5 Replies Latest reply on May 29, 2012 4:11 PM by esdebon
    Passing variables to actionscript 2 using javascript
    Tony404 Level 1
      Hi
      I have been trying to pass variables to a flash player with out refreshing the page. While do my research I came I cross things like externalinterface and other.
      I found a javascript + actionscript code that passed ariables to flash without refreshing page:
      So I have flash 8 with actionscript 2.0.
      HTML:
      <SCRIPT LANGUAGE=JavaScript>
      function callJavascript(){
        var sendText = inputValue.vars.value
        window.document.myMovie.SetVariable("testValue", sendText);
      </SCRIPT>
      <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,0,0" width="550" height="100" id="myMovie" align="middle">
      <param name="allowScriptAccess" value="sameDomain" />
      <param name="movie" value="setplay.swf" /><param name="quality" value="high" /><param name="bgcolor" value="#ffcc00" /><embed src="setplay.swf" quality="high" bgcolor="#ffcc00" width="550" height="100" name="myMovie" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" />
      </object>
      </body>
      <p>
      &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<input type=button value="Pass the variable to Flash" onClick="callJavascript()">
      <form name="inputValue">
      <a href="javascript:callJavascript()"> flash one</a><input type="hidden" name="vars" value="1.flv"/>
        </form>
      </html>
      I have a flash player with a movie player instance  name myVid:
      Actionscript:
      var testValue:String = "";
      watchCallback = function (id, oldval, newval):String {
      result_txt.text = newval;
      myVid.play(newval);
      return newval;
      _root.watch("testValue", watchCallback);
      The code gets the vars variable on the html page. Passes vars to actionscript using javascript, displays the text on result_txt and plays a flv video with similar name to passed variable.
      The problem is :
      I have multiple a href links which I would like to have different variables that they would pass to the flash player.
      <a href="javascript:callJavascript()"> flash one</a><input type="hidden" name="var1" value="1.flv"/>
      <a href="javascript:callJavascript()"> flash two</a><input type="hidden" name="var2" value="2.flv"/>
      <a href="javascript:callJavascript()"> flash three</a><input type="hidden" name="var3" value="3.flv"/>
      <a href="javascript:callJavascript()"> flash four</a><input type="hidden" name="var4" value="4.flv"/>
      How can I change the code so that if someone clicks flash one the value in var1 is passed to flash.
      and if flash two is clicked var2 is passed to flash.
      Thanks.
        • 1. Re: Passing variables to actionscript 2 using javascript
          esdebon Level 4
          this is not the complete example...
          You need a javascipt fuction for each value or use id to get the reference of the value
          • 2. Re: Passing variables to actionscript 2 using javascript
            Tony404 Level 1
            HI
            Thanks for the reply. So the javascipt function is now.
               var sendText1 = inputValue.vars1.value
               if(sendText!='')
               else if(sendtext1!='')
            </SCRIPT>
            This sucesfully recognises what variable to be passed to actionscript in a multiple variable situation.
            The problem now is how I can sucessfully flick from one ahref to another  .
            So lets say I click the first a href it calls the function the variable is passed and all works. If I then click the second the first video just stops and variable is still passed.
            Actionscript 2.0 is:
            myVid.play(newval);
            return newval;
            I would like for user to click first a href variable passing variable to player. If user clicks  second a href the a variable is passed replacing old variable the action script is above.
            Hope you can help thanks.
            • 3. Re: Passing variables to actionscript 2 using javascript
              esdebon Level 4
              you are calling the same value
              <SCRIPT>
              //more code
              //more code
              </SCRIPT>
              //more code
              //more code
              • 4. Re: Passing variables to actionscript 2 using javascript
                Tony404 Level 1
                Hi thanks again for replay
                so:
                Changes using the if statement with another variable. sendText1 is different variable.
                   if(sendText!='')
                   window.document.myMovie.SetVariable("testValue", sendText1);
                </SCRIPT>
                I would like to flip. rom 2 different video variables.
                Thanks.
