 AM (in response to Steve Werner)got it. thanks for the help. Also any idea why a checkbox, when exported to pdf, would not show up on the pdf?
5. Re: Applying Form Fields
Steve Werner May 25, 2012 8:12 AM (in response to rsukhram@tgioa.com)Just create a rectangle, select it and convert it to a Checkbox using the Buttons and Forms panel. Should definitely be a checkbox in Acrobat.
