4 Replies Latest reply on Jun 20, 2012 2:03 PM by csthacker
    Extension Manager "unexpectedly quit" after initial install
    csthacker Level 1
      I can't get Adobe Extension Manager to open at all after an initial install.  It crashes with an "unexpectedly quit" error.
      I used AAMEE 3.0 to create an install package, then installed CS 6.
      I moved the AdobeUpdaterAdminPrefs.dat file out of its folder and then I updated all CS 6 apps using the built-in updater.  I then put the .dat file back.
      I modified the Acrobat 'FeatureLockDown' file to prevent updates.
      To fix the crashing, I've tried deleting a couple of obvious Extension Manager preferences but that didn't help.   What else can I try?
      I installed it on 10.6.8.
      Thanks!
        • 1. Re: Extension Manager "unexpectedly quit" after initial install
          Xiaoyi Tong Adobe Employee
          If Extension Manager crashed when it is launched, a crash reporter window would pop up to show some technical data. Did you see that? Have you tried to download and install Extension Manager again( http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/AdobeExtensionManager 6.0All.dmg )?
          You can try following 2 things:
          1. ( Generate log files ) http://forums.adobe.com/message/4275082#4275082
          2. ( launch Extension Manager again with admin ) http://forums.adobe.com/message/4275109#4275109
          3. If steps above does not work, please paste the content of log here.
          • 2. Re: Extension Manager "unexpectedly quit" after initial install
            csthacker Level 1
            it runs when launched with admin (step 3 above) so what might that indicate?
            i've tried reinstalling and that didn't help.  I updated it to the latest version and tried reinstalling and leaving at an older version.  neither will open without crashing unless i use the terminal.
            thanks!
            Process:         Adobe Extension Manager CS6 [16256]
            Path:            /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/Adobe Extension Manager CS6
            Identifier:      com.adobe.ExtensionManager
            Version:         "6.0.0.412" (6.0.412)
            Code Type:       X86 (Native)
            Parent Process:  launchd [146]
            Date/Time:       2012-06-01 12:37:10.449 -0700
            OS Version:      Mac OS X 10.6.8 (10K549)
            Report Version:  6
            Interval Since Last Report:          103208 sec
            Crashes Since Last Report:           10
            Per-App Interval Since Last Report:  5670 sec
            Per-App Crashes Since Last Report:   5
            Anonymous UUID:                      56FBB038-00A2-4C1E-B611-2A327A8F76A6
            Exception Type:  EXC_BAD_ACCESS (SIGBUS)
            Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
            Crashed Thread:  9
            Thread 0:  Dispatch queue: com.apple.main-thread
            0   libSystem.B.dylib                       0x94fb7afa mach_msg_trap + 10
            1   libSystem.B.dylib                       0x94fb8267 mach_msg + 68
            2   com.apple.CoreFoundation                0x9743e2df __CFRunLoopRun + 2079
            3   com.apple.CoreFoundation                0x9743d3c4 CFRunLoopRunSpecific + 452
            4   com.apple.CoreFoundation                0x9743d1f1 CFRunLoopRunInMode + 97
            5   com.apple.HIToolbox                     0x965e4e04 RunCurrentEventLoopInMode + 392
            6   com.apple.HIToolbox                     0x965e4bb9 ReceiveNextEventCommon + 354
            7   com.apple.HIToolbox                     0x965e4a3e BlockUntilNextEventMatchingListInMode + 81
            8   com.apple.AppKit                        0x92ffb595 _DPSNextEvent + 847
            9   com.apple.AppKit                        0x92ffadd6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
            10  com.apple.AppKit                        0x92fbd1f3 -[NSApplication run] + 821
            11  com.apple.AppKit                        0x92fb5289 NSApplicationMain + 574
            12  com.adobe.ExtensionManager              0x000243c2 main + 1426
            13  com.adobe.ExtensionManager              0x00021fe5 start + 53
            Thread 1:  Dispatch queue: com.apple.libdispatch-manager
            0   libSystem.B.dylib                       0x94fde382 kevent + 10
            1   libSystem.B.dylib                       0x94fdea9c _dispatch_mgr_invoke + 215
