2 Replies Latest reply on Mar 26, 2013 10:08 AM by KennethWebb
    Is it possible to script a tabbed ui?
    Damienned Level 1
      Is it possible to script a tabbed ui like this, i can't seem to get it to work, please help...
      Cheers Daniel.
      My script for now:
      #target illustrator
      tabbed_ui();
      //Functions
      function tabbed_ui(){
          res =
          "dialog {text:'Adres database:', properties:{resizeable:false }, \
              maintabpanel: TabbedPanel { text:'', \
                  subtab1panel: Tab { text:'Tab1', \
                  subtab2panel: Tab { text:'Tab2', \
          wininfo = new Window (res);
          wininfo.frameLocation = [100, 100];
          wininfo.margins = 0;
          // Control Escape key
          wininfo.addEventListener('keydown', function (k) {
              if (k.keyName == 'Escape') {
                  wininfo.close();
          wininfo.center();
          wininfo.show();
        • 1. Re: Is it possible to script a tabbed ui?
          moluapple Level 4
          Resource string not work here, but regular code will work.
          var w = new Window ("dialog", "Adres database:");
          var tpanel = w.add ("tabbedpanel");
          var subtab1panel = tpanel.add ("tab", undefined, "Tab1");
          var subtab2panel = tpanel.add ("tab", undefined, "Tab2");
          w.show();
          Since resource-based style is hard to debug, you'd better always use code-based style.
          • 2. Re: Is it possible to script a tabbed ui?
            KennethWebb Level 1
            Resource strings do work with tabbed panels, you just have to call it out as a panel and set its "type:" to "tabbedpanel", and to create tabs you create new Panels as children and call out their "type:" as "tab".
            Link to thread that explains this.
            Res code that will work for you:
            res =
                    maintabpanel: Panel { type: 'tabbedpanel', \
                        subtab1panel: Panel { type: 'tab', text:'Tab1', \
                        subtab2panel: Panel { type: 'tab', text:'Tab2', \
