2 Replies Latest reply on May 28, 2012 11:45 AM by esdebon
    Is there a way to make the Tween class move XY?
    JBonavita
      I want to move an object across the screen. For the first 10 x pixels I want it to also move 10 y pixels. So if I was manually coding it I would do
      for (i = 0; i < 10; i++) {
           x + i;
           y +i
      Once it gets to the max x position I want it to reverse y.
      At the same time I would like to reduce the size of the object for the same by 1% while moving y and then reversing it back to the normal size at when the y is reversed.
      I think maybe the size can be done with the transition but I'm not sure.
      Thanks for any help.
      Joe.
        • 1. Re: Is there a way to make the Tween class move XY?
          JBonavita Level 1
          Can the tween class be used on the 3D properties?
          • 2. Re: Is there a way to make the Tween class move XY?
            esdebon Level 4
            Where object is the instance name of the object to move
            import fl.transitions.Tween;
            import fl.transitions.TweenEvent;
            var xTween:Tween;
            var yTween:Tween;
            var yScale:Tween;
            var XScale:Tween;
            var initX:Number;
            var initY:Number;
            var finishX:Number;
            var finishY:Number;
            var timeTweens:int = 5;
            var newScaleX:Number=0.3;
            var newScaleY:Number=0.3;
            xTween = new Tween(object,"x",Strong.easeOut,initX,finishX,timeTweens,true);
            yTween = new Tween(object,"y",Strong.easeOut,initY,finishY,timeTweens,true);
            xTween.addEventListener(TweenEvent.MOTION_FINISH, reverseY);
            function reverseY(e:TweenEvent):void{
                yTween = new Tween(object,"x",Strong.easeOut,finishY,initY,timeTweens,true);
                XScale = new Tween(object,"scaleX",Strong.easeOut,1,newScaleX,timeTweens,true);
                yScale = new Tween(object,"scaleY",Strong.easeOut,1,newScaleY,timeTweens,true);