            2   libSystem.B.dylib                       0x94fddf59 _dispatch_queue_invoke + 163
            3   libSystem.B.dylib                       0x94fddcfe _dispatch_worker_thread2 + 240
            4   libSystem.B.dylib                       0x94fdd781 _pthread_wqthread + 390
            5   libSystem.B.dylib                       0x94fdd5c6 start_wqthread + 30
            Thread 2:
            0   libSystem.B.dylib                       0x94fdd412 __workq_kernreturn + 10
            1   libSystem.B.dylib                       0x94fdd9a8 _pthread_wqthread + 941
            2   libSystem.B.dylib                       0x94fdd5c6 start_wqthread + 30
            Thread 3:
            Thread 4:
            0   libSystem.B.dylib                       0x94fb7c0e mach_wait_until + 10
            1   libSystem.B.dylib                       0x9503f429 nanosleep + 345
            2   com.adobe.ExtensionManager              0x001eeae3 ScObjects::Thread::sleep(unsigned int) + 143
            3   com.adobe.ExtensionManager              0x001eeb43 ScObjects::Thread::wait(unsigned int) + 23
            4   com.adobe.ExtensionManager              0x001e583e ScObjects::BridgeTalkThread::run() + 332
            5   com.adobe.ExtensionManager              0x001ef04d ScObjects::Thread::go(void*) + 315
            6   libSystem.B.dylib                       0x94fe5259 _pthread_start + 345
            7   libSystem.B.dylib                       0x94fe50de thread_start + 34
            Thread 5:
            0   libSystem.B.dylib                       0x94fe5aa2 __semwait_signal + 10
            1   libSystem.B.dylib                       0x94fe575e _pthread_cond_wait + 1191
            2   libSystem.B.dylib                       0x94fe73f8 pthread_cond_wait$UNIX2003 + 73
            3   com.adobe.ape.engine                    0x1354004f APXGetHostAPI + 2633743
            4   com.adobe.ape.engine                    0x132d162f APXGetHostAPI + 83439
            5   com.adobe.ape.engine                    0x1354013e APXGetHostAPI + 2633982
            6   com.adobe.ape.engine                    0x135401a7 APXGetHostAPI + 2634087
            7   com.adobe.ape.engine                    0x135402c6 APXGetHostAPI + 2634374
            8   libSystem.B.dylib                       0x94fe5259 _pthread_start + 345
            9   libSystem.B.dylib                       0x94fe50de thread_start + 34
            Thread 6:
            Thread 7:
            0   libSystem.B.dylib                       0x94fb7b5a semaphore_timedwait_signal_trap + 10
            1   libSystem.B.dylib                       0x94fe56e1 _pthread_cond_wait + 1066
            2   libSystem.B.dylib                       0x950145a8 pthread_cond_timedwait_relative_np + 47
            3   com.adobe.ape.engine                    0x13540017 APXGetHostAPI + 2633687
            4   com.adobe.ape.engine                    0x1355920e APXGetHostAPI + 2736590
            Thread 8:
            4   com.adobe.ape.engine                    0x136ce0c8 APXGetHostAPI + 4264072
            Thread 9 Crashed:
            0   com.apple.CoreFoundation                0x97413973 CFArrayGetCount + 67
            1   com.apple.CoreFoundation                0x974645fc _CFBundleTryOnePreferredLprojNameInArray + 60
            2   com.apple.CoreFoundation                0x974644a5 _CFBundleCopyLocalizationsForPreferences + 421
            3   com.adobe.ExtensionManager              0x000f24d4 CMacrFireworks9::Initialize() + 346
            4   com.adobe.ExtensionManager              0x0003e173 CMacrExtensionManager::AddFwToProductsListOnInit() + 85
            5   com.adobe.ExtensionManager              0x0003e470 CMacrExtensionManager::AddDwFwFlToProductsListOnInit() + 26
            6   com.adobe.ExtensionManager              0x0006c0f9 CMacrExtensionManager::Init() + 753
            7   com.adobe.ExtensionManager              0x000f967c COWLFrontController::Initialize() + 3502
            8   com.adobe.ExtensionManager              0x0010e8f4 CommandExecutor::init() + 22
            9   com.adobe.ExtensionManager              0x000f6318 CommandExecutor_Impl::run() + 38
            10  com.adobe.ExtensionManager              0x000f63c8 CommandExecutor_Impl::runHelper(void*) + 60
            11  libSystem.B.dylib                       0x94fe5259 _pthread_start + 345
            12  libSystem.B.dylib                       0x94fe50de thread_start + 34
            Thread 10:
            0   libSystem.B.dylib                       0x94fd6ac6 select$DARWIN_EXTSN + 10
