19 Replies Latest reply: Dec 7, 2012 12:04 AM by GrizzlyAK RSS
    Cant open new install of Audition CS6 Constantly Crashing
    lasvideo CommunityMVP
      Process:     Adobe Audition CS6 [344]
      Path:        /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/MacOS/Adobe Audition CS6
      Identifier:  com.adobe.Audition.5.0
      Version:     5.0x708 (5.0)
      Code Type:   X86 (Native)
      Parent Process:  launchd [142]
      Date/Time:   2012-05-31 10:37:09.638 -0700
      OS Version:  Mac OS X 10.7.3 (11D50d)
      Report Version:  9
      Interval Since Last Report:      1297586 sec
      Crashes Since Last Report:       3
      Per-App Interval Since Last Report:  18 sec
      Per-App Crashes Since Last Report:   3
      Anonymous UUID:                  B058F01B-40B0-4B77-B0AF-086642178641
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Exception Type:  EXC_CRASH (SIGABRT)
      Exception Codes: 0x0000000000000000, 0x0000000000000000
      Application Specific Information:
      objc[344]: garbage collection is OFF
      terminate called throwing an exception
      abort() called
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   libsystem_kernel.dylib    0x9c4899c6 __pthread_kill + 10
      1   libsystem_c.dylib         0x9a2adf78 pthread_kill + 106
      2   libsystem_c.dylib         0x9a29ebdd abort + 167
      3   libc++abi.dylib           0x9afa5921 abort_message + 94
      4   libc++abi.dylib           0x9afa31bc default_terminate() + 36
      5   libc++abi.dylib           0x9afa31fe safe_handler_caller(void (*)()) + 15
      6   libc++abi.dylib           0x9afa3268 std::terminate() + 23
      7   libc++abi.dylib           0x9afa42a0 __cxa_throw + 112
      8   com.adobe.auui.framework  0x04e5e2b3 BIB_T_NMT::BIBThrowError(BIBError*) + 195
      9   com.adobe.auui.framework  0x04e83580 dvaui::drawbot::AGMTextDoc::GetLineBounds(int) const + 412
      10  com.adobe.auui.framework  0x04e69d01 dvaui::drawbot::AGMFontInterface::MeasureMultiLineStringHeight(unsigned short const*, float, int) const + 509
      11  com.adobe.dvaui.framework 0x00580a50 dvaui::controls::UI_StaticText::GetRecommendedSize_Helper(dvaui::drawbot::Drawbot*, boost::intrusive_ptr<dvaui::ui::Theme>, bool) const + 496
      12  com.adobe.dvaui.framework 0x00580d12 dvaui::controls::UI_StaticText::UI_GetRecommendedSize(dvaui::drawbot::Drawbot*) const + 60
      13  com.adobe.dvaui.framework 0x006af6c8 dvaui::ui::(anonymous namespace)::LayoutNode::operator()(boost::intrusive_ptr<dvaui::ui::UI_Node>) + 448
      14  com.adobe.dvaui.framework 0x006afdba dvaui::ui::AutoLayoutSubView(boost::intrusive_ptr<dvaui::ui::UI_SubView>, dvaui::drawbot::Drawbot*) + 986
      15  com.adobe.dvaui.framework 0x0068dae9 dvaui::ui::UI_SubViewAdapter::AutoLayout(dvaui::drawbot::Drawbot*, boost::intrusive_ptr<dvaui::ui::UI_Node>, boost::intrusive_ptr<dvaui::ui::UI_Node>) const + 47
      16  com.adobe.dvaui.framework 0x006b4ad8 dvaui::ui::UI_NodeArchive::CreateNode(boost::intrusive_ptr<dvaui::ui::UI_Node>, dvacore::proplist::PropList const&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) + 1984
      17  com.adobe.dvaui.framework 0x006b54e7 dvaui::ui::UI_NodeArchive::BuildFromPropList(dvacore::proplist::PropList const&, std::map<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*, std::less<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const>, std::allocator<std::pair<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*> > >&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) + 313
      18  com.adobe.dvaui.framework 0x006b5714 dvaui::ui::UI_NodeBuilder::Build(dvaui::drawbot::SupplierInterface const*, std::map<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*, std::less<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const>, std::allocator<std::pair<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*> > >&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) const + 148
      19  com.adobe.dvaui.framework 0x006520d8 dvaui::sharedui::DVAAboutDlog::ConstructCommon(dvaui::utility::ResourceManager const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::geom::PointT<float>, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>, bool) + 1238
      20  com.adobe.dvaui.framework 0x00652a6c dvaui::sharedui::DVAAboutDlog::DVAAboutDlog(dvaui::utility::ResourceManager const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::geom::PointT<float>, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>, bool) + 462
      21  com.adobe.auui.framework  0x047d4a69 aui::SplashScreen::SplashScreen(dvaworkspace::workspace::Workspace*, dvaui::utility::ResourceManager*) + 181
      22  com.adobe.auui.framework  0x047c0d2a aui::Application::GetNewSplashScreen() + 62
      23  com.adobe.exo.framework   0x01d2d5cb exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 687
      24  com.adobe.auui.framework  0x047c7131 aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 145
      25  com.adobe.auui.framework  0x047d5162 AudMacMain(int, char**) + 386
      26  com.adobe.Audition.5.0    0x00002e3f main + 159
      27  com.adobe.Audition.5.0    0x00002c55 start + 53
      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
      0   libsystem_kernel.dylib    0x9c48a90a kevent + 10
      1   libdispatch.dylib         0x900eac58 _dispatch_mgr_invoke + 969
      2   libdispatch.dylib         0x900e96a7 _dispatch_mgr_thread + 53
      Thread 2:
      0   libsystem_kernel.dylib    0x9c48a02e __workq_kernreturn + 10
      1   libsystem_c.dylib         0x9a2adccf _pthread_wqthread + 773
      2   libsystem_c.dylib         0x9a2af6fe start_wqthread + 30
      Thread 3:
      Thread 4:
      0   libsystem_kernel.dylib    0x9c48983e __psynch_cvwait + 10
      1   libsystem_c.dylib         0x9a2afe21 _pthread_cond_wait + 827
      2   libsystem_c.dylib         0x9a26042c pthread_cond_wait$UNIX2003 + 71
      3   com.apple.CoreServices.CarbonCore0x98c82e62 TSWaitOnCondition + 124
      4   com.apple.CoreServices.CarbonCore0x98bf43c5 TSWaitOnConditionTimedRelative + 136
      5   com.apple.CoreServices.CarbonCore0x98c56681 MPWaitOnQueue + 200
      6   com.adobe.ACE             0x080b6a69 0x8077000 + 260713
      7   com.adobe.ACE             0x080b5d99 0x8077000 + 257433
      8   com.apple.CoreServices.CarbonCore0x98c575e0 PrivateMPEntryPoint + 68
      9   libsystem_c.dylib         0x9a2abed9 _pthread_start + 335
      10  libsystem_c.dylib         0x9a2af6de thread_start + 34
      Thread 5:
      Thread 6:
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      Thread 12:
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000000  ebx: 0x9afa6330  ecx: 0xbffff04c  edx: 0x9c4899c6
        edi: 0xaceae2c0  esi: 0x00000006  ebp: 0xbffff068  esp: 0xbffff04c
