7 Replies Latest reply on Jun 5, 2012 12:28 AM by manojb05
    Flame Effect
    manojb05 Level 1
      Dear all,
      I am make a flame but smoothness & running of flame is not correct,
      Please help this weblink
        • 1. Re: Flame Effect
          SuhasYogin Adobe Employee
          Hi Manoj,
          The link you posted didn't work. Could you please repost?
          Regards,
          Suhas Yogin
          • 2. Re: Flame Effect
            manojb05 Level 1
            hi suhas thanks for your reply please check updated link WEBLINK
            • 3. Re: Flame Effect
              Hi, Manoj
              We need you to share your FLA file with us, you can use any free file sharing website for the same.
              Regards,
              Suhas Yogin
              • 4. Re: Flame Effect
                manojb05 Level 1
                • 5. Re: Flame Effect
                  manojb05 Level 1
                  hi anybody know how can do?
                  plz help
                  • 6. Re: Flame Effect
                    Rothrock Level 5
                    I don't know if you are using AS2 or AS3. But here is an AS2 flame effect. Try it by itself first and see if you can figure out a way to use it.
                    Or you might like this tutorial here: http://www.powerabuse.co.uk/tutorials/particle_fire.html
                    Good luck
                    import flash.display.BitmapData;
                    import flash.filters.BlurFilter;
                    import flash.geom.*;
                    var flameWidth:Number = 800
                    var flameHeight:Number = 300;
                    var seedWidth:Number = 15;
                    var blurX:Number = 4;
                    var blurY:Number = 8;
                    var numSeeds:Number = 15;
                    var numPasses:Number = 2;
                    var blur:BlurFilter = new BlurFilter(blurX, blurY,2);
                    var bmp0:BitmapData = new BitmapData(flameWidth, flameHeight+blurY*2, false, 0x0);
                    var bmp1:BitmapData = new BitmapData(flameWidth, flameHeight, true, 0xffffffff);
                    this.createEmptyMovieClip("img",100);
                    this.attachBitmap(bmp0,200);
                    img.attachBitmap(bmp1,100);
                    img._y = Stage.height-flameHeight+(blurY >> 1);
                    img._x = (Stage.width-flameWidth)/2
                    var map:Array = new Array();
                    var nullArray:Array = new Array();
                    for (var i = 0; i<256; i++) {
                              map[i] = HSL2RGB(i/3, 255, Math.min(255, i*2));
                              nullArray[i] = 0;
                    onEnterFrame = function() {
                              for (var i = 0; i<numPasses; i++) {
                                        for (var j = 0; j<numSeeds; j++) {
                                                  bmp0.fillRect(new Rectangle(getRandInt(150,flameWidth-150), flameHeight+(blurY >> 1), seedWidth, 2),0xffffff);
                                        bmp0.applyFilter(bmp0,new Rectangle(0, 0, flameWidth, flameHeight+(blurY >> 1)),new Point(0, -3),blur);
                              bmp1.paletteMap(bmp0,new Rectangle(0, 0, flameWidth, flameHeight-(blurY >> 1)),new Point(0, 0),map,nullArray,nullArray,null);
                    function HSL2RGB(h:Number, sl:Number, l:Number) {
                              var r:Number;
                              var g:Number;
                              var b:Number;
                              h /= 255;
                              sl /= 255;
                              l /= 255;
                              var v:Number = (l<=0.5) ? (l*(1.0+sl)) : (l+sl-l*sl);
                              if (v<=0) {
                                        r = g=b=0;
                              } else {
                                        var m:Number = l+l-v;
                                        var sv:Number = (v-m)/v;
                                        h *= 6;
                                        var sextant:Number = Math.floor(h);
                                        var fract:Number = h-sextant;
                                        var vsf:Number = v*sv*fract;
                                        var mid1:Number = m+vsf;
                                        var mid2:Number = v-vsf;
                                        switch (sextant) {
                                                  case 0 :
                                                            r = v;
                                                            g = mid1;
                                                            b = m;
                                                            break;
                                                  case 1 :
                                                            r = mid2;
                                                            g = v;
                                                            b = m;
                                                            break;
                                                  case 2 :
                                                            r = m;
                                                            g = v;
                                                            b = mid1;
                                                            break;
                                                  case 3 :
                                                            r = m;
                                                            g = mid2;
                                                            b = v;
                                                            break;
                                                  case 4 :
                                                            r = mid1;
                                                            g = m;
                                                            b = v;
                                                            break;
                                                  case 5 :
                                                            r = v;
                                                            g = m;
                                                            b = mid2;
                                                            break;
                              return ( ((r*255) << 16) | ((g*255) << 8) | ((b*255)));
                    function getRandInt(min:Number, max:Number):Number {
                              var num:Number = Math.floor(Math.random()*(max-min+1))+min;
                              return num;
                    • 7. Re: Flame Effect
                      manojb05 Level 1
                      Rothrock, Awesome thanks for your valuable feedback. I am try to your tutorial its works fine.
                      I am that code incorporate in my creative