            1   com.adobe.ape.engine                    0x13825593 SWFLPlayer_Initialize + 853027
            2   com.adobe.ape.engine                    0x13512280 APXGetHostAPI + 2445888
            3   com.adobe.ape.engine                    0x1354013e APXGetHostAPI + 2633982
            4   com.adobe.ape.engine                    0x135401a7 APXGetHostAPI + 2634087
            5   com.adobe.ape.engine                    0x135402c6 APXGetHostAPI + 2634374
            Thread 11:
            3   com.adobe.ape.engine                    0x132cef3d APXGetHostAPI + 73469
            4   com.adobe.ape.engine                    0x132cf292 APXGetHostAPI + 74322
            Thread 9 crashed with X86 Thread State (32-bit):
              eax: 0x00000000  ebx: 0x9741393c  ecx: 0x01277190  edx: 0x00000012
              edi: 0x00000000  esi: 0xffffffff  ebp: 0xb04bd708  esp: 0xb04bd6f0
               ss: 0x0000001f  efl: 0x00010287  eip: 0x97413973   cs: 0x00000017
               ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
              cr2: 0x00000000
            Binary Images:
                0x1000 -   0x30efe3 +com.adobe.ExtensionManager "6.0.0.412" (6.0.412) <0778E482-6353-D2CE-064B-25990F587784> /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/Adobe Extension Manager CS6
              0x430000 -   0x437ffb +com.adobe.ape.shim 3.3.8.19346 (3.3.8.19346) <B711CAA7-29D6-D5CF-CE1B-A611896C8D87> /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
              0x43f000 -   0x500fe7 +IMSLib.dylib 6.0.38.0 (BuildVersion: 1.0; BuildDate: Mon Jan 30 2012 13:08:45 ) (6.0.38.0 (BuildVersion: 1.0; BuildDate: Mon Jan 30 2012 13:08:45 )) <CF29E154-EF93-2C62-B217-85AA2EEBBE50> /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Frameworks/IMSLib.dylib
              0x516000 -   0x519ffb +com.adobe.AdobeCrashReporter 6.0 (6.0.20120201) <6CE1936E-6AC7-6900-769B-876CBB68B5BC> /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
              0x520000 -   0x523fe7 +libwchar.dylib ??? (???) <458F4548-4404-7972-AB6D-7B3FD7A22772> /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Frameworks/libwchar.dylib
              0x526000 -   0x598fef +com.adobe.adobe_caps adobe_caps 6.0.29.0 (6.0.29.0) <E4ADECD5-05B4-E78B-09D8-E45FD640E84D> /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
              0x5a5000 -   0x612ffb +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1640) <82DA9279-45D2-AD40-C86C-F5A94B9DAAFF> /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
              0x65b000 -   0x69bff7  com.apple.vmutils 4.2 (106) <92BB4844-304C-C7AB-1F9B-686537C56099> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
            0x171c000 -  0x1770fe7 +com.adobe.ape 3.3.8.19346 (3.3.8.19346) <0B80F7A7-EC10-A7C7-5E6E-787953553C55> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/adbeapecore
            0x17f6000 -  0x17faff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <E9CB576C-283B-1DB2-0C69-E7C914BD7922> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
            0x13288000 - 0x141d0fcb +com.adobe.ape.engine 3.3.8.19346 (3.3.8.19346) <FB642021-E854-27B0-9C15-E3567B4F56B9> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/Libraries/adbeapeengine.bundle/Contents/MacOS /adbeapeengine
            0x143cb000 - 0x14480fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
            0x14751000 - 0x14757ff7  com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
            0x17580000 - 0x1758efe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <1825F5DF-491F-FDD5-3ABB-3FAC1EDC4357> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
            0x17592000 - 0x175a4ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <3057675E-16A3-EC0C-A764-5CADB6C5ECD2> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
            0x17b55000 - 0x180cfff7 +Webkit.dylib ??? (???) <E95E661D-8C10-3227-AF6A-89594FF2A873> /Library/Application Support/Adobe/APE/3.3/adbeapecore.framework/Versions/A/Libraries/Webkit.dylib
            0x1987b000 - 0x1987cff7  com.apple.textencoding.unicode 2.3 (2.3) <A7D310DB-A5E6-C834-F72F-A66453834CC0> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
            0x8fe00000 - 0x8fe4163b  dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
            0x90003000 - 0x90043ff3  com.apple.securityinterface 4.0.1 (40418.0.1) <2141A924-748E-CE6F-2D75-D82BC265BD30> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