         ss: 0x00000023  efl: 0x00000246  eip: 0x9c4899c6   cs: 0x0000000b
         ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
        cr2: 0x04f83e18
      Logical CPU: 0
      Binary Images:
      0x1000 - 0x2ff3 +com.adobe.Audition.5.0 (5.0x708 - 5.0) <7143E96E-16C4-15B3-73E1-B69B2E28AC62> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/MacOS/Adobe Audition CS6
      0x7000 - 0xaffb +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <6CE1936E-6AC7-6900-769B-876CBB68B5BC> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
         0x12000 -0x18ff7 +com.adobe.boost_date_time.framework (6.0.0 - 6.0.0.348464) <A946B021-8CB6-375A-0D5B-37E16B6DED76> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
         0x32000 -0x40ff3 +com.adobe.boost_threads.framework (6.0.0 - 6.0.0.348464) <EE427D2F-44C8-9DF7-9432-E0EAC2073322> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
         0x5e000 -0x68ff7 +com.adobe.boost_signals.framework (6.0.0 - 6.0.0.348464) <123701D0-BA86-956E-9D3A-1F05A4F2EEEB> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
         0x7f000 -0x82fff +com.adobe.boost_system.framework (6.0.0 - 6.0.0.348464) <733D47FB-B703-E1DD-42B8-FC60CDC67286> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
         0x89000 -   0x246fe3 +com.adobe.dvacore.framework (6.0.0 - 6.0.0.348464) <663DD48C-414B-7C64-79F1-2EEA08DBCD5B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
        0x42d000 -   0x84fff7 +com.adobe.dvaui.framework (6.0.0 - 6.0.0.348464) <6327A558-DF1E-3D65-413F-A78DDB9B9961> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
        0xd40000 -  0x105efeb +com.adobe.dvaadameve.framework (6.0.0 - 6.0.0.348464) <5AD031BA-0B79-0B68-E3AA-CB9A6C2126B1> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
      0x1706000 -  0x17b2ff3 +com.adobe.dvaworkspace.framework (6.0.0 - 6.0.0.348464) <4D2F35A2-DAE2-D2B3-C091-1DF1EBB94EAA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
      0x18ab000 -  0x18daff3 +com.adobe.dvamediatypes.framework (6.0.0 - 6.0.0.348464) <36494605-0BF9-C0C8-598D-243BD6D255BD> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
      0x190f000 -  0x1963ffb +com.adobe.dvametadata.framework (6.0.0 - 6.0.0.348464) <E6D4B62C-F80D-DA36-8A17-1F43F85D4FC3> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
      0x19f8000 -  0x1a54fef +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <123A0829-A85B-6E67-0E48-4F37B08E4C03> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
      0x1a5d000 -  0x1b18fef +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.4 -f 49 - 66.145661) <B8855D3A-C827-D9EB-040E-F808043458DA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
      0x1b47000 -  0x1bd3fff +com.adobe.dvametadataUI.framework (6.0.0 - 6.0.0.348464) <BC4B79B3-337D-0AB9-8315-5F7C38A64869> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
      0x1c9e000 -  0x1cf8fff +com.adobe.dvatemporalxmp.framework (6.0.0 - 6.0.0.348464) <C10B326B-3B9A-6C0F-A757-E55ACB51C16B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
      0x1d29000 -  0x1debff3 +com.adobe.exo.framework (6.0.0 - 6.0.0.348464) <A1DEBB6E-AE56-8B3E-62A3-2BDFD6FECEA8> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/exo.framework/Versions/A/exo
      0x1f34000 -  0x1f55ff7 +com.adobe.dvaunittesting.framework (6.0.0 - 6.0.0.348464) <3FFD4D0B-C02A-FDF1-8612-725D1BCA27DB> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
      0x1f96000 -  0x1fa3ffb +com.adobe.aucore.framework (1.0 - 1.0) <40B2195C-9FBD-6DBD-111F-FDCA4387E9FF> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
      0x1fbb000 -  0x21fcff3 +com.adobe.audsp.framework (1.0 - 1.0) <B4E896CF-9EF7-95AB-7D05-17EC6CD4074B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
      0x22af000 -  0x2360ffb +com.adobe.dvaaudiofilterhost.framework (6.0.0 - 6.0.0.348464) <E6C1B553-B2A8-75A0-B40C-C01056D8729E> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
      0x244c000 -  0x256afeb +com.adobe.auaudiocomponents.framework (1.0 - 1.0) <F61668F7-3716-A9A3-D7B3-3C3F6C2F7ABE> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuAudioComponents.framework/Versions/A/AuAudioComponents
      0x2627000 -  0x26a8feb +com.adobe.dvaaudiodevice.framework (6.0.0 - 6.0.0.348464) <8E0B5B3D-B285-ECA7-E016-46BB8F4A54C5> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
      0x275d000 -  0x27baffb +com.adobe.dvatransport.framework (6.0.0 - 6.0.0.348464) <1174AF4C-0FC5-D7B2-56DE-331C2B83B574> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
      0x2830000 -  0x2868ff3 +com.adobe.dvamarshal.framework (6.0.0 - 6.0.0.348464) <DAC2C35E-02DF-8620-D050-E94A49BA2785> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
      0x28f5000 -  0x2abbfe7 +com.adobe.dynamiclink.framework (6.0.0 - 6.0.0.348464) <87781694-3CCE-4E40-CF3D-8717BCA7805C> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
      0x2ca4000 -  0x2d5bffb +com.adobe.dvaplayer.framework (6.0.0 - 6.0.0.348464) <C31EDE2F-354C-369D-217A-4B9A272812CA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
      0x2ea3000 -  0x3208fe7 +com.adobe.aubackend.framework (1.0 - 1.0) <EC8C1CFE-821A-9BDE-156D-430CAD6CDC2F> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBackEnd
      0x3574000 -  0x357bfff +com.adobe.dvaundo.framework (6.0.0 - 6.0.0.348464) <3F921716-0B48-4C71-C633-99D05450A0D0> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
      0x3589000 -  0x39cafef +com.adobe.auapplication.framework (1.0 - 1.0) <68A76749-D933-E0DF-D10D-21735F863B53> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuApplication.framework/Versions/A/AuApplication
      0x3d6b000 -  0x3e36ff7 +com.adobe.auuitoolkit.framework (1.0 - 1.0) <0D46E172-E874-3889-43D1-CE1B88C840F5> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuUIToolkit
      0x3f9b000 -  0x404fffb +com.adobe.AdobeExtendScript (ExtendScript 4.2.12 - 4.2.12.18602) <2C860A49-8645-DC74-DC56-53BC99138C6F> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
      0x4092000 -  0x4130ff3 +com.adobe.AdobeScCore (ScCore 4.2.12 - 4.2.12.18602) <D8CDF140-E42A-DCFB-AFFC-69B4694FB639> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
      0x4166000 -  0x428dff3 +com.adobe.auscripting.framework (1.0 - 1.0) <18BB467E-16FF-AFE0-1C60-821D818E1C3F> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuScripting
      0x443a000 -  0x4491ffb +com.adobe.dvaaudiofilterhostui.framework (6.0.0 - 6.0.0.348464) <09E4640D-C6CC-678E-787C-56567ABD70AA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhostu i
      0x452a000 -  0x461afeb +com.adobe.auaudiocomponentsui.framework (1.0 - 1.0) <682B2B78-16D3-6965-F4C7-83E81BBDF034> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versions/A/AuAudioComponentsUI
