14 Replies Latest reply on Dec 4, 2012 1:25 PM by IAMTEEJAY
    Cannot put dwt file to remote /BC site
    EV WD Level 1
      Hey... I cannot put my dwt file to a BC site.
      I got to the point where my template.dwt was ready and I put the site to remote server. But the template does not go to remote: Templates:template.dwt - error occured.
      Any ideas? I also tried to create a new site straight in BC but the option to import a site of my own is not available:
      Import your current website in minutes and build it yourself from there (This option is currently not available)
      Then I went back to DW and decided to try and create a new template from scratch ( in case I missed something before)
      and then I noticed that there is a chekbox which is grayed out in all of the html templates.
      The link under goes to Adobe site where it just says that since 2010 InContext Editing will be discountinued as a standalone service…
      So… Is it possible to use my own template with BC? Does anyone know?
        • 1. Re: Cannot put dwt file to remote /BC site
          Liam Dilley Adobe Community Professional & MVP
          Hey there, Your usign CS6 or 5? If five and using the BC extension you need to mange your BC stuff through there. With CS6 you need to use the integrated features
          You can not "Put" any DWT files onto the BC system manually via FTP into the templates folder, it only handles .html files. If your using DW you use the BC stuff which converts .dwt files into the .html files it needs to work.
          • 2. Re: Cannot put dwt file to remote /BC site
            EV WD Level 1
            Hey,
            Thank you for your quick reply. I am using CS6.  So, BC does not support dwt files? Could you help me a little bit more and explaine what stuff converts .dwt files into .html files?
            I haven´t used BC before so I am lost here.
            • 3. Re: Cannot put dwt file to remote /BC site
              The BC part of Dreamweaver converts dwt files. The system itsefl does not.
              I use Coda2, I do not use DW6 so you will need to wait for someone who does to use it.
              • 4. Re: Cannot put dwt file to remote /BC site
                lazmattlabs Level 1
                I had this problem as well , My solution was when setting up your FTP setting in DW  in the username you have to put /dw after your username, thats what lets the .dwt file to be uploaded
                Cheers
                Laz
                • 5. Re: Cannot put dwt file to remote /BC site
                  studiomigo Level 1
                  I use CS6 and no PUT/ GET .dwt issues at all. there are a few login screens for some odd reason make sure you're logged-in to BC both FTP and the BC panel.
                  • 6. Re: Cannot put dwt file to remote /BC site
                    EV WD Level 1
                    Okay, there is something wrong with either CS6 or BC... When I go to my site settings /servers, I cannot see Save - Cancel - Help buttons at all until I hover on top of where they should be, then they appear.
                    Also, the server settings look empty, until I click to where they should be.
                    Anyway, changing my username doesn´t help, still error when trying to upload dwt file. Connection to server in Ok. All the other files goes to remote, just not the template file.
                    I am logged into both of them in DW, I can see the BC modules palette, and I can get to remote server from DW. Still: "Templates:template.dwt - error occured." No explanation.
                    • 7. Re: Cannot put dwt file to remote /BC site
                      Your not uploading files, you can not just put as a standard put to the server. Use the BC stuff to do that.
                      • 8. Re: Cannot put dwt file to remote /BC site
                        florincarlig.a Adobe Employee
                        Hi Elisa,
                        Can you please send me a private message and attach that .dwt file? Or open a new case and attach the template to the case so we can have a closer look.
                        Thanks and regards,
                        Florin Carlig
                        • 9. Re: Cannot put dwt file to remote /BC site
                          EV WD Level 1
                          Hi Florin,
                          I tried several different templates, none of them goes to remote, here is the code for one ( it is a ready template from DW that I named test.dwt):
                          <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                          <html xmlns="http://www.w3.org/1999/xhtml">
                          <head>
                          <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
                          <!-- TemplateBeginEditable name="doctitle" -->
                          <title>test</title>
                          <!-- TemplateEndEditable -->
                          <!-- TemplateBeginEditable name="head" -->
                          <link href="/oneColFixCtr.css" rel="stylesheet" type="text/css" />
                          </head>
                          <body>
                          <div class="container">
                            <div class="content"><!-- TemplateBeginEditable name="content" -->
                              <h1>Heading</h1>
                              <p>Paragraph</p>
                               <!-- TemplateEndEditable --><!-- end .content --></div>
                            <!-- end .container --></div>
                          </body>
                          </html>
                          I also tried different document types (html4 transitional, html5, xhtml) for the template, doesn´t help.
                          Then I used a different network as well, doesn´t help.
                          I also tried to change the file access properties for the folder Templates in remote server, but I cannot change them. (Don´t know if I even should). They are 755, same as images folder and all the images goes to remote.
                          • 10. Re: Cannot put dwt file to remote /BC site
                            EV WD Level 1
                            Okay, Now it when I try to put the test.dwt to remote, I get a longer message than before:
                            Templates:test.dwt - error occurred - An FTP error occurred - cannot put test.dwt.  Access denied.  The file may not exist, or there could be a permission problem.   Make sure you have proper authorization on the server and the server is properly configured.
                            And in the Ftp log it says:
                            The file "/Templates/Sivu.dwt" was skipped because the old remote file could not be deleted.
                            There is no old one on the server since I can´t put it.
                            • 11. Re: Cannot put dwt file to remote /BC site
                              Hi Elisa,
                              Looking at the code, the problem might be that you don't have the {tag_pagecontent} tag in the editable region that's inside the <body> tag. Business Catalyst requires a specific template structure: only one editable region in the <body> (besides the other 2 that Dreamweaver creates inside the <head> tag) and that region has to have the {tag_pagecontent} tag. You can see more details in this article that details how Business Catalyst and Dreamweaver work: http://www.businesscatalyst.com/support/dw#templates
                              Hope this helps.
                              Regards,
                              Florin Carlig
                              • 12. Re: Cannot put dwt file to remote /BC site
                                EV WD Level 1
                                Oh, I forgatten that from the test.dwt... I put it there, and still error.
                                Templates:test.dwt - Transferring
                                Here is a piece of the new code:
                                <body>
                                    {tag_pagecontent}
                                    <h1>Heading</h1>
                                    <p>Paragraph</p>
                                • 13. Re: Cannot put dwt file to remote /BC site
                                  EV WD Level 1
                                  Problem solved:
                                  I tried on a different computer that had OS 10.7.2 and Adobe CS6 and the templates went on remote server right away.
                                  And I was able to make pages based on that template in the browser in BC.
                                  My OS is 10.6.8 and also Adobe CS6.
                                  Thank you all for your help though.
                                  • 14. Re: Cannot put dwt file to remote /BC site
                                    IAMTEEJAY Level 2
                                    WOW. What an odd thing. Adding the DW worked for me too!
                                    My hero for the day, you are.
