10 Replies Latest reply on Jun 7, 2012 10:22 PM by Flex harUI
    limits of containers (maxHeight=10000)
    ne_polle
      Hi there,
      I'm trying to fill a box with a color.
      The size of the box is as a set it (20000px), but the colored area is clipped by the default maxheight of 10000px.
      How could I get a box completly filled up with the choosen color?
      <mx:Canvas id="container1" width="1000" height="500" backgroundColor="0x009999" >
                          <mx:Box id="box" width="100" height="20000" x="100" y="100" backgroundColor="0x00ff00" maxHeight="20000" />
      </mx:Canvas>
      thanks for any advice
      Julia
        • 1. Re: limits of containers (maxHeight=10000)
          Flex harUI Adobe Employee
          Change the maxHeight of the container.
          • 2. Re: limits of containers (maxHeight=10000)
            ne_polle Level 1
            Hi
            thanks for the answer.
            I changed the maxHeight of each container and nothing changed.
            When you copy paste the following code:
                                             xmlns:mx="library://ns.adobe.com/flex/mx"
                                             minWidth="955" minHeight="600"
                                             maxHeight="20000"
                      <mx:Canvas id="container1" x="200" y="300" width="1000" height="500" backgroundColor="0x009999"  maxHeight="20000">
                                <mx:Box id="box" width="100" height="20000" x="100" y="100" backgroundColor="0x00ff00" maxHeight="20000" minHeight="20000" />
              </mx:Canvas>
            </s:Application>
            and scroll down till the end of the Canvas you will see that the Box is'nt complitly filled with the choosen color.
            maybee another advice???
            • 3. Re: limits of containers (maxHeight=10000)
              It looks like the skin has background rectangles with the default maxHeight of 10000.  You will need to modify the skin for at least the Box.
              • 4. Re: limits of containers (maxHeight=10000)
                Sainath.B
                Thanks for the answer. I am even stuck with the same problem. Could solve this in Flex 4 using below lines of code
                <s:BorderContainer skinClass="skins.BorderContainerSkin" /> where BorderContainerSkin has
                <s:Group id="contentGroup" maxHeight="{Infinity}" maxWidth="{Infinity}"/>
                How do we do the same thing in Flex 3? How to write skin for the box in the code snippet given by ne_polle?
                Please help, I am using Flex 3.0
                Thanks in advance
                • 5. Re: limits of containers (maxHeight=10000)
                  Post the smallest test case that reproduces your problem.
                  • 6. Re: limits of containers (maxHeight=10000)
                    Sainath.B Level 1
                    Hello there,
                    Sorry should have been more clear : Please refer the code snippet that ne_polle posted above after changing Canvas's maxHeight to "20000". You said "You will need to modify the skin for at least the Box."  We could do this in Flex 4 and it works but how exactly do you mean to skin the Box in Flex 3??
                    Sorry but my Eng is poor.
                    Thanks in anticipation of a solution
                    • 7. Re: limits of containers (maxHeight=10000)
                      You said you are using Flex 3.  Please provide a small case that uses Flex 3.  The test case posted is using s:Application and is therefore tied to Flex 4.
                      • 8. Re: limits of containers (maxHeight=10000)
                        ne_polle Level 1
                        In my case I could solve my problem, by using the graphics drawing option.
                        I don't know if this is the best choice, but it works well.
                                                         maxHeight="20000" initialize="init()"
                          <fx:Script>
                                            <![CDATA[
                                                      private function init():void {
        box.clipContent = false;
        box.graphics.clear();
        box.graphics.beginFill(0x0000ff);
        box.graphics.drawRect(0,0, 100, 20000);
        box.graphics.endFill();
                          </fx:Script>
                                            <mx:Box id="box" width="100" height="20000" x="100" y="100>
                          </mx:Box>
                          </mx:Canvas>
                        </s:Application>
                        To the discussion of Flex harUI and Sainath.B:
                        I don't get eather the meanning of the advice to change something in the skin of the mx:Box.
                        How could I change the skin?
                        What do you mean with the keyword "skin" exactly?
                        • 9. Re: limits of containers (maxHeight=10000)
                          Sainath.B Level 1
                          Apologies for the mix up, I am using Flex 4 application but MX components only. Following is a sample code for your reference
                                               xmlns:mx="library://ns.adobe.com/flex/mx">
                                <mx:Canvas id="container1" width="1000" height="500" backgroundColor="0x009999"  maxHeight="20000" maxWidth="20000">
                                      <mx:Box id="box" width="20000" height="20000" backgroundColor="0x00ff00" maxHeight="20000" maxWidth="20000"/>
                                </mx:Canvas>
                          </s:Application>
                          The problem is we cannot change the MX components to Spark component. And we can't use the above solution provided by ne_polle in our case. Thanks ne_polle anyways for sharing the solution.
                          • 10. Re: limits of containers (maxHeight=10000)
                            If you are using the Spark theme, then you need to alter the skins as the internal pieces have maxHeights as well.