      0x4742000 -  0x5225feb +com.adobe.auui.framework (1.0 - 1.0) <487E4C9E-4BAA-4969-ACAD-BD9546DCAF02> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
      0x5c3a000 -  0x5c77fff  com.apple.vmutils (4.2.1 - 107) <43B3BFA5-8362-3EBD-B44B-32DCE9885082> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0x5c91000 -  0x5ca5ff3 +com.adobe.boost_filesystem.framework (6.0.0 - 6.0.0.348464) <AB0E824D-AD9F-7AD5-9D5F-C6AE9D8BE579> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
      0x5cc9000 -  0x5d5cfe7 +com.adobe.boost_regex.framework (6.0.0 - 6.0.0.348464) <04104232-C5E0-F4F5-5C5D-8A45E2FE9C3E> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
      0x5df5000 -  0x5eb6ffb +com.adobe.dvaeve.framework (6.0.0 - 6.0.0.348464) <34CB64A1-5F13-89E5-8909-899F814F8301> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
      0x6016000 -  0x62d2ff7 +libmkl_intel.dylib (??? - ???) <25E5013B-C664-8353-5B95-417876276056> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/libmkl_intel.dylib
      0x6399000 -  0x6650ff7 +libmkl_sequential.dylib (??? - ???) <C0A18DB1-3D56-AF3A-2B0B-7FC163AEA80C> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/libmkl_sequential.dylib
      0x66e3000 -  0x7007fe3 +libmkl_core.dylib (??? - ???) <93B3DD56-8103-45E8-AD8D-7F133535BB4B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/libmkl_core.dylib
      0x709b000 -  0x709bfff  libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <859B5BCC-B5D9-370F-8B6C-1E2B242D5DCD> /usr/lib/libmx.A.dylib
      0x709e000 -  0x70caff3  com.apple.audio.CoreAudioKit (1.6.3 - 1.6.3) <7D47B1D3-4410-3524-BC47-FCDF49E48DB5> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
      0x70dd000 -  0x7186fe7 +iZotope_Radius (??? - ???) <85A9D505-8918-02CD-F5D9-EDA4AB5E24CD> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZotope_Radius
      0x71bc000 -  0x71f1fff +iZotopeOmegaStreaming (??? - ???) <98FBD353-965B-5C41-19FC-50F91A973A7C> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/iZotopeOmegaStreaming.framework/Versions/A/iZotopeOmegaStream ing
      0x7204000 -  0x7822ff7 +com.sonic.AS_Storage (5.2.17 - compatibility 1.0.0) <C4D2F83C-4B3B-EABB-DEAA-E6E48ABEF174> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AS_Storage.framework/Versions/A/AS_Storage
      0x7baa000 -  0x7c17ffb +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1652) <82DA9279-45D2-AD40-C86C-F5A94B9DAAFF> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x7c66000 -  0x7ef4fec +libxerces-c-3.0.dylib (??? - ???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/libxerces-c-3.0.dylib
      0x8077000 -  0x81f3ff3 +com.adobe.ACE (AdobeACE 2.19.18.19243 - 2.19.18.19243) <464E11C2-11BF-EED9-445F-B110D65E1944> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x8202000 -  0x88ddfe3 +com.adobe.AGM (AdobeAGM 4.26.17.19243 - 4.26.17.19243) <42C0275C-8715-D732-1EEB-12E4548DDA9F> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x895b000 -  0x8978ff3 +com.adobe.BIB (AdobeBIB 1.2.02.19243 - 1.2.02.19243) <652AAC98-9C63-CB58-8E03-45F14C8B3A1D> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x897e000 -  0x89a5ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <53AF73F4-B822-A23F-A7C6-0CFB6326D8AA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x89ab000 -  0x8cd2ffb +com.adobe.CoolType (AdobeCoolType 5.10.31.19243 - 5.10.31.19243) <4DB6A24B-C380-EF7A-B9A1-BF373C6F0AAD> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x8d0a000 -  0x8decff3 +com.adobe.amtlib (amtlib 6.0.0.93 - 6.0.0.93) <2218F05B-09B7-AE0E-5EF7-98FBA5DF9C86> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x8dfb000 -  0x8dfbffb +com.adobe.PRM.framework (6.0.0 - 6.0.0.0) <3B615928-9364-A3BE-41FC-84383CDC01B9> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
      0x8e02000 -  0x8e60ff7 +com.adobe.ASLFoundation.framework (6.0.0 - 6.0.0.0) <8EBBB1C5-8042-D532-D58B-36BBF96F4702> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
      0x8f1f000 -  0x8f3affb +com.adobe.ASLMessaging.framework (6.0.0 - 6.0.0.0) <959C4992-F28A-213F-6D1B-30E49C485FB9> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
      0x8f66000 -  0x8f74fff +com.adobe.ASLUnitTesting.framework (6.0.0 - 6.0.0.0) <0B446A0F-87BC-03B9-01A7-6F4EEB956083> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
      0x8f8e000 -  0x8fdbfef +com.adobe.MediaFoundation.framework (6.0.0 - 6.0.0.0) <D492885A-7550-1C92-58C2-DEFFE9A39712> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
      0x903f000 -  0x907cffb +com.adobe.DisplaySurface.framework (6.0.0 - 6.0.0.0) <EA64EA01-CE0E-5450-1CF9-8D45ED6EEA2B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
      0x90ce000 -  0x92e1ffb +com.adobe.ImageRenderer.framework (6.0.0 - 6.0.0.0) <EB99D6D9-C5AB-4232-DD5F-EF579D3EF263> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
      0x93d4000 -  0x93d5ffb +com.adobe.Memory.framework (6.0.0 - 6.0.0.0) <F9032F6D-6BBC-E66E-A5AE-BA4AA7D9167A> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
      0x93dc000 -  0x942cffb +com.adobe.VideoFrame.framework (6.0.0 - 6.0.0.0) <2D5BC52D-BB03-9C26-EF01-2D18EF2349CB> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
      0x9475000 -  0x9497fe7 +com.mainconcept.mc.enc.dv (9.1 - 9.1.0.60018) <7F1E874F-0B3E-AD0B-A016-328DD319F3B0> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
      0xa7c0000 -  0xa7ceffb  libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <D3F1CC34-55EB-3D33-A7C2-025D5C8025D0> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0xa7ef000 -  0xa7f0ff1  com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0xd7b0000 -  0xd7c2fff  libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <ADEB72F9-0048-3C87-AD9B-71AA57D523E9> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x103bb000 - 0x103bfffb  libFontRegistryUI.dylib (??? - ???) <E986346C-8132-33B6-8525-AA2A3233F99C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
      0x10a57000 - 0x10a58ffc  ATSHI.dylib (??? - ???) <B244624E-E09E-34B2-A185-EB30AF08A95D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
      0x8feb8000 - 0x8feeaaa7  dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
      0x90005000 - 0x90062ffb  com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x90063000 - 0x900a6ffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
      0x900a7000 - 0x900e7ff7  com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x900e8000 - 0x900f6fff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
      0x9015c000 - 0x90163ffd  com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x90164000 - 0x90167ffb  com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x90168000 - 0x901d7fff  com.apple.Heimdal (2.1 - 2.0) <BCF7C3F1-23BE-315A-BBB6-5F01C79CF626> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
      0x90545000 - 0x90546ff7  libsystem_sandbox.dylib (??? - ???) <D272A77F-7F47-32CD-A36E-5A3FB966ED55> /usr/lib/system/libsystem_sandbox.dylib
