2 Replies Latest reply on Sep 27, 2012 10:40 AM by KookaStarr
    iTomic e-reader gives error message when trying to register DRM
    janiceandken@netzero.net
      iTomic e-reader model IEBR7C  AH Version:GH321  Adobe Reader Version: 9.1.28890   2010.  when sending my Adobe ID via WiFi at Starbucks in order to "Register DRM," I get a certificate syntax error, what does this mean, how can I fix this so we can at least read the pre-installed e-books? Any suggestions appreciated! Thank you. P.S. The manufacturer is nowhere to be found, and Walmart wants to replace or refund, I would like to just make it work, I imagine it's my error and a replacement wont help.
        • 1. Re: iTomic e-reader gives error message when trying to register DRM
          Level 4
          There are a couple of things you talk about here.  One is the Adobe
          software and one is the ereader.
          For the software, don't confuse Adobe Reader with Adobe Digital Editions.
          They're very separate products, and Reader does not work with ebooks in
          Digital Editions format.  So, are you talking about Reader or Digital
          Editions?  Your ereader and its instructions should tell you which one.
          Also, when you talk about 'registering DRM', that's not what happens.
          'DRM' stands for Digital Rights Management, and it's not software.  It's
          the way that a publisher, distributor or library restrict the use of an
          ebook - and you don't register for it because it's a set of attributes
          built into ebooks themselves, not Reader or Digital Editions.
          Next, the ereader that you mention is not supported by Digital Editions, so
          even if you get it registered, it's very likely that you won't be able to
          interact with Digital Editions.  THIS
          LINK<http://blogs.adobe.com/digitalpublishing/supported-devices> will
          take you to the Adobe Digital Editions webpage that lists those ereaders
          and other devices that are supported.  Many off-brand manufacturers promise
          that their ereader will work with Adobe software, but in the real world,
          they don't.
          Getting to the preloaded ebooks on your ereader should not involve
          registering with Adobe, but it probably does involve registering with the
          manufacturer's website.  You may be able to do that from the ereader
          wirelessly, but you'll have to go to THEIR website, not to Adobe's.  Check
          the 'user's guide' that came with your ereader for directions.
          Hope this helps!
          On Mon, May 28, 2012 at 11:05 AM, janiceandken@netzero.net <forums@adobe.com
          • 2. Re: iTomic e-reader gives error message when trying to register DRM
            KookaStarr
            I am having the same problem with my daughter's new iTomic E reader, can't register DRM which means can't read any of the books she wants to download. All the manual says is to go register for an adobe digital edition account then use that id and password as your DRM register. What I really don't get is that it really does work for some people even though its not on Adobes list! And of course the company is out of business so you can't get any help at all!