            0x90044000 - 0x90055ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
            0x90056000 - 0x90064fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
            0x9009f000 - 0x900e3ff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
            0x900e4000 - 0x900eafff  com.apple.CommonPanels 1.2.4 (91) <CE92759E-865E-8A3B-1488-ECD497E4074D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
            0x900eb000 - 0x900ebff7  com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
            0x900ec000 - 0x90104ff7  com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
            0x90105000 - 0x90143ff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
            0x9024b000 - 0x9024fff7  libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
            0x90250000 - 0x90258ff7  com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
            0x90259000 - 0x9025ffe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
            0x90260000 - 0x90319fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
            0x9031a000 - 0x90370ff7  com.apple.MeshKitRuntime 1.1 (49.2) <CB9F38B1-E107-EA62-EDFF-02EE79F6D1A5> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
            0x90371000 - 0x9037cff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
            0x9042e000 - 0x9049cff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
            0x9049d000 - 0x90660feb  com.apple.ImageIO.framework 3.0.5 (3.0.5) <87750C2B-193F-56A6-AB97-0842A2D02092> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
            0x90661000 - 0x90741fe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
            0x9087f000 - 0x908fafff  com.apple.AppleVAFramework 4.10.27 (4.10.27) <BFD2D1CA-535C-F16F-0EB5-04905ABD65CF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
            0x908fb000 - 0x90b6cfef  com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            0x90b6d000 - 0x90fa2ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <4D2F47EF-BD32-1E3C-6A0A-438896ADE2BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
            0x90fa3000 - 0x90fd6fff  libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
            0x91653000 - 0x916e5fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
            0x916e6000 - 0x91721ffb  libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
            0x91722000 - 0x91755ff7  com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
            0x9187f000 - 0x918cefe7  libTIFF.dylib ??? (???) <D0EB31DC-40E6-9A97-64D3-9867605DC3DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
            0x918cf000 - 0x918dfff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <95DC4010-ECC4-3A75-5DEE-11BB2AE895EE> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
            0x91902000 - 0x9195cfe7  com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
            0x919be000 - 0x91a89fef  com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
            0x91a8a000 - 0x91abaff7  com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
            0x91abb000 - 0x91bfefef  com.apple.QTKit 7.7 (1790) <95F7C69A-1D24-A96A-E95D-1DF8CCD03FB3> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
            0x91c6e000 - 0x91f8eff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
            0x91f8f000 - 0x9223dfe7  com.apple.JavaScriptCore 6534.57 (6534.57.3) <5B18B308-DBB2-7133-DE56-494C2FA1848B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
            0x9228c000 - 0x9228fff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
            0x92300000 - 0x92300ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
            0x92301000 - 0x923b9feb  libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
            0x923ba000 - 0x923ceffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <9F5CE4F7-D05C-8C14-4B76-E43D07A8A680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
            0x923ed000 - 0x923f4ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
            0x92401000 - 0x92404ff7  libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
            0x9248e000 - 0x92c7d557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
            0x92cc4000 - 0x92d2efe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
            0x92d2f000 - 0x92dddff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
            0x92dde000 - 0x92eaffe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <C618942F-BC01-0565-18CF-477B63C02181> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