      0x90547000 - 0x9054affd  libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x9054b000 - 0x9054bfff  com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x9054c000 - 0x90a28ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x90a58000 - 0x90a75fff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
      0x90a76000 - 0x90afdfff  com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x90afe000 - 0x90afefff  com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x90aff000 - 0x90c60ffb  com.apple.QuartzCore (1.7 - 270.2) <4A6035C8-1237-37E5-9FFF-1EFD735D8B18> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x90c61000 - 0x90c62ff7  libquarantine.dylib (36.2.0 - compatibility 1.0.0) <3F974196-FBAD-3DBD-8ED0-DC16C2B3526B> /usr/lib/system/libquarantine.dylib
      0x90c63000 - 0x90c70fff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x90c71000 - 0x90c71fff  libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
      0x90cef000 - 0x90f74fe3  com.apple.QuickTime (7.7.1 - 2315) <E6249041-B569-3A96-897F-E84B1C057948> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x90f7f000 - 0x90fd0fff  libFontRegistry.dylib (??? - ???) <DF69E8EC-9114-3757-8355-8F3E82156F85> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x90fd1000 - 0x90ff6ff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x90ff7000 - 0x91059ff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
      0x91284000 - 0x91393fff  com.apple.DesktopServices (1.6.2 - 1.6.2) <33DCFB71-1D9E-30B6-BC4C-CD54068690BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x9149a000 - 0x914c8fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
      0x914dd000 - 0x914f9ffc  libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x914fa000 - 0x914fbfff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
      0x914fc000 - 0x9151effe  com.apple.framework.familycontrols (3.0 - 300) <6B0920A5-3971-30EF-AE4C-5361BB7199EB> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x91637000 - 0x91637fff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x91638000 - 0x9163fff5  libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
      0x91640000 - 0x920d3ff6  com.apple.AppKit (6.7.3 - 1138.32) <008E7C05-C20C-344A-B51C-4A2441372785> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x92107000 - 0x9210aff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
      0x9210b000 - 0x92134ffe  com.apple.opencl (1.50.69 - 1.50.69) <44120D48-00A2-3C09-9055-36D309F1E7C9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x92135000 - 0x9213dff3  liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
      0x9213e000 - 0x92200fff  com.apple.CoreServices.OSServices (478.37 - 478.37) <00A48B2A-2D75-3FD0-9805-61BB11710879> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x92364000 - 0x925d7ff7  com.apple.CoreImage (7.93 - 1.0.1) <88FEFE5B-83A9-3CD9-BE2E-DB1E0553EBB0> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
      0x925d8000 - 0x925ebffb  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <AE079D11-3A38-3707-A2DF-6BD2FC24B712> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x925ec000 - 0x925f4ff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
      0x925f5000 - 0x92600ffe  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <4A7FCD28-9C09-3120-980A-BDF6EDFAAC62> /usr/lib/libbz2.1.0.dylib
      0x92601000 - 0x92605fff  com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x92606000 - 0x927fbff7  com.apple.CoreData (104.1 - 358.13) <EB02DCA7-DB2A-32DD-B49E-ECE54D078610> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x92871000 - 0x92875ff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
      0x92876000 - 0x9287affd  IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x92891000 - 0x92928ff3  com.apple.securityfoundation (5.0 - 55107) <DF36D4ED-47F7-3F7F-AB09-32E5BFB7EF05> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x92929000 - 0x9296aff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <CAE102A7-EA5E-391C-A91F-A08071A68652> /usr/lib/libcurl.4.dylib
      0x9297e000 - 0x92a08ffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x92a09000 - 0x92a1dff7  com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x92a8a000 - 0x92ad3ff7  libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x92b20000 - 0x92c10ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
      0x9338c000 - 0x933c3fef  com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
      0x934f8000 - 0x935f0ff7  libFontParser.dylib (??? - ???) <8C069D3D-534F-3EBC-8035-A43E2B3A431A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x935f1000 - 0x93655fff  com.apple.framework.IOKit (2.0 - ???) <8DAF4991-7359-3D1B-AC69-3CBA797D1E3C> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x93656000 - 0x93657ff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
      0x93658000 - 0x937aafff  com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <E369AC9E-F548-3DF6-B320-9D09E486070E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x937e9000 - 0x937f9fff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
      0x93855000 - 0x9385dfff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x9385e000 - 0x93860ff9  com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x93939000 - 0x93947ff7  libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
      0x9399a000 - 0x9399eff7  com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x9399f000 - 0x93a82ff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
      0x93a83000 - 0x93c5afff  com.apple.CoreFoundation (6.7.1 - 635.19) <3A07EDA3-F460-3971-BFCB-AFE9A11F74F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x943c4000 - 0x943c5fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
      0x943c6000 - 0x943c7fff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x943c8000 - 0x94424fff  com.apple.coreui (1.2.1 - 165.3) <65526A00-D355-3932-9279-9A7D6BF76D95> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x94aac000 - 0x94aadffd  libCVMSPluginSupport.dylib (??? - ???) <6C364E11-B9B3-351A-B297-DB06FBAAFFD1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
      0x94aae000 - 0x94b3bfe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x94b3f000 - 0x94b42ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
      0x94b43000 - 0x94c53fe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
      0x956ea000 - 0x9574bffb  com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <E617857C-D870-3E2D-BA13-3732DD1BC15E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x958ab000 - 0x958b2ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
      0x958cb000 - 0x958d2fff  com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x958d3000 - 0x95949fff  com.apple.Metadata (10.7.0 - 627.28) <71AC8DA5-FA89-3411-A97C-65B6129E97BD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x959a1000 - 0x959d5ff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
