1 Reply Latest reply on May 31, 2012 12:42 PM by BennoFlo
    StageWebView and iOS - LocationChangeEvent
    BennoFlo
      Hi All,
      I've run into a cross platform issue. Below is my current code for location change handling within my StageWebView.
      webView.addEventListener(LocationChangeEvent.LOCATION_CHANGE, handleHrefClick);
      webView.addEventListener(LocationChangeEvent.LOCATION_CHANGING, handleHrefClick);
      if(Capabilities.version.indexOf("IOS") != -1){
              webView.addEventListener(Event.COMPLETE, handleHrefClickComplete);
      What I use this for is clicking links within my HTML. For Android, whenever the click occurs, a LocationChangingEvent occurs.
      However, in iOS, I get no event. I just receive the following error:
      The protocol is not supported.: <myProtocol>://blah/#<ID>
      As you can see, I tried capturing Event.COMPLETE for iOS, but to no avail. What is the proper way to capture location change events for iOS?
      More Notes:
      The reason I have custom URLs that are linked up is to capture the StageWebView's location change, prevent default interaction (going to a custom URL), and parsing the ID from this URL. Then I use the ID to call some javascript functions and do cool things within my StageWebView.
      All helpful comments are appreciated.
      Ben
        • 1. Re: StageWebView and iOS - LocationChangeEvent
          BennoFlo Level 1
          I fixed the above issue. In this case, the iPhone is reporting an Event.ERROR whenever the unsupported protocol is used. I can parse this error message for my ID and get my desired result.
          However, if the protocol was supported and clicked via HREF within a StageWebView, does anyone know the resulting event?
          I'll do some testing a bit later for more information.
