1 Reply Latest reply on Jun 1, 2012 1:01 PM by needles27
    Has anyone have these error codes in "Console" utility Mac Pro Users?
    Autoworldmobilia Level 1
      I am getting zero resolutions from Adobe Call Center. Five / Six hours of explainations between PP and AE. Sending my RAID card to be checked out .. but still errors are persistant.
      Could someone check the Console for me .. thanks.
      6/1/12 2:45:37.136 PM Adobe Premiere Pro CS5.5: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/System.framework' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      6/1/12 2:45:37.178 PM Adobe Premiere Pro CS5.5: kCGErrorInvalidConnection: CGSGetOnScreenWindowCount: Invalid connection
      6/1/12 2:45:37.178 PM Adobe Premiere Pro CS5.5: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
      6/1/12 2:45:37.179 PM Adobe Premiere Pro CS5.5: kCGErrorInvalidConnection: CGSGetOnScreenWindowCount: Invalid connection
      6/1/12 2:45:37.367 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Texture memory: 0
      6/1/12 2:45:37.381 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Vendor string:    NVIDIA Corporation
      6/1/12 2:45:37.381 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Renderer string:  NVIDIA GeForce GTX 285 OpenGL Engine
      6/1/12 2:45:37.381 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Version string:   2.1 NVIDIA-7.10.2
      6/1/12 2:45:37.381 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: OpenGL version as determined by Extensionator...
      6/1/12 2:45:37.381 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: OpenGL Version 2.0
      6/1/12 2:45:37.381 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Supports shaders!
      6/1/12 2:45:37.393 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Supports BGRA -> BGRA Shader
      6/1/12 2:45:37.393 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Supports VUYA Shader -> BGRA
      6/1/12 2:45:37.395 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Supports UYVY/YUYV ->BGRA Shader
      6/1/12 2:45:37.396 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Supports YUV 4:2:0 -> BGRA Shader
      6/1/12 2:45:37.396 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Testing for CUDA support...
      6/1/12 2:45:37.396 PM [0x0-0x1d01d].com.adobe.AdobePremierePro:    Found 1 devices supporting CUDA.
      6/1/12 2:45:37.396 PM [0x0-0x1d01d].com.adobe.AdobePremierePro:    CUDA Device # 0 properties -
      6/1/12 2:45:37.396 PM [0x0-0x1d01d].com.adobe.AdobePremierePro:    CUDA device details:
      6/1/12 2:45:37.396 PM [0x0-0x1d01d].com.adobe.AdobePremierePro:       Name: GeForce GTX 285
      6/1/12 2:45:37.396 PM [0x0-0x1d01d].com.adobe.AdobePremierePro:       Compute capability: 1.3
      6/1/12 2:45:37.396 PM [0x0-0x1d01d].com.adobe.AdobePremierePro:       Total Video Memory: 1023MB
      6/1/12 2:45:37.396 PM [0x0-0x1d01d].com.adobe.AdobePremierePro:    CUDA driver version: 4020
      6/1/12 2:45:37.397 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: CUDA Device # 0 supported.
      6/1/12 2:45:37.411 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: Completed shader test!
      6/1/12 2:45:37.580 PM Adobe QT32 Server: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/System.framework' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      6/1/12 2:45:49.612 PM com.apple.kextd: Can't create kext: invalid CFBundleVersion in identifier cache entry entry 329.
      6/1/12 2:45:49.914 PM com.apple.kextd: Can't create kext: invalid CFBundleVersion in identifier cache entry entry 329.
      6/1/12 2:45:51.343 PM com.apple.launchd: (com.apple.coreservices.appleid.authentication[128]) Exit timeout elapsed (20 seconds). Killing
      6/1/12 2:45:51.437 PM Adobe Premiere Pro CS5.5: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      6/1/12 2:45:52.908 PM aerendercore: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/System.framework' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      6/1/12 2:45:52.909 PM aerendercore: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/System.framework' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      6/1/12 2:45:53.505 PM aerendercore: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/System.framework' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      6/1/12 2:45:53.761 PM Adobe Premiere Pro CS5.5: OS_ViewContainer Cocoa view is <DVAMacContainerView: 0x12dc97e10>
      6/1/12 2:45:53.873 PM Adobe QT32 Server: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/System.framework' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      6/1/12 2:45:56.890 PM aerendercore: -[NSMenu menuID]: unrecognized selector sent to instance 0x10d284150
      6/1/12 2:46:31.457 PM mdworker: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
      6/1/12 2:46:36.876 PM com.apple.kextd: Can't create kext: invalid CFBundleVersion in identifier cache entry entry 329.
      6/1/12 2:48:41.941 PM helpd: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
      6/1/12 2:54:06.480 PM Adobe Premiere Pro CS5.5: [PremiereCocoaMacApplication handleMenuCommand:2147483638 from <DVAMacMenuItem: 0x113e9af10 Updates...>]
      6/1/12 2:54:06.776 PM PDApp: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      6/1/12 2:54:06.776 PM [0x0-0x1d01d].com.adobe.AdobePremierePro: 2012-06-01 14:54:06.775 PDApp[245:403] CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
      6/1/12 2:56:27.162 PM Adobe Premiere Pro CS5.5: [PremiereCocoaMacApplication handleMenuCommand:11361 from <DVAMacMenuItem: 0x11d257070 Memory...>]