      0x959d6000 - 0x959ebff7  com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x959ec000 - 0x95a15ff1  com.apple.CoreServicesInternal (113.12 - 113.12) <CFF78E35-81F5-36C2-A59F-BF85561AC16D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
      0x95a16000 - 0x95b27ff7  libJP2.dylib (??? - ???) <143828CE-D429-3C66-A0DC-4F39536568E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
      0x95b28000 - 0x95b2dff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
      0x9616d000 - 0x96187fff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x96188000 - 0x9619effe  libxpc.dylib (77.18.0 - compatibility 1.0.0) <D40B8FD1-C671-3BD5-8C9E-054AF6D4FE9A> /usr/lib/system/libxpc.dylib
      0x9619f000 - 0x961a2ff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
      0x961ca000 - 0x961f9ff7  libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
      0x96f4b000 - 0x9734dff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x9734e000 - 0x973e3ff7  com.apple.LaunchServices (480.27.1 - 480.27.1) <8BFE799A-7E35-3834-9403-20E5ADE015D0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x973e4000 - 0x976eeff3  com.apple.Foundation (6.7.1 - 833.24) <8E2AD829-587C-3146-B483-9D0209B84192> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x976ef000 - 0x978a3ff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
      0x978a4000 - 0x97d19ff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
      0x97d9e000 - 0x97ebcfec  com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x97efb000 - 0x97f29ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x97f34000 - 0x98003fff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <D4D6EB78-8A6C-3474-921C-622C6951489B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x98004000 - 0x9892c5eb  com.apple.CoreGraphics (1.600.0 - ???) <E285B0B6-F9FC-33BC-988F-ED619B32029C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x9892d000 - 0x9894cfff  com.apple.RemoteViewServices (1.3 - 44) <243F16F3-FFFE-3E81-A969-2EC947A11D89> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
      0x98a7a000 - 0x98acaff0  libTIFF.dylib (??? - ???) <F532A16A-7761-355C-8B7B-CEF988D8EEFF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x98ae4000 - 0x98aeffff  libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
      0x98af0000 - 0x98b0dff3  com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x98b0e000 - 0x98b0effe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
      0x98b0f000 - 0x98b45ff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x98b46000 - 0x98b71fff  com.apple.GSS (2.1 - 2.0) <DA24E4F9-F9D4-3CDB-89E4-6EAA7A9F6005> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
      0x98b72000 - 0x98b82ff7  libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
      0x98bad000 - 0x98bb5ff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
      0x98bb6000 - 0x98eb8fff  com.apple.CoreServices.CarbonCore (960.20 - 960.20) <E6300673-A013-3A91-BB1A-DD793B857E16> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x9916b000 - 0x991cdffb  com.apple.datadetectorscore (3.0 - 179.4) <32262124-6F75-3999-86DA-590A90BA464C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
      0x992e5000 - 0x993bbaab  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
      0x99403000 - 0x9944bff7  com.apple.SystemConfiguration (1.11.2 - 1.11) <CA077C0D-8A54-38DB-9690-5D222899B93D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x9944c000 - 0x99461fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x995f8000 - 0x996b8ffb  com.apple.ColorSync (4.7.1 - 4.7.1) <68413C12-2380-3B73-AF74-B9E069DFB89A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x996b9000 - 0x996c4ff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <DD0529E3-9D71-37B6-9EB8-D7747B2B12C6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x996c5000 - 0x996c5fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x996c6000 - 0x996d4fff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
      0x99a3a000 - 0x99a5dfff  com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x99a5e000 - 0x99ad2fff  com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
      0x99daf000 - 0x9a0f3ffb  com.apple.HIToolbox (1.8 - ???) <9540400F-B432-3116-AEAD-C1FBCFE67E73> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x9a161000 - 0x9a1b2ff9  com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
      0x9a1b3000 - 0x9a1b8ffd  libGFXShared.dylib (??? - ???) <179E77CE-C72C-3B5F-8F1E-3901517C24BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x9a1bb000 - 0x9a1c1ffd  com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
      0x9a1c2000 - 0x9a227ff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x9a24f000 - 0x9a31afff  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
      0x9a31b000 - 0x9a31bfff  com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x9a31c000 - 0x9a377ff3  com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
      0x9a7ba000 - 0x9a7bbff4  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
      0x9a7bc000 - 0x9a7f8ffa  libGLImage.dylib (??? - ???) <05B36DC4-6B90-33E6-AE6A-10CAA1B70606> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x9a9b8000 - 0x9a9b8fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x9a9b9000 - 0x9aa54ff3  com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x9aa55000 - 0x9aabcfff  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
      0x9aabf000 - 0x9abebff9  com.apple.CFNetwork (520.3.2 - 520.3.2) <58021CA7-0C91-3395-8278-8BD76E03BDCB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x9ac25000 - 0x9ac5bff4  com.apple.LDAPFramework (3.0 - 120.1) <EA92FCA5-7A7E-328F-8C7F-4250FCC45879> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
      0x9ac5c000 - 0x9ac65ff3  com.apple.CommonAuth (2.1 - 2.0) <5DA75D12-A4D6-3362-AD72-79A64C79669E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
      0x9ac66000 - 0x9ac66ff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x9ac67000 - 0x9ac69ffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x9af9e000 - 0x9afa7fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
      0x9afa8000 - 0x9afcaff1  com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
      0x9b1e7000 - 0x9b1eaff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <E06426D8-CC01-3754-B5B3-D15CBA5C8D73> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x9b639000 - 0x9b644ffc  com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
      0x9b77e000 - 0x9b782ffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
