1 Reply Latest reply on Jun 4, 2012 12:07 AM by Loic.Aigon
    [AS][CS4] Recursive XML element function
    JohnDevlon Level 1
      Does anyone have any experience in using a recursive XML element function in Applescript and Indesign CS4?
      I would like to do a search for a XML element based on the text who has the xml attachted.
      tell application "Adobe InDesign CS4"
                tell active document
                          set myXMLElement to XML element 1
                          repeat with i from 1 to the number of items of XML elements of myXMLElement
                                    my SearchXML(item i of XML elements of myXMLElement)
                          end repeat
                end tell
      end tell
      on SearchXML(elm)
                          set myText to contents of elm
                          repeat with i from 1 to the number of items of XML elements of elm
                                    my SearchXML(item i of XML elements of elm)
                          end repeat
                end tell
      end UpdateXMLData
      For some reason myText doesn't contain the text but an XML structure !!!! (something like
      XML element id 3 of XML element id 2 of document "test.indd")
      I've used the same structure in Javascript and the contents property gives the text back !
      What I'm I doing wrong? How can I get the text contents of the xml element?
        • 1. Re: [AS][CS4] Recursive XML element function
          Loic.Aigon Adobe Community Professional
          I would definitively recommend you to avoid recursing within the xml structure as it's freaking slow ! Instead I do use evaluate XPath expression :
          tell application "Adobe InDesign CS5.5"
                    tell XML element 1 of active document
            evaluate XPath expression using "//tag[.='foo']"
                    end tell
          end tell
          => returns a list of all xmlElements whose markup tag name is "tag" and where the contents is "foo".
          Then you can iterate through the list.
          Loic
