3 Replies Latest reply on May 30, 2012 10:25 AM by sinious
    Flash Export to Quick Time - Ghosting
    MCC 004
      Hi all,
      I'm having a problem exporting from Flash CS5.5 to Quicktime.
      The Quick Time file shows a 'ghosting' effect on sections of the video (see attached screen stills). The SWF file is fine.
      Here's the technical side:
      File created in FLASH CS5.5 on a Mac.
      24fps
      It has an embedded FLV movie (frame rate 24fps)
      I've tried exporting with Compression type:
      None
      H.264
      MPEG-4 Video
      Animation
      I have re-imported the FLV file (original was .AVI - Converted in Adobe Media Encoder)
      I have re-encoded it through Adobe Media Encoder.
      The ghosting was originally only happening on the bits of embedded movie, but is now happening on the screen stills which are JPGs.
      I'm slowly loosing the will, so if anyone can help it would be much appreciated.
      Many thanks,
      Heidi
        • 1. Re: Flash Export to Quick Time - Ghosting
          sinious Most Valuable Participant
          Wow that device looks um............... ok let's get past that.
          Compression is your issue. Ghosting as you call it is leftover artifacts in compression. Compressions job is to figure out what changed and ONLY update that. With a low keyframe setting you'll see these artifacts all day.
          Tell us what your compression settings are exactly from color depth to bitrate to keyframe distance.
          • 2. Re: Flash Export to Quick Time - Ghosting
            MCC 004 Level 1
            Thanks for you help.
            This setting seems to work best, but still gives me the artifacts problem (just less so than the rest) in the 'Export to Movie' settings:
            Compression Type = H.264
            Frame rate = 24
            Keyframes = Auto
            Data rate = Auto
            Compression = High
            Encoding = Best Quality
            Filters = none
            Size = 1280 x 720
            Sound = None
            Internet Streaming  = Fast Start
            The original AVI file I received had Codec compression.
            I have managed to create a QuickTime mov with no artifacts... but that's with a Frame Rate of 12fps.
            I can't find Colour Depth info...
            Any help will be great.
            Many thanks,
            Heidi
            • 3. Re: Flash Export to Quick Time - Ghosting
              A simple way to figure out if there's a real issue is to have you export AVI or Quicktime uncompressed. It will make a HUGE video but there will be no artifacts. Then take that uncompressed video back into Adobe Media Encoder and use those same settings. Your artifacting should go away.
              One thing you should note is setting compression to high and using best quality is sort of polar opposites. Try your hand at setting those settings rather than full auto.
              If this video is going online then I'd probably use:
              Data rate: average[768kbit/s] max[1.0mbit/s]
              Keyframes: every 10 seconds
              If intended for local playback I'd use profile 5.1 and do something like:
              Data rate: average[2.0mbit/s] max[4.0mbit/s]
              Keyframes: every 2 seconds
              Internet Streaming = disabled
              What codec is the AVI in?
              Generally your first job is to remove unnecessary complexity from the formula. Converting assets to uncompressed does that. So adding that extra step of reconverting the AVI to uncompressed and then compressing that will almost always work perfectly fine.