      0x9b783000 - 0x9b7dcfff  com.apple.HIServices (1.11 - ???) <F8B77735-B168-3E21-9B8F-921115B4C19B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x9b8bd000 - 0x9b961fff  com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x9b962000 - 0x9b9ddffb  com.apple.ApplicationServices.ATS (317.5.0 - ???) <7A8B0538-8E2E-3355-81E3-0C0A7EBED28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x9b9e3000 - 0x9b9e4fff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
      0x9b9e5000 - 0x9b9f0ffb  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x9ba41000 - 0x9ba51fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x9ba9c000 - 0x9bac4ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
      0x9bac5000 - 0x9bac9fff  libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x9bc0e000 - 0x9bc4eff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
      0x9bca7000 - 0x9bcc3ff5  com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
      0x9bcc4000 - 0x9bcceff2  com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x9bccf000 - 0x9bd0cff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <4508AABD-EDA8-3BF7-B03A-978D2395C9A8> /usr/lib/libcups.2.dylib
      0x9bd0d000 - 0x9bd13ffb  com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x9bd14000 - 0x9bdfcfff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
      0x9c047000 - 0x9c055fff  com.apple.opengl (1.7.6 - 1.7.6) <5EF9685C-F8B2-3B22-B291-8012761E9AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x9c46e000 - 0x9c470ff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
      0x9c471000 - 0x9c48fff7  libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
      0x9c4ee000 - 0x9c4eeff0  com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x9c623000 - 0x9c6b0ff7  com.apple.CoreText (220.11.0 - ???) <720EFEE0-A92A-3519-9C88-D06E4DE14EAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x9c6b1000 - 0x9c6effff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0FAB8C29-2A1B-3E25-BA34-BDD832B828DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x9c6f0000 - 0x9c701fff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
      0x9cb29000 - 0x9cde5ff3  com.apple.security (7.0 - 55110) <2F4FCD65-2A30-3330-99DE-91FE1F78B9FB> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0xb0000000 - 0xb001afe3 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <928D8FAD-DEE7-F1D0-FE17-FA7F4E4C1E48> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
      0xba900000 - 0xba91bffd  libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <5635DF40-8D8E-3B8C-B075-7B3FC0F184A4> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21ff6  libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) <17226124-8E8A-34EB-A2C4-D4A0469CF45B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      External Modification Summary:
        Calls made by other processes targeting this process:
      task_for_pid: 2
      thread_create: 0
      thread_set_state: 0
        Calls made by this process:
      task_for_pid: 0
      thread_create: 0
      thread_set_state: 0
        Calls made by all processes on this machine:
      task_for_pid: 556
      thread_create: 0
      thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=276.9M resident=173.3M(63%) swapped_out_or_unallocated=103.6M(37%)
      Writable regions: Total=146.3M written=25.9M(18%) resident=30.3M(21%) swapped_out=0K(0%) unallocated=116.0M(79%)
      REGION TYPE                  VIRTUAL
      ATS (font support)             31.9M
      CG shared images                 96K
      CoreGraphics                      8K
      CoreServices                   1088K
      MALLOC                         90.1M
      MALLOC guard page                32K
      Memory tag=242                   12K
      Memory tag=243                    4K
      Stack                          70.1M
      VM_ALLOCATE                    7784K
      __CI_BITMAP                      80K
      __DATA                         11.5M
      __DATA/__OBJC                   108K
      __IMAGE                         528K
      __IMPORT                         84K
      __LINKEDIT                     98.8M
      __OBJC                         1624K
      __PAGEZERO                        4K
      __TEXT                        178.1M
      __UNICODE                       544K
      mapped file                   556.6M
      shared memory                   312K
      shared pmap                    10.5M
      TOTAL                           1.0G
      Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 3.2 GHz, 24 GB, SMC 1.25f4
      Graphics: NVIDIA Quadro 4000, NVIDIA Quadro 4000, PCIe, 2048 MB
      Memory Module: DIMM Riser B/DIMM 1, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323541373243503844332D5335
      Memory Module: DIMM Riser B/DIMM 2, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323541373243503844332D5335
      Memory Module: DIMM Riser A/DIMM 1, 4 GB, DDR2 FB-DIMM, 800 MHz, 0x0D9B, 0x000000000000000000000000000000000000
      Memory Module: DIMM Riser A/DIMM 2, 4 GB, DDR2 FB-DIMM, 800 MHz, 0x0D9B, 0x000000000000000000000000000000000000
      Memory Module: DIMM Riser B/DIMM 3, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323541373243503844332D5335
      Memory Module: DIMM Riser B/DIMM 4, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323541373243503844332D5335
      Memory Module: DIMM Riser A/DIMM 3, 4 GB, DDR2 FB-DIMM, 800 MHz, 0x0D9B, 0x000000000000000000000000000000000000
      Memory Module: DIMM Riser A/DIMM 4, 4 GB, DDR2 FB-DIMM, 800 MHz, 0x0D9B, 0x000000000000000000000000000000000000
      Bluetooth: Version 4.0.3f12, 2 service, 18 devices, 1 incoming serial ports
      Network Service: Ethernet 2, Ethernet, en1
      PCI Card: NVIDIA Quadro 4000, sppci_displaycontroller, Slot-1
      PCI Card: NVIDIA Quadro 4000, NVDA,Parent, Slot-1
      PCI Card: pci17d3,1280, sppci_raid, Slot-4
      PCI Card: pcif1d0,c0ff, sppci_video, Slot-3@8,12,0
      Serial ATA Device: ST3500630AS P, 500.11 GB
      Parallel ATA Device: OPTIARC DVD RW AD-7170A
      USB Device: hub_device, apple_vendor_id, 0x911c, 0xfd500000 / 2
      USB Device: USB Receiver, 0x046d  (Logitech Inc.), 0xc52b, 0xfd510000 / 5
      USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd530000 / 4
      USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfd532000 / 6
      USB Device: Apple Cinema HD Display, apple_vendor_id, 0x921c, 0xfd520000 / 3
      USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8206, 0x5d200000 / 2
      FireWire Device: built-in_hub, 800mbit_speed
        • 1. Re: Cant open new install of Audition CS6 Constantly Crashing
          _durin_ Employee Hosts
          Hi lasvideo,
          It appears you may be running into a font-related issue discovered after release.  While we're working on a fix for this, there is a workaround to resolve the issue for now.
