7 Replies Latest reply on Jun 10, 2012 6:16 AM by Loic.Aigon
    JS Obtain list of elements in library asset
    secondgradersrule Level 1
      I am trying to develop a script to obtain a list of elements in each library asset, and the link status of each.  The workaround has been to place each asset onto a page and then use the Links window to check the status of the elements.
      This code returns [object Asset]:
      var libList = app.libraries.item(0).assets.item(0).getElements();
      This returns the name of the asset:
      var libName = app.libraries.item(0).assets.item(0).name;
      The eventual goal is to write a script for off-site disaster recovery.  It would relink each library asset element to a backup copy in the new location.
      Is this possible without writing a script to  place each asset, update the links and then put it back in the library?
      Thanks.
      Dick Conrad
        • 1. Re: JS Obtain list of elements in library asset
          Loic.Aigon Adobe Community Professional
          Sure it is, however, it's basically consisting in placing library item, editing item, replacing ( or updating* ) item, removing placed content.
          Quite time consuming but still quicker than manual operations.
          I wrote a snippet that you need to set for your own needs :
          function updateAllAssetsInLib ( lib )
                    var libAssets = lib.assets.everyItem().getElements(), libAsset, placedAsset, doc = app.activeDocument;
                    while ( libAsset = libAssets.pop() )
                              placedAsset = libAsset.placeAsset ( doc );
                              placedAsset = placedAsset[0];
                              // do your stuff;
                              libAsset.remove();
                              lib.store ( placedAsset );
                              placedAsset.remove();
          updateAllAssetsInLib ( app.libraries.itemByName ( "foo.indl" ) );
          Hope it helps,
          Loic
          *Pretty sure there is a "update library item" that you can call with meanuAction.invoke() but recently it disappeared from my UI to the point I started wondering if I had dreamed about it.
          • 2. Re: JS Obtain list of elements in library asset
            Thanks for the help.  I will enjoy stepping through this and watching the action.  In the meantime, I am wondering why the link status of an element can't be obtained via a property.  Apparently InDesign has to place the item before attemping to resolve the source.
            Thanks again.
            Dick Conrad
            • 3. Re: JS Obtain list of elements in library asset
              No I don't think you can check at link status while asset is in the library.
              • 4. Re: JS Obtain list of elements in library asset
                @Loic – you are not dreaming ;-)
                Try the following:
                //Invoke the menu "Update Library Item":
                try{app.scriptMenuActions.itemByID(34410).invoke()}catch(e){};
                I got the ID from InDesign CS4 and it is still the same in InDesign CS5 and CS5.5.
                Uwe
                • 5. Re: JS Obtain list of elements in library asset
                  @Uwe Thanks, I feel safer now However, I don't know if it's a bug. I used it intensively ( invokinbg the update ). And then it really vanished from the UI, the contextual menu just doesn't display the command any longer. I had to modify my script in order to place asset, edit placed item, store edited item, remove former asset. That's dumb but it's all I have left
                  • 6. Re: JS Obtain list of elements in library asset
                    Loic:
                    Your code was very helpful in building a script to batch-change the paths of library items.  I did find a quirk with Indesign CS.
                    I tested my script in CS5. An asset with three elements (two images plus text) ended up with the new paths!  I then ran it against a large CS library, omitting the image swap and just generating a list of assets and links.  Each replacement asset received the name 'untitled.'    The production use of the script will be in CS5 so I am not concerned,  and I have not tried forcing the asset name into the replacement for use with CS.
                    Dick
                    • 7. Re: JS Obtain list of elements in library asset
                      Hi Dick,
                      Yes, it's "normal"; To be complete the snippet should include the asset name
                                var libAssets = lib.assets.everyItem().getElements(), libAsset, assetName, placedAsset, doc = app.activeDocument;
                      assetName = libAsset.name;
                                          // do your stuff;
                                          libAsset.remove();
                                          lib.store ( placedAsset, {name:assetName} );
