1. Re: Rendering a movie as 2560x1440??
Dave LaRonde May 30, 2012 1:27 PM (in response to StreetwiseCreative)If the client has a RAID hooked up via Thunderbolt or something, it could work. If it's off the inter\nal hard drive, it's a crap shoot.
I suggest making a simple test movie at the resolution the client wants: perhaps a minute's worth of a white circle bouncing around on the screen, like in the venerable Pong game. If it takes you more than 5 minutes to whip it up, you've spent too much time on it.
It will also be a good test if AE will even allow you to render in H.264 at that resolution; it may not.
And H.264 doesn't do interlaced: only progressive.
2. Re: Rendering a movie as 2560x1440??
StreetwiseCreative May 30, 2012 1:32 PM (in response to Dave LaRonde)Thanks Dave! I'll whip up a test as you say. What codec do you recommend using?
3. Re: Rendering a movie as 2560x1440??
Dave LaRonde May 30, 2012 1:36 PM (in response to StreetwiseCreative)H.264: you might as well find out if it's going to work for you, which is another reason for the test, yes?
4. Re: Rendering a movie as 2560x1440??
Mylenium May 30, 2012 11:08 PM (in response to StreetwiseCreative)Use H.264 as Dave advised and set it to level 5.1 to be able to use that resolution. The rest is merely a matter of experimentation I would assume. If properly configured, any contemporary system should be able to handle this with a bit of graphics acceleration. The only potential issue I see here is the iMacs possibly heating up too much under the stress and then something might break down. Inherent in the design of the system with everything being crammed into so little space...
Mylenium
5. Re: Rendering a movie as 2560x1440??
bogiesan May 31, 2012 7:42 AM (in response to Dave LaRonde)Dave LaRonde wrote:
You can render any size comp out of AE but encoding/exporting is a different situation. Render your movies out of After Effects and then bring them into Apple's Compressor or Adobe Media Encoder or whatever encoder you have. Some codecs have specific and unalterable preset sizes.
Your client's ignorance about movie playback is going to be a problem. They may or may not have the capacity to learn anything.