          Please follow the steps available at http://helpx.adobe.com/audition/kb/audition-cs6-crashes-launch.html and let me know if they resolve this issue.  If not, we can continue troubleshooting.
          Durin
          • 2. Re: Cant open new install of Audition CS6 Constantly Crashing
            Finally got it to work. A little tricky on the Mac, but doable.
            Tom Daigon
            Premier / After Effects Editor
            www.hdshotsandcuts.com
            • 3. Re: Cant open new install of Audition CS6 Constantly Crashing
              Hi Tom,
              You got it to work with the instructions I posted, or was it a different issue?
              In any case, I'm glad it's working and we hope to have a permanent solution available very soon.  Please let me know if you run into any other issues.
              Durin
              • 4. Re: Cant open new install of Audition CS6 Constantly Crashing
                Yes, with your instructions. Creating the test file on the Mac was tricky because it kept wanting to save the file I created as rtf. But I worked around that issue eventually. Thank you very much!
                • 5. Re: Cant open new install of Audition CS6 Constantly Crashing
                  rossdc Community Member
                  Hey Tom, I was having the same problem with my subscription Audition CS6 on an iMac running OS X 10.7.4.  Your solution was instantly effective for me.
                  Thanx.
                  DCR
                  • 7. Re: Cant open new install of Audition CS6 Constantly Crashing
                    Thanks for the follow-ups, everyone.  Very appreciated.
                    An issue was discovered after release where some fonts may cause a graphics acceleration library in Audition to crash.  It has been exceedingly difficult to reproduce in-house, but with the help of some of our stellar pre-release users we've been able to confirm a solution that should be made available soon.  Thanks for your help and patience.  I hate sneaky bugs.
                    Durin
                    • 8. Re: Cant open new install of Audition CS6 Constantly Crashing
                      Durin, thanks for the work around fix!!!
                      • 9. Re: Cant open new install of Audition CS6 Constantly Crashing
                        NickWB Community Member
                        Thanks for this. Fixed.
                        One tip - don't try renaming the exisitng .txt file and adding in the text - it does not work
                        • 10. Re: Cant open new install of Audition CS6 Constantly Crashing
                          Robertino Community Member
                          Yes, the fix seems to have worked so far... fingers crossed.  Thanks.
                          Sadly, I would think this problem would have been a chance for the unpopular "subscription model" to have really stepped up to the plate...
                          Adobe advertising department's "affordable monthly membership includes upgrades to all new versions upon release, plus new features and services between releases" and Adobe development team's solution buried in a discussion group suggests not everybody is quite on the same page yet.
                          I've passed on my experience and notes here to a few other Lion 10.7.4 subscribers, and hope they will be able to get their crashing product working as well.
                          • 11. Re: Cant open new install of Audition CS6 Constantly Crashing
                            This is probably the wrong thread for this discussion, but I'll touch upon the subscription updates vs. patches real quick.
                            The "boxed software release" model that Adobe has followed, with accounting requirements born from the Sarbanes-Oxley laws, limited how Adobe could release new functionality.  In a nutshell, we would be unable to ship new features in a "version" of the software, outside the quarter that it was released.  This means that if you paid for Audition CS6 in January and Adobe completely counted this sale on their revenue reports, and then in June we released an update with new features, Adobe would be in trouble if they provided this new functionality to you without receiving additional revenue.  Bug fixes are okay, but new "stuff" is a no-no.  It is possible to get around this by deferring portions of the sale revenue throughout the year, but it's not simple.
                            The subscription model eases these restrictions by, in effect, making each "sale" last for only a month with each new months subscription cost recorded as a "new" sale.  This means all of our product teams now have the ability to release new functionality monthly, without worrying about the lawyers and accountants knocking on our doors.
                            However, changing our development systems and release processes is going to take some time and it's going to require a few product teams to take the lead and work out the kinks before everyone can really take advantage of this opportunity.  Believe me, the Audition team would love to be putting out a new release every few months adding new features we've been working on, fixing bugs, and responding more quickly to your requests.  But currently, we spend a significant amount of time between the time we stop developing new features and the day the version is released.  There's a lot of testing, fixing, discussions, improvements, documentation, and release & marketing preparation that goes into every release we make public, and while our goal is to release as often as possible, we're not going to get there overnight with the processes we've had for the last 15+ years.
                            Updates to fix bugs is a slightly simpler matter since we're implementing these fixes on a codebase that has already been vetted and released.  We still spend a lot of time ensuring the fixes work as expected and don't have any negative impact in other areas of the program.  We've got to be certain because it's a logistical and support nightmare when there are dozens of potential versions of the software out there in use.  The fewer "subversions" that are in use, the better we can respond to questions and issues.
                            So, expect to see an update soon that addresses the bugs that were discovered after release.  In the longer-term, we really hope to supply regular upgrades to our Creative Cloud customers - though keep in mind that we would still be unable to offer these versions to users of the boxed or perpetual-license product.  It's a new frontier in a lot of ways, especially for Adobe, so it may take awhile to really get its momentum.  It will be very nice when we get there, though.
