4 Replies Latest reply: Jun 2, 2012 1:26 PM by Smitch1581 RSS
    Checkbox values
    Smitch1581 MeganK
      Hi
      I have this script that when a check box is ticked it inserts the values in to a new field. It removes the "Off" value and all works well
      At the moment when 2 check boxes are ticked it enters both values into the field. What i would reallly like is that when any 2 check boxes are ticked, i would like the text field to display MUL. Can any body help me finish of my code, its beaten me ;(
      // array of field names to use
      var aFieldNames = new Array("HOR", "LIV", "CAR", "FUR", "HEA", "MIN", "HOU", "Skills", "ICT", "BDS", "None");
      // clear the result field
      event.value = "";
      // variable for testing the value of a single field
      var cItem = "";
      // array of values not equal to "Off"
      var aValues = new Array();
      // process each field name
      for (i = 0; i < aFieldNames.length; i ++) {
      // get i name's field value as a string
      cItem = this.getField(aFieldNames[i]).valueAsString;
      // see if value not equal to "Off"
      if(cItem != "Off") {
      // add to array of non "Off" values
      aValues[aValues.length] = cItem;
      } // end not "Off" value
      } // end loop names
      // set field value
      event.value = aValues.join(", ");
      var sect = this.getField("R1").length;
      if (sect == "String")
      event.value = "MUL";
      Thanx in advance
        • 1. Re: Checkbox values
          GKaiseril CommunityMVP
          You could just count how many check boxes have a value other than "Off" and then fill in the field base on that value. Zero and one is blank 2 or greater is "Mul".
          • 2. Re: Checkbox values
            Smitch1581 MeganK
            Thanx for the reply. For some reason i just cant get this. How do i i check the value is other than "Off"?
            • 3. Re: Checkbox values
              You are already adding the value to an array when the check box value is not "Off" or the check box has a value other than off.
              You need to define a variable to hold the count and then of adding the value of the check box to the array, you increment the count.
              Another idea, since you have the non-Off values in an array just check the length or number of items in the array. If the length is greater than 1 then there are multiple entries. If the value is zero then there are no check boxes checked.
              change:
              // set field value
              To
              // set the field value
              event.value ="";
              if(aValues.length > 1)
              event.value = "Mul";
              • 4. Re: Checkbox values
                Smitch1581 MeganK
                Thank you very much! Thats was driving me up the wall. Knew what i wanted to do but just couldnt do it!
                Thanx again
