4 Replies Latest reply on Mar 1, 2013 5:47 AM by stejan74
    CQ 5 Default select text in Selection
    Raja_Raju_Learner
      I am noew to CQ5. I need to know how to display the --Select-- default value int he selection xtype of CQ5.
      Any help will be appreciated.
        • 1. Re: CQ 5 Default select text in Selection
          Sham HC Level 7
          Have you tried using the property 'defaultValue' on the node having xtype as 'selection'.
          • 2. Re: CQ 5 Default select text in Selection
            Raja_Raju_Learner Level 1
            Hi Sham,
            Thanks for your input. I will use ‘defaultValue’ and check it out.
            Thanks & Regards,
            Raja R
            • 3. Re: CQ 5 Default select text in Selection
              kand12345 Level 1
              I am also having an issue with this.
              Given the following structure in my dialog.xml:
              <someSelect
                   name="someSelect"
                   fieldLabel="Here are some options"
                   type="select"
                   xtype="selection"
                   defaultValue="value1"
                   allowBlank="false"
                   jcr:primaryType="cq:Widget">
                          <options jcr:primaryType="cq:WidgetCollection">
                                   <option1
                                          jcr:primaryType="nt:unstructured"
                                          text="Option 1"
                                          value="value1"/>
                                   <option2
                                           text="Option 2"
                                           value="value2" />
                          </options>
              </someSelect>
              I tried putting these properties on my select:
              defaultValue="0"
              defaultValue="1"
              activeItem="0"
              activeItem="1"
              And none of these will set the first option, or any option, as the default for the select.
              What am I missing here??
              • 4. Re: CQ 5 Default select text in Selection
                stejan74 Level 1
                I had the same problem but now i found it.
                I don't know if you need this information but for others it's perhabs helpful.
                You have to set the value property then it works.
                <someSelect
                     value="value1"
