2 Replies Latest reply on Jun 1, 2012 7:18 AM by sylvaimz
    Path problem with aerender
    sylvaimz
      Hello all,
      I'm on an Mac Platform and I've a problem with 'aerender' command line renderer. When i use this command :
      /Applications/Adobe\ After\ Effects CS6/aerender -project /Volumes/xsan/irl/3_users/SYLVAIN/project.aep -comp "Comp 1" -output /Volumes/xsan/irl/3_users/SYLVAIN
      The command exit with:
      aerender version 11.0x378
      PROGRESS: Launching After Effects...
      PROGRESS: ...After Effects successfully launched
      aerender Error: After Effects error: Unable to call openFast because of parameter 1. Path is not valid. Path: /Volumes/Volumes/xsan/irl/3_users/SYLVAINproject.aep
      Heuu!!! WTF!
      I've try to uninstall and delete prefs then reinstall but that do nothing...
      Please help... I can't use Smedge and Terminal for render !!!!
        • 1. Re: Path problem with aerender
          And what if you leave out the "Volumes" part? Looks like this is an alias and when resolving it, the program doubles the path reference...
          Mylenium
          • 2. Re: Path problem with aerender
            sylvaimz Level 1
            Hello Mylenium,
            Thank you for reply.
            aerender -project /xsan/irl/3_users/SYLVAIN/testSmedge/testSmedgeCS6.aep -output /xsan/irl/3_users/SYLVAIN/testSmedge -comp "Comp 1"
            output:
            aerender Error: After Effects error: Error in output for render queue item 1, output module 1. Directory does not exist: /Volumes/Volumes/xsan/irl/3_users/SYLVAIN.
            What do you mean by an alias ?
