22 Replies Latest reply on Jun 1, 2012 5:53 AM by TᴀW
    Menu Actions: eventType question. JS
    TᴀW Adobe Community Professional & MVP
      (1) How would I add an eventListener for a given menu action that kicks
      in when the menu is dismissed?
      Eg
      myMenuAction.addListener("onInvoke", function(){alert("Hello");});
      adds a listener when it is invoked. But what would be the eventType for
      "dismiss"?
      (2) Where are the list of eventTypes documented?
      Ariel
        • 1. Re: Menu Actions: eventType question. JS
          John Hawkinson Level 5
          Menus don't get dismissed. They get invoked.
          Do you mean a panel or a dialog or a window?
          There's afterInvoke and of course you can queue an idle event handler and ON_IDLE.
          I guess that means my answer to your List of Eventtypes question is a bad one:
          >> Event.reflect.properties.sort().join("\n")
          AFTER_ACTIVATE
          AFTER_CLOSE
          AFTER_CONTEXT_CHANGED
          AFTER_DELETE
          AFTER_EMBED
          AFTER_INVOKE
          AFTER_LINKS_CHANGED
          AFTER_MOVE
          AFTER_NEW
          AFTER_OPEN
          AFTER_PLACE
          AFTER_QUIT
          AFTER_SELECTION_ATTRIBUTE_CHANGED
          AFTER_SELECTION_CHANGED
          AFTER_UNEMBED
          AFTER_UPDATE
          AT_TARGET
          BEFORE_CLOSE
          BEFORE_DEACTIVATE
          BEFORE_DELETE
          BEFORE_DISPLAY
          BEFORE_EMBED
          BEFORE_INVOKE
          BEFORE_MOVE
          BEFORE_PLACE
          BEFORE_QUIT
          BEFORE_UNEMBED
          BEFORE_UPDATE
          BUBBLING_PHASE
          CAPTURING_PHASE
          NOT_DISPATCHING
          ON_INVOKE
          __proto__
          arguments
          arity
          length
          name
          prototype
          prototype
          since it doesn't include many kinds of events. Like IdleEvent.ON_IDLE.
          So I guess you have to look at all the types that end in Event, like Event, IdleEvent, MutationEvent, etc., and enumerate them.
          Bah.
          • 2. Re: Menu Actions: eventType question. JS
            Thank you John, that's very helpful.
            Still, not managing to get anything to work except "onInvoke".
            For instance, thinking about the quick apply menu, I'd like to add a
            listener after it is closed/hidden/dismissed or whatever the term would be.
            But
            app.menuActions.itemByID(18771).addEventListener("AFTER_CLOSE",
            function(){alert("hello")});
            ...does nothing.
            Ariel
            • 3. Re: Menu Actions: eventType question. JS
              Again, that's because menus don't get dismissed.
              They merely get invoked.
              The Quick Apply panel is not a menu.
              I don't think there is anywhere you can attach an event for this.
              What is your actual goal?
              • 4. Re: Menu Actions: eventType question. JS
                Arïel, according to my vsn of the Object Model, not every object responds to the same message. AFTER_CLOSE, for example, only applies to Window, StoryWindow, LayoutWindow, Event, DocumentEvent and Application.
                (Huh--that last one ... So you can make a script do something after InDesign closed down.)
                For menuActions, it only lists BEFORE_INVOKE and AFTER_INVOKE.
                OT: Can anyone explain in simple terms what the "bubbleability" of events is all about?
                • 5. Re: Menu Actions: eventType question. JS
                  John,
                  My goal is simple. Quick Apply fails to provide a convenient way to
                  apply a paragraph style and then next style (and so on) in a case where
                  a user has selected multiple paragraphs.
                  My idea was do catch the QuickApply palette when it opens, store the
                  current paragraph styles applied to any selected paragraphs, and catch
                  it again when it closes. Then I would compare the current paragraph
                  styles with the stored values, and if they have changed (meaning that
                  the use has applied a paragraph style via Quick Apply) apply the
                  appropriate nextStyles.
                  So to do that I would need to create an eventListener when the palette
                  or panel or whatever it is is dismissed or closed.
                  Failing that, I have writte a QuickApply lookalike which applies next
                  style. I'll post it soon.
                  Ariel
                  • 6. Re: Menu Actions: eventType question. JS
                    Jongware,
                    If your browser provides that information, then I really must figure out
                    how to use it. The ESTK browser has nothing to say about event types.
                    What I understand about event propagation is probably no more than you.
                    I think that it begins with the fact that say you have a Window with a
                    button. If you click the button, then the button generates an onClick
                    event -- but after that, the Window does too (because in fact every
                    click on the button is a click on the Window as well). So that event
                    bubbles up from the button to the Window.
                    So if you have 2 event listeners -- one an onClick for the button, and
                    another an onClick for the window -- it could be that if the button is
                    clicked, you don't want the Window listener to be triggered as well --
                    so then you can stop the propagation of the event.
                    But the details: like which way it goes first (whether from the general
                    to the particular or from particular to general) and other things, I
                    don't know.
                    Ariel
                    • 7. Re: Menu Actions: eventType question. JS
                      Marijan Tompa [tomaxxi] Level 4
                      Ariel,
                      I think you should take a look at "AFTER_SELECTION_ATTRIBUTE_CHANGED" event.