            0x92eb0000 - 0x92fb2fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
            0x92fb3000 - 0x93896ff7  com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
            0x938a8000 - 0x938a8ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
            0x938a9000 - 0x938b3ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
            0x938ed000 - 0x9392aff7  com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
            0x9392b000 - 0x939adffb  SecurityFoundation ??? (???) <C4506287-1AE2-5380-675D-95B0291AA425> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
            0x939f2000 - 0x93a8ffe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
            0x93a90000 - 0x93a94ff7  IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
            0x93a95000 - 0x93aa1ff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
            0x93ad7000 - 0x93b19ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
            0x93b2b000 - 0x93b4cfe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
            0x93b4d000 - 0x93b4fff7  com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
            0x93b50000 - 0x93b57ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <A5FF7623-9F55-0364-AD9B-42CF13C677C1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
            0x93b58000 - 0x93b58ff7  com.apple.ApplicationServices 38 (38) <EAF1BC8C-4FD4-4300-B8F7-4B24E49125E2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
            0x93b59000 - 0x93b69ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <E276514D-394B-2FDD-6264-07A444AA6A4E> /usr/lib/libsasl2.2.dylib
            0x93bb6000 - 0x93c06ff7  com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
            0x94b5b000 - 0x94b70fff  com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
            0x94b79000 - 0x94bb3ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <6875335E-0993-0D77-4E80-41763A8477CF> /usr/lib/libcups.2.dylib
            0x94bb4000 - 0x94bb4ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
            0x94bb5000 - 0x94bd5fe7  libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
            0x94bd6000 - 0x94ce2fe7  libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
            0x94ce3000 - 0x94ce3ff7  com.apple.Cocoa 6.6 (???) <5A785062-1ABB-2A54-BAAC-8FEF95275E05> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
            0x94cfa000 - 0x94d92fe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
            0x94d93000 - 0x94e95fef  com.apple.MeshKitIO 1.1 (49.2) <D0401AC5-1F92-2BBB-EBAB-58EDD3BA61B9> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
            0x94fb7000 - 0x9515eff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
            0x951dd000 - 0x95204ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <F45520B0-6B27-CD57-54B1-203FE32120DA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
            0x95205000 - 0x956c0ff7  com.apple.VideoToolbox 0.484.60 (484.60) <B53299EC-E30F-EC04-779D-29B7113CC14A> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
            0x9589b000 - 0x958c3ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <E761F29A-328B-29D9-3DF0-023F2C21E500> /usr/lib/libxslt.1.dylib
            0x95ad1000 - 0x95aeffe7  libPng.dylib ??? (???) <45185287-25AD-C239-AA58-8FA53DF55B79> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
            0x95af0000 - 0x95af0ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
            0x95d01000 - 0x95d13ff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
            0x95d14000 - 0x95d18ff7  libGIF.dylib ??? (???) <5D29E5F4-30B9-5A24-55E7-BCBA30499093> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
            0x95d6b000 - 0x95d6bff7  com.apple.quartzframework 1.5 (1.5) <7DD4EBF1-60C4-9329-08EF-6E59731D9430> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
            0x95d6c000 - 0x95f97ff3  com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
            0x95f98000 - 0x96292fef  com.apple.QuickTime 7.6.6 (1790) <A5B2CDA8-47C9-F1AE-ED54-625B0FAB426F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
            0x96293000 - 0x9629cff7  com.apple.DiskArbitration 2.3 (2.3) <6AA6DDF6-AFC3-BBDB-751A-64AE3580A49E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
            0x9629d000 - 0x962f0ff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
            0x962f1000 - 0x96473fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib
