5 Replies Latest reply on Jun 4, 2012 2:48 PM by davidflash123
    DataProvider: Is it possible
    davidflash123
      Hi All, I'm a newbie.  Question:  Is it possible to have one dataprovider call via an HttpService call and use the same data in both a datagrid and a comboBox or ListBox.  Can the data type be XML in the HttpService call.  Or do I have to use "ex4" data type to use for my comboBox????
      Are there any examples /scripts to look at???
      Thanks for taking the time.
        • 1. Re: DataProvider: Is it possible
          sumit.king7 Level 1
          Yes you can use type XML for setting the data provider for any of the three controls(combobox, datagrid, listbox).
          see the example I prepared:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                    <mx:List x="303" y="34" dataProvider="{dataXml.name}"></mx:List>
                    <mx:DataGrid x="522" y="37" dataProvider="{dataXml.name}">
                    </mx:DataGrid>
                    <mx:ComboBox x="864" y="38" dataProvider="{dataXml.name}"></mx:ComboBox>
                    <mx:Script>
                              <![CDATA[
                                        private var dataXml:XML = <root>
        <name>A</name>
        <name>B</name>
        <name>C</name>
        </root>
                    </mx:Script>
          </mx:Application>
          • 2. Re: DataProvider: Is it possible
            davidflash123 Level 1
            Sumit Jain, I tried your example, but got this error on line 16.  See my code below.  Thanks for your asistance.
                  xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
                  creationComplete="userRequest.send()">
            <fx:Declarations>
              <s:HTTPService id="userRequest" url="http://localhost:8500/PostalTest2-debug/test1.cfm"
                    useProxy="false" method="POST">
               <mx:request xmlns="">
                <username>{username.text}</username>
                <emailaddress>{emailaddress.text}</emailaddress>
               </mx:request>
              </s:HTTPService>
              <mx:script>
              <![CDATA[
               private var userRequest:XML = <users>
               <name>username</name>
               <name>emailaddress</name>
               </users>
              </mx:Script>
            </fx:Declarations>
            <mx:Form x="22" y="10" width="300">
              <mx:FormItem>
               <s:Label text="Username" />
               <s:TextInput id="username"/>
              </mx:FormItem>
              <mx:FormItem>
               <s:Label text="Email Address" />
               <s:TextInput id="emailaddress"/>
              </mx:FormItem>
              <s:Button label="Submit" click="userRequest.send()"/>
            </mx:Form>
            <mx:DataGrid id="dgUserRequest" x="573" y="18" height="556"
                 dataProvider="{userRequest.lastResult.users.user}">
              <mx:columns>
               <mx:DataGridColumn headerText="User ID" dataField="username"/>
               <mx:DataGridColumn headerText="User Name" dataField="emailaddress"/>
              </mx:columns>
            </mx:DataGrid>
            <s:TextInput x="22" y="300" id="selectedemailaddress" text="{dgUserRequest.selectedItem.emailaddress}"/>
            <mx:ComboBox x="864" y="38" dataProvider="{userRequest.username}"></mx:ComboBox>
            </s:Application>
            • 3. Re: DataProvider: Is it possible
              Problem solved,  I was able to locate some solutions to solve my combobox problem.  I am now able to load data into the combobox.   Now I just need to figrue out how to update the backend database when I select a data from either the datagrid or combobox.
              See below
              <fx:Declarations>
                 </mx:request>
                </s:HTTPService>
              </fx:Declarations>
                <mx:FormItem>
                </mx:FormItem>
                <mx:FormItem>
                </mx:FormItem>
              </mx:Form>
              <s:ComboBox x="864" y="38" dataProvider="{userRequest.lastResult.users.user}"
              labelField= "username">
              </s:ComboBox>
                <mx:columns>
                </mx:columns>
              </mx:DataGrid>
              </s:Application>
              • 4. Re: DataProvider: Is it possible
                sumit.king7 Level 1
                I think instead of using HTTP service, use Remoting so that u can call a ColdFusion Component function directly.
                Now, Apply a change event on combobox. And in the change handler function of combobox, call the coldfusion component function which in turn updates ur database.
                I suggest, go for remoting.
                • 5. Re: DataProvider: Is it possible
                  frustrated newbie.  I using this code by is getting this error:
                  "[MessagingError message='Destination 'ColdFusion' either does not exist or the destination has no channels defined (and the application does not define any default channels.)']"
                  My code:
                        xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                  <fx:Declarations>
                    <mx:RemoteObject
                     id="userRequest"
                     destination="ColdFusion"
                     source="//xxxxx.xxx.com/webdata/IS/ACE3-Data/cfc/PrinterSitesTable.cfm">
                     <mx:method name="GetAllLocations" result="returnHandler(event)"
                          fault="mx.controls.Alert.show(event.fault.faultString)"/>
                  <!--  <mx:method name="insertRecord" result="insertHandler()"
                    </mx:RemoteObject>
                  </fx:Declarations>
                  <fx:Script>
                    <![CDATA[
                     import mx.rpc.events.ResultEvent;
                     private function returnHandler(e:ResultEvent):void
                      dgUserRequest.dataProvider = e.result;
                  // <!-- private function insertHandler():void
                  //   userRequest.GetAllLocations();
                  //  private function clickHandler():void
                  //   userRequest.insertRecord(username.text, emailaddress.text);
                  </fx:Script>
                    <mx:FormItem>
                    </mx:FormItem>
                    <mx:FormItem>
                     <s:Label text="Email Add" />
                    </mx:FormItem>
                    <s:Button label="Submit" click="userRequest.GetAllLocations()"/>
                  </mx:Form>
                  <mx:DataGrid id="dgUserRequest" x="22" y="200" width="754" height="364">
                    <mx:columns>
                     <mx:DataGridColumn headerText="User ID" dataField="FacilityDatabaseID"/>
                     <mx:DataGridColumn headerText="User Name" dataField="FACILITY_NAME"/>
                    </mx:columns>
                  </mx:DataGrid>
                  </s:Application>
                  My problem is that I do not know what to put in :
                     source="//xxxxx.xxx.com/webdata/IS/ACE3-Data/cfc/PrinterSitesTable.cfc">
                  My development is on my local PC, but I want to reference my coldfusion cfc on my actual production server.  This server is my share server, I do not know where our actual Coldfusion server is located.  All I know is that when I run my Coldfusion apps, the worked when using and calling cfc's.
                  So my think is that once I officially launch the app on our production server, the destination source will already be in place.  I just do not know how to reference the source.    All I can tell you is that the cfc's that I use when running Coldfusion programs are located in my "webdata/IS/ACE-Data/cfc folder.
                  Now I trying to use Flex to reference my Coldfusion cfc's and I do not know what to used for the source.
                  Can I use for the source =  "http://servername.com/webdata/IS/ACE3-Data/cfc/PrinterSitesTable.cfc.
                  or source = //servername/webdata/IS/ACE3-Data/cfc/PrinterSitesTable.cfc.
                  I read about services-config.xml but it seems that file must go under the actual Coldfusion server (which I do not have access to nor know where the server located.
                  Can you or anyone assist.
                  Thanks.