                      This event detects all style changes to selected text/object.
                      Hope that helps.
                      Marijan (tomaxxi)
                      http://tomaxxi.com
                      • 8. Re: Menu Actions: eventType question. JS
                        Harbs. Level 6
                        Here's a 30 second crash course in events:
                        The basic concept to grock is the "box model".
                        Basically an app can be looked at as nested boxes -- boxes within boxes. In InDesign terms, the outermost box is the application, inside that is a document, inside that are layout windows. Inside that are all the objects.
                        UI Events generally have two phases. There's the capture phase and the bubbling phase.
                        When you click on something (for example), the click is "captured" from the outermost box inward. So it's first captured by the application, then the document, then the layout window, etc.
                        Once the click (or what-have-you) hit the target (i.e. a button or InDesign object), the event then bubbles back out. It starts at the innermost object and bubbles out to the outermost box (i.e. the application).
                        Theoretically, events can be attached to any box from the innermost one and outwards. If the event is recieved in the capture phase, the outer boxes will catch it first. If it's recieved in the bubbling phase, the inner boxes come first.
                        Let's say we have a "move" event on page items (which does not exist). We could theoretically add event listeners to the object itself (not possible because that level was never implemented), the page (also not possible), the window which holds the object, the document, or the application. If we attach listener to all the boxes, the innermost ones will be executed first. If bubbling can be canceled, the inner boxes can prevent the event from bubbling out to the outer boxes.
                        AFTER_CLOSE refers to windows or documents. The event can be attached to the app because it bubbles out to the app. Not that you can listen for an AFTER_CLOSE event for the app itself...
                        • 9. Re: Menu Actions: eventType question. JS
                          Thanks Harbs. So is there any intrinsic difference between the so-called
                          "capturing" phase and bubbling phase? Or is it just that capturing goes
                          down/into/from general to particular, and bubbling goes the other way?
                          • 10. Re: Menu Actions: eventType question. JS
                            Arïel wrote:
                            Jongware,
                            See http://jongware.mit.edu/idcs5.5js_html/idcs5.5js/pc_MenuAction.html -- events of these kind appear under a section of their own in the ESTK (actually, I couldn't say -- they do in its data file) as "class" properties.
                            The online version is good if you know in advance what you are looking for, but when in doubt I always use the CHM version, since you can use "search any text" -- with the provision that your CHM viewer software must support it. For your particular case I only had to check the index, though:
                            (This index is not from the OMV data; it's All Mine™, and I took my time thinking about what and how items should be included. Time well spent, so it appears!)
                            • 11. Re: Menu Actions: eventType question. JS
                              Downloaded the CS4 version i CHM but still can't find anything like the
                              list that John generated.
                              • 12. Re: Menu Actions: eventType question. JS
                                Harbs. Level 6
                                I believe events are generally cancelable in the capturing phase, but less so in the bubbling phase.
                                Harbs
                                • 13. Re: Menu Actions: eventType question. JS
                                  was it not clear how I generated my list? You do it interactively.
                                  • 14. Re: Menu Actions: eventType question. JS
                                    Yes, I know. But I though it was also in Jongware's reference.
                                    Ariel
                                    • 15. Re: Menu Actions: eventType question. JS
                                      absqua Level 4
                                      Using the Event Watcher extension linked in this thread will take some of the guesswork out of figuring out which events are actually implemented where and which events are firing. Totally essential in my opinion.
                                      Jeff
                                      • 16. Re: Menu Actions: eventType question. JS
                                        Marijan, thank you very much, I'll try it.
                                        Ariel
                                        • 17. Re: Menu Actions: eventType question. JS
                                          Marijan,
                                          What object would I attach that to? I'm trying:
                                          #targetengine "session"
                                          app.activeDocument.addEventListener("AFTER_SELECTION_ATTRIBUTE_CHANGED",
                                          but not getting any results.
                                          Ariel
                                          • 18. Re: Menu Actions: eventType question. JS
                                            You have to use it like this:
                                            app.activeDocument.addEventListener(Event.AFTER_SELECTION_ATTRIBUTE_CHANGED, function(){alert("hello")});
                                            or this:
                                            app.activeDocument.addEventListener("afterSelectionAttributeChanged", function(){alert("hello")});
                                            Hope that helps.
                                            Marijan (tomaxxi)
                                            • 19. Re: Menu Actions: eventType question. JS
                                              Thanks Marijan,
                                              The first method throws an error about expecting a string.
                                              The second is okay, but it doesn't work as I understand it should.
                                              that is, if I set an eventListener as per your example, and then select
                                              some text in a doc, and apply a different style, nothing happens!
                                              Ariel
                                              • 20. Re: Menu Actions: eventType question. JS
                                                Unfortunately, if you are using preCS5, it's not going to work.
                                                I didn't knew which version do you use.
                                                • 22. Re: Menu Actions: eventType question. JS
                                                  Jeff, thanks for the link. I think it's only for CS5+ though.
                                                  Anyway, here's my attempt at a simplified quick-apply clone that respects the Next Style settings:
                                                  http://www.freelancebookdesign.com/?page_id=461
                                                  If I could get evenListening to work (maybe when I upgrade), I'll try the more the sophisticated method detailed above....
                                                  Ariel