            0x96474000 - 0x9650ffe7  com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
            0x96536000 - 0x96539fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
            0x96586000 - 0x965aaff7  libJPEG.dylib ??? (???) <5F2343E4-C268-B9AE-1BC3-466F5A614648> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
            0x965b0000 - 0x968d4fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            0x96bfb000 - 0x96bfdff7  libRadiance.dylib ??? (???) <98EC06D5-1A02-EDEF-BF9D-2C986761AD54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
            0x96c29000 - 0x96c6fff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
            0x96cdf000 - 0x96d2cfeb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
            0x96d2d000 - 0x96d2eff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <1DD14B2E-E466-1A45-5CF7-947766F0ECD9> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
            0x96f37000 - 0x96f4bfe7  libbsm.0.dylib ??? (???) <B328FA0A-899C-4FC4-F2AC-2FDC08819CD2> /usr/lib/libbsm.0.dylib
            0x96f65000 - 0x96f8bffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
            0x96f8c000 - 0x97038fe7  com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
            0x97047000 - 0x972adff7  com.apple.security 6.1.2 (55002) <E999CCEF-B769-4355-3E68-6003FCF6FE2B> /System/Library/Frameworks/Security.framework/Versions/A/Security
            0x972ae000 - 0x9735bfe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
            0x9735c000 - 0x9737bff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
            0x97401000 - 0x9757cfe7  com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0x9757d000 - 0x976abfe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
            0x976ac000 - 0x97ac2ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <9D89FCB3-24C9-8FCF-DB49-27B184AC3222> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
            0x97ac3000 - 0x97af4ff7  libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
            0x97b8c000 - 0x97bcfff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
            0x97bd0000 - 0x97becfe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
            0x97bed000 - 0x97c5cff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
            0x97e3a000 - 0x97e9efff  com.apple.htmlrendering 72 (1.1.4) <0D22B190-513B-7FF6-39FC-9D336285DE08> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
            0x97e9f000 - 0x97f5bfff  com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
            0x97f5c000 - 0x982c7ff7  com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
            0x98a6b000 - 0x98a8dfef  com.apple.DirectoryService.Framework 3.6 (621.14) <A24C9308-4EB3-456D-1691-43DDB6F9A79F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
            0x98a8e000 - 0x98bcbfe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
            0x98cc6000 - 0x98d09ff7  libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
            0x98d0a000 - 0x98db2ffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
            0x98db3000 - 0x98eb3fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <BE7FCD73-03B5-25A4-FCA4-D4980F1488D6> /usr/lib/libxml2.2.dylib
            0x98eb4000 - 0x98eb9ff7  com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
            0x98f15000 - 0x99042ffb  com.apple.MediaToolbox 0.484.60 (484.60) <A7FE2739-64A7-40EB-A6E7-69FBCE3C87D4> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
            0x99043000 - 0x99046ffb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
            0x99047000 - 0x99051fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <DE0E0EF6-8190-3F65-6BDD-5AC9D8A025D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
            0x99066000 - 0x990adffb  com.apple.CoreMediaIOServices 140.0 (1496) <DA152F1C-8EF4-4F5E-6D60-82B1DC72EF47> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
            0x990ae000 - 0x9910bff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
            0x9910c000 - 0x99151ff7  com.apple.ImageCaptureCore 1.1 (1.1) <F54F284F-0B81-0AFA-CE47-FF797A6E05B0> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
            0x99152000 - 0x99160ff7  com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
            0x991b8000 - 0x99231ff7  com.apple.PDFKit 2.5.1 (2.5.1) <A068BF37-03E0-A231-2791-561C60C3ED2B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