                            • 12. Re: Cant open new install of Audition CS6 Constantly Crashing
                              SteveG(AudioMasters) Community Member
                              Not for the boxed users it won't be... I can imagine a lot of flack over this.
                              • 13. Re: Cant open new install of Audition CS6 Constantly Crashing
                                _durin_wrote:
                                "The "boxed software release" model that Adobe has followed, with accounting requirements born from the Sarbanes-Oxley laws, limited how Adobe could release new functionality.  In a nutshell, we would be unable to ship new features in a "version" of the software, outside the quarter that it was released.  This means that if you paid for Audition CS6 in January and Adobe completely counted this sale on their revenue reports, and then in June we released an update with new features, Adobe would be in trouble if they provided this new functionality to you without receiving additional revenue.  Bug fixes are okay, but new "stuff" is a no-no.  It is possible to get around this by deferring portions of the sale revenue throughout the year, but it's not simple."
                                While the the information is appreciated, and obviously an Adobe mantra, this is clearly not true in the real world. Many (US based) companies release new features in an existing software release, under a 'boxed software release' model where a software version is paid for in a single transaction. This includes Apple through their app store, and plenty of other download only software companies, so it is possible.
                                If Adobe manage to fulfil their promises of fixes and features on an ongoing basis, then all the good, but the current model not delivering, yet charging a subscription, is not really a way of moving forward IMO.
                                Back to the current issue, is it really acceptable that bug fixing is now a (paying) user responsibility? That over six weeks after the initial reports there is still not a released fix for a critical issue that prevents the software from launching / running? Yes, there is workaround here for the tech savy user, but a 30 min phone call Adobe Tech support could not point me to it, nor could any other way to get the software running.
                                • 14. Re: Cant open new install of Audition CS6 Constantly Crashing
                                  emmrecs Community Member
                                  I'm not a Mac user and I realise this thread seems particularly pertinent to that OS, but...
                                  I'm one of the "boxed users" (albeit as a download) and this morning when I turned my computer on I was met by a screen which told me that there was an update/bug fix available to download for AA CS6.  This downloaded and installed without problem.  So, clearly, the provision to provide such to non-subscription or Creative Cloud members is "active"; however, it appears from what _durin_ wrote that any "new features" which may be introduced to the program are NOT to be made automatically available to users like me.  Not good!
                                  Jeff
                                  • 15. Re: Cant open new install of Audition CS6 Constantly Crashing
                                    N74JW Community Member
                                    I am in the same boat, running 10.7.5, Au 5.0.2. I tried the steps above but they did not do anything to fix the problem. Audition works if I log in as another user. The program is updated to it's latest extent, according to the Adobe update manager. CS6 was installed from a DVD and with an education license.
                                    Anything else I can try?
                                    TIA
                                    • 16. Re: Cant open new install of Audition CS6 Constantly Crashing
                                      GrizzlyAK Community Member
                                      _durin_, I've got a similar problem, but on Win7 Ultimate x64. This is a new install of CS6 Master Collection, on a new HP z820, and Audition fails 19 times out of 20, just after showing the program window on launch. Faulting Module is AuScripting.dll.
                                      I've been on chat with adobe twice. The first time, "regsvr32 vbscript.dll" seemed to resolve the problem, for a while. Now I can't get it to run at all, and have been through all the steps in the link http://forums.adobe.com/message/4204470#4204470.
                                      At any rate, it appears this application wasn't well tested before release. At first, InDesign failed as well, along with Extension Manager, but whatever we did on the first chat seemed to work for those, at least for now, and we did a lot (uninstall, reinstall, register stuff, rename stuff, delete stuff, etc., etc., etc.). This last time, I was told I needed to call in. Yay. It's pretty sad that we spend so much money on Adobe products and they won't run out of the box on a brand new, fresh installation, on one of Microsoft's most stable OSs. Do you guys still have a testing department, after nobody upgraded to CS4 or CS5? Now I remember why I skipped CS4, CS5, and CS5.5...
                                      In addition, I'm not at all thrilled about your comments on Adobe's new approach to bug fixes and feature releases for 'box set' customers. I'm not a fan of 'subscriptions', sorry, call me old school. One day, hopefully soon, there will be serious competition for Adobe and all of us will remember these 'bad ole days'. Maybe soon, too, I'll be able to run an application I paid for a while ago. That would be nice.
                                      Cheers,
                                      Griz
                                      • 17. Re: Cant open new install of Audition CS6 Constantly Crashing
                                        Hi Griz,
                                        Can you send me an e-mail at audbugs@adobe.com?  I'd like to troubleshoot this a bit more with you if you don't mind.  I've received reports from another user about problems in AuScripting.DLL that were related to their locked-down network permissions, but the Scripting team asked for additional information.  (In their case, users whose accounts were not completely locked-down did not have a problem.  It was related to their limtitations on their Roaming profiles.)
                                        I must disagree, however, that Audition wasn't well-tested before release.  This has absolutely been the most dedicated and intelligent group of engineers I've had the pleasure to work with, and the Audition CS codebase is one of the best-architected applications I've seen.  There have been a small number of issues that were found after release, but in most cases they have been related to specific system or network environments.
                                        • 18. Re: Cant open new install of Audition CS6 Constantly Crashing
                                          I have to agree about the dedication -- your fix solved my problem some weeks ago, and thanks for that.  I have the highest confidence in Adobe products.
                                          • 19. Re: Cant open new install of Audition CS6 Constantly Crashing
                                            _durin_,
                                            Sorry, I was just a little peeved last night when I wrote my post. As a career SW engineer (25+ years), I know what is involved in developing complex apps, especially a whole suite of them that are integrated. However, it seems to happen all too often that things just don't work out of the box, perhaps due to the complex nature of the interaction of all the apps and their various HW components. Indeed, the MC is a wealth of SW capabilities all in one. (Although, I still say shame on Adobe for it's apparent disregard for former long term GoLive users in converting to DW, but that's for another time).
                                            At any rate, I would be happy to work with you and others to help Adobe better understand what is happening here. One thing I can report, is that after my post here, I found this:
                                            which resolved my problem perfectly. So, at least we know that my problem fits in that bin. I will email you directly.
                                            Cheers,
                                            Griz
