21 Replies Latest reply on Jun 6, 2012 6:07 PM by Kevin-Monahan
    Adjust Gain by... (CS6)
    Steven Pribilinskiy Level 1
      Every time, after changing Audio Gain by using Adjust Gain by parameter, a "Calculating Audio Peeks" dialog with progress bar is pop-up.
      It is expected, that the peaks will be updated instantly like after setting a value for the Set Gain to parameter. Opinions?
      Feature Request/Bug Report Form
      ******BUG******
      Concise problem statement:Unnecessary "Calculating Audio Peeks" dialog with progress bar pop-up after changing Audio Gain.
      Steps to reproduce bug:
      1.Place some Long Audio Clip in a Sequence, let it be 1 hour
      2.Open Audio Gain Dialog
      3.Set Value for "Adjust Gain by" Editbox to 10 and hit OK
      Results:Every time a "Calculating Audio Peeks" Dialog with Progress Bar is opened
      Expected results:Instantly update peaks, like after setting value for the "Set Gain to" Editbox.
      Link: http://www.adobe.com/go/wish
        • 1. Re: Adjust Gain by... (CS6)
          Jim_Simon Level 8
          They just work differently.  I'm not seeing an issue here.
          • 2. Re: Adjust Gain by... (CS6)
            What is the difference between Instant vs Delayed functioning in your opinion?
            I'm rest assured that if on my systems there would be a Delay and on yours the same function would be Instant you would say offensively:
            Dude, you may want to wipe your system and reinstall everything from Windows on up.  You seem to be having a LOT of issues that I can't reproduce on two different systems.
            But when there's an obvious Program fault, you're saying inadequately that it's the way it should be, it's by design, it's just work differently, I'm not seeing an issue, etc.etc. Even Adobe Employees are not such an app defenders.
            Anyway, thanks for entering discussions, you are probably one of the most active participant on the forum.
            FYI, each of my described bugs have it's own workaround(s). But in most cases workarounds are slow. I start Discussions to confirm that I am not alone and the issue is Program-specific, no need to defend the app reputation. Current issue is solved by a macro script which uses it's own methods to alter Audio Gain by manipulating Premiere's Audio Gain Dialog Box.
            • 3. Re: Adjust Gain by... (CS6)
              TradeWind Level 3
              I guess I don't really understand the problem.
              When you say "change the gain from 0 to 5" the application doesn't have to think about it. When you say "adjust it by 5" it has to check the current peak gain on the clip and make a relative adjustment, not an absolute adjustment.
              Assuming I understand your bug correctly, I would tend to agree that once the peak gain level has been determined that no more adjustment is made. In that case, no further analysis (calculating) should be required, but the program may just be set to check it every time by default when a relative adjustment is being made.
              At any rate, hopefully I've explained why they DO work differently. As to whether or not it SHOULD in many cases, I guess that's a question Adobe developers will have to answer for you.
              • 4. Re: Adjust Gain by... (CS6)
                imho, a Calculation of %iCurrentGain% +5 should not invoke the Calculating Audio Peeks progress bar.
                exactly
                But why? It's needless. Could you imagine that after using a Clip Speed/Duration and setting a checkbox to Ripple Edit an unnecessary Calculating Ripple Edit, Shifting Trailing Clips progress bar dialog box would appear? Would you say in that case that the program may just be set to check the clips location every time by default when a ripple edit is being made?
                Looks like you are defending app's operation behaviour like Jim did.
                Hopefully in this Discussion.
                • 5. Re: Adjust Gain by... (CS6)
                  Jim_Simon Level 8
                  No, I'm just saying it appears to be the way it IS.  I'm not saying anything about the way it should be.  If you think it should be different, go ahead and file a feature request.
                  I just don't believe this is a bug, that the behavior you're seeing is the way it was designed to work.  I say this because I think it's important to file the proper form, in this case, a Feature Request.
                  • 6. Re: Adjust Gain by... (CS6)
                    This case is definitely cannot be a Feature Request and it is defenitely not a thought-out design of an app operation.