            0x99341000 - 0x99399fe7  com.apple.datadetectorscore 2.0 (80.7) <3830B574-3B0B-76DA-390D-702D908A71F4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
            0x9939a000 - 0x9939bff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
            0x9939c000 - 0x993a7ff7  libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
            0x993a8000 - 0x99409fe7  com.apple.CoreText 151.12 (???) <98F53C15-1D29-A2B3-0717-5A26A2699163> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
            0x9a18e000 - 0x9a1cbff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
            0x9a1cd000 - 0x9a247fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
            0x9a248000 - 0x9a255ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
            0x9a256000 - 0x9a297ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
            0x9a298000 - 0x9a299ff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
            0x9a2d5000 - 0x9a2d5ff7  liblangid.dylib ??? (???) <FCC37057-CDD7-2AF1-21AF-52A06C4048FF> /usr/lib/liblangid.dylib
            0x9a2d6000 - 0x9a3b0fff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
            0x9a442000 - 0x9a486fe7  com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
            0x9a487000 - 0x9a507feb  com.apple.SearchKit 1.3.0 (1.3.0) <7AE32A31-2B8E-E271-C03A-7A0F7BAFC85C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
            0x9aa11000 - 0x9abf3fff  com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
            0xb0000000 - 0xb001afe3 +com.adobe.ahclientframework 1.7.0.56 (1.7.0.56) <928D8FAD-DEE7-F1D0-FE17-FA7F4E4C1E48> /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
            0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <49C72FD1-891C-23C4-40E7-63DE3368C306> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
            0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <B7E8B785-D05F-F89B-5E18-EF854555926C> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
            0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
            Model: iMac7,1, BootROM IM71.007A.B03, 2 processors, Intel Core 2 Duo, 2.8 GHz, 2 GB, SMC 1.21f4
            Graphics: ATI Radeon HD 2600 Pro, ATI,RadeonHD2600, PCIe, 256 MB
            Memory Module: global_name
            AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.131.42.4)
            Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
            Network Service: Ethernet, Ethernet, en0
            Serial ATA Device: WDC WD5000AAKS-00A7B2, 465.76 GB
            Parallel ATA Device: OPTIARC  DVD RW AD-5630A
            USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd400000 / 2
            USB Device: Hub in Apple Pro Keyboard, 0x05ac  (Apple Inc.), 0x1003, 0x3a200000 / 2
            USB Device: Apple Optical USB Mouse, 0x05ac  (Apple Inc.), 0x0307, 0x3a210000 / 4
            USB Device: Apple Pro Keyboard, 0x05ac  (Apple Inc.), 0x020b, 0x3a230000 / 3
            USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8206, 0x1a100000 / 2
            USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x5d100000 / 2
            • 3. Re: Extension Manager "unexpectedly quit" after initial install
              From the log above, the crash happened on the memory object initialization of Fireworks11.5/Fireworks12. The localization array might has something wrong which caused the memory violation or other fatal errors. According to your description( "it runs when launched with admin" ), this seems a privilege related problem.
              My suggestion is:
              1. Check the Fireworks11.5 or Fireworks12 installed on your machine, unisntall and reinstall them again if it is possible. You'd better intall them on the default location to avoid privilege troubles.
              2. If you cannot do the 1st step or it does not work, you have to always run Extension Manager as admin. It is a workaround.
              • 4. Re: Extension Manager "unexpectedly quit" after initial install
                csthacker Level 1
                I created the CS6 installer using AAMEE and rerunning the installer and uninstaller that AAMEE made both failed.  So I wiped the system and installed CS6 again from the already created AAMEE pkg.
                I reinstalled again using the AAMEE created package and am getting the same result.
                Running Extension Manager as admin won't work for us.  I am trying to create a fileset to deploy this to all of our clients.  This needs to be fully functional and work as expected before doing that.
