2 Replies Latest reply on May 29, 2012 6:44 AM by dcd018
    Flash Pro CS6 - Exporting Sprite Sheet With EaselJS JSON Data
    dcd018
      I've imported a png sequence into Flash Pro and have been trying to get the new sprite sheet generation feature to export JSON data in EaselJS format, but when I choose the EaselJS option from the dropdown menu, I only get a window function:
      (function(window) {
      }(window));
      However, when I export as JSON, I do get proper JSON data.  Is this a known issue with EaselJS support in CS6, or should I be doing something differently?  I'd rather not use Zoe, the SWF to EaselJS AIR utility, because the pngs are fairly large and Zoe seems to have a maximum dimention cap for exporting sprite sheets, I get 12 of them whereas Flash Pro is able to auto detect dimentions, exporting one sprite sheet, which is great, I just need to get it to generate the EaselJS data along with it.  Thanks in advance!
