3 Replies Latest reply on May 30, 2012 9:20 PM by Velprakash
    Cut/paste text in a new TextFrame, and place it on the text original position
    Marcos Suárez Level 1
      With this script, the pagraphs with style "_DESTACADOS" are cut and paste in a new TextFrame, but place them in to first page. I need place it on the text original position...
      var myDocument = app.activeDocument;
      var myRegExp = ".+";
      app.findGrepPreferences = NothingEnum.nothing;
      app.changeGrepPreferences = NothingEnum.nothing;
      app.findGrepPreferences.appliedParagraphStyle = "_DESTACADOS";
      app.findGrepPreferences.findWhat = myRegExp;
      var myFoundItems = myDocument.findGrep(true);
      if(myFoundItems.length != 0){
            for(var myCounter = 0; myCounter < myFoundItems.length; myCounter ++){
                myFoundItem = myFoundItems[myCounter];
                myX1 = myFoundItem.characters.item(0).horizontalOffset;
                myY1 = myFoundItem.characters.item(0).baseline;
                myX2 = myX1 + 50;
                myY2 = myY1 + 50;
                  app.selection = myFoundItem;
                      app.cut();
                  myTextFrame = myDocument.textFrames.add();
                  myTextFrame.geometricBounds = [myY1, myX1, myY2, myX2];
                  app.selection = myTextFrame.insertionPoints[0];
                      app.paste(); // Pega el texto del caso encontrado
                  myTextFrame.applyObjectStyle(app.activeDocument.objectStyles.item("_Destacados"), true);
                  myTextFrame.fit(FitOptions.FRAME_TO_CONTENT);
      THANKS...
        • 1. Re: Cut/paste text in a new TextFrame, and place it on the text original position
          Velprakash Level 1
          Hi Marcos Suárez,
                       If you've xml for the indesign document, u can use the following.
          myElement.placeIntoInlineFrame(["8p","6p1"]);
          I hope this code is useful in ur script.
          #include "glue code.jsx"
          var doc = app.activeDocument;
          var myRuleSet = new Array ( new idd)
                    with(doc)
                              var elements = xmlElements;
                              __processRuleSet(elements.item(0), myRuleSet)
          function idd()
              var newstyle=doc.objectStyles.add("ObjectStyle1");
              newstyle.appliedParagraphStyle="Ap3";
              newstyle.strokeColor="None";
              newstyle.fillColor="None";
                    this.name = "idd"
                    this.xpath = "//title/p2"                    //set this xpath value to the xmltree element which u want to set into frame.
                    this.apply = function(myElement, myRuleProcessor)
                  var txt=myElement.placeIntoInlineFrame(["8p","6p1"]);
                  txt.fit(FitOptions.frameToContent);
                  txt.applyObjectStyle(newstyle, true);
            return true;
          This will create a textframe around the selected content which u want to do so...
          For more info, refer XMLElement.placeIntoInlineFrame() in Object Model Viewer....
          With Regards,
          Vel.
          • 3. Re: Cut/paste text in a new TextFrame, and place it on the text original position
            Velprakash Level 1
            I don't have CS4. I'm having CS5 only. In this it works fine yaar...
