4 Replies Latest reply on May 30, 2012 9:49 PM by michael.shen
    how to create a marquee selection and  then write some texts inside
    michael.shen Level 1
      hi,guys.
      Does scripts can do the following things?
      1. create a marquee selection and  then write some texts inside
      2. align vertically center the text in the marquee selection
      Michael
        • 1. Re: how to create a marquee selection and  then write some texts inside
          Paul Riggott Level 6
          He is an example...
          var startRulerUnits = app.preferences.rulerUnits;
          app.preferences.rulerUnits = Units.PIXELS;
          var FontName = "Georgia";
          var FontSize = 14;
          var black = new SolidColor();
          black.rgb.hexValue = '000000';
          //create a new document  @ 72 PPI
          app.documents.add(600,400,72,"Justification Example");
          var SB = new Array();
          SB[0] = 20; //Left
          SB[1] = 20; //Top
          SB[2] = 300; //Right
          SB[3] = 200; //Bottom
          //make a selection
          activeDocument.selection.select([[SB[0],SB[1]], [SB[2],SB[1]], [SB[2],SB[3]], [SB[0], SB[3]]], SelectionType.REPLACE, 0, false);
          //Stroke selection so you can see the results
          activeDocument.selection.stroke (black, 1, StrokeLocation.INSIDE, ColorBlendMode.NORMAL, 100, false);
          //new text layer
          var newTextLayer = activeDocument.artLayers.add();
          newTextLayer.kind = LayerKind.TEXT;
          newTextLayer.textItem.kind = TextType.POINTTEXT
          newTextLayer.textItem.color = black;
          newTextLayer.textItem.font = FontName;
          newTextLayer.textItem.size = FontSize;
          newTextLayer.textItem.contents = "Centered Marquee Text";
          var X = SB[0] + 5;  //Five pixels to the right of the marquee selection
          var Y = ((SB[3]-SB[1])/2) + SB[0]; //Find the middle of the marquee selection and add the pixels top of selection to top of document.
          //Position text
          newTextLayer.textItem.position = Array(X, Y);
          //Convert the document to 300 PPI
          activeDocument.resizeImage(undefined, undefined, 300, ResampleMethod.NONE);
          app.preferences.rulerUnits = startRulerUnits;
          • 2. Re: how to create a marquee selection and  then write some texts inside
            This is another example to fit the text to the selection....
            It will create two documents...
            createExample("Example Text");
            createExample("Example Text and this fits too");
            function createExample(text){
            var FontSize = 4;
            SB[0] = 20; //Left
            SB[1] = 20; //Top
            //make a selection
            //new text layer
            newTextLayer.textItem.kind = TextType.POINTTEXT;
            newTextLayer.textItem.contents = text;
            var LB = activeDocument.activeLayer.bounds;
            //create text 6 pixels less than width of selection
            var selWidth = (SB[2]-SB[0]) - 6; //create text
            var LWidth = Math.abs(LB[2].value) - Math.abs(LB[0].value);
            var percentageWidth = ((selWidth/LWidth)* 100);
            activeDocument.activeLayer.resize(percentageWidth,percentageWidth,AnchorPosition.MIDDLECENTER);
            var X = SB[0] + 3;  //Three pixels to the right of the marquee selection
            var Y = ((SB[3]-SB[1])/2) + (SB[0]+ (LB[3]-LB[1])/2); //Find the middle of the marquee selection and add the pixels top of selection to top of document.
            //Position text
            • 3. Re: how to create a marquee selection and  then write some texts inside
              Thank you.
              It works greate.
              But if want to align vertically center the text in the selection,  the Y coordinate is incorrect. It seems impossible to get the correct coordinate.  Because textItem.position is the  orign for the text , Is it right?
              • 4. Re: how to create a marquee selection and  then write some texts inside
                Thanks i have solved .
                I moved two times to align vertically center.
                var LB = newTextLayer.bounds;
                var detaY = (SB[3]-LB[3].value-LB[1].value+SB[1])/2;
                newTextLayer.textItem.position = Array(X, Y+detaY);