                    Can you assume that it's simply a mistakenly written code?
                    http://en.wikipedia.org/wiki/Software_bug
                    A software bug is the common term used to describe an error, flaw, mistake, failure, or fault
                    a mistake in program code is also considered as a bug
                    • 7. Re: Adjust Gain by... (CS6)
                      Jim_Simon Level 8
                      I suspect it's working as designed.  But only an Adobe engineer would know for sure.
                      • 8. Re: Adjust Gain by... (CS6)
                        When you will have an opportunity, try changing Audio Gain for a > 1 h long audio clip.
                        Simply type +1 in Adjust Gain by editbox, and then do the same thing, but use Set Gain to editbox. It's interesting that Set Gain to can be used in the same manner as Adjust Gain by.
                        Activate Adjust Gain by editbox, then press End and type +1. New Gain will be calculated in the same way as when typing relative values for Set Gain to, but with a difference - the change will be Instant, no Progress Bar.
                        • 9. Re: Adjust Gain by... (CS6)
                          [r]Evolution Level 1
                          I too have noticed and been irritated by this.
                          Although it is not the cure-all, I'm glad to have seen your discussion as it has altered my behavior to instead use Adjust Gain by.
                          • 10. Re: Adjust Gain by... (CS6)
                            Thanks for the feedback.
                            It's great that somebody can benefit from my manifests.
                            An Adobe engineer would just confirm a mistake in program code or, if you wish, not deliberately a function("Calculate Audio Peaks") is used in wrong place
                            • 11. Re: Adjust Gain by... (CS6)
                              Now I understand why this Dialog appears. A progress bar which shows a calculation of audio peaks is correct for multiple selected clips. But even in that case it's not obvious why it pop-ups for simple addition and subtraction math operations. Some code should be added to test whether a Single Audio Clip is selected - because when changing gain the change should be Instant at least for a single clip selection.
                              I've made the script that controls Audio Gain Dialog publicly available
                              https://sourceforge.net/projects/prpro6audiogain/
                              Download Link:
                              https://sourceforge.net/projects/prpro6audiogain/files/latest/download
                              Works only in CS6.
                              No installation is required. A System Tray icon will appear after starting the app and an ini file is created near the executable.
                              No need to invoke Audio Gain dialog.
                              By default a HotKey Alt+G is defined, but feel free to modify it in the ini file:
                              ^ - Ctrl
                              ! - Alt
                              + - Shift
                              # - Win
                              for example, ^+g is Ctrl+Shift+G
                              the Hotkey triggers only in Premiere Pro Window
                              Relative value cannot be set with Set Gain to for Multiple Clips, as a 0 dB value is shown when changing audio gain for multiple clips.
                              • 12. Re: Adjust Gain by... (CS6)
                                AkilW
                                It’s a good question for the reasons you've mentioned.  I suggest you go ahead and submit a bug.  The only cases where I'd expect  a progress bar is for the Normalize selections, which require an analysis pass on the selected waveform(s).  T
                                • 13. Re: Adjust Gain by... (CS6)
                                  Exactly, it's reasonable only for Audio Normalization, not for simply adding/subtracting Audio Gain Value(s).
                                  Each created discussion is automatically sent to
                                  but nobody replies
                                  • 14. Re: Adjust Gain by... (CS6)
                                    Are you tried the tool? Is it a good idea to develop such tools?
                                    • 15. Re: Adjust Gain by... (CS6)
                                      Kevin-Monahan Adobe Employee
                                      We had AkilW answer you in post #10: http://forums.adobe.com/message/4470380#4470380
                                      He is an audio specialist on the Premiere Pro team.
                                      If a bug was filed, you've done your best.
                                      Thanks.
                                      • 16. Re: Adjust Gain by... (CS6)
                                        It's great to know who is who
                                        Currently I know only:
                                        • Kevin Monahan - Help Files, Community (maybe more)
                                        • AkilW - Audio Specialist
                                        • 17. Re: Adjust Gain by... (CS6)
                                          Sure!
                                          I'm the Sr. Content and Community Lead. I'm mainly responsible for Help for After Effects, Premiere Pro, Media Encoder, and Prelude. I'm also responsible for the community, both online and in person. I do demos, create tutorials. write blogs, manage author relations, and evaluate statistics. My main job is simply to help people. I'm in a good position to do that as the founder of a prominent user group, an author, a trainer, and editor in San Francisco and Los Angeles.
                                          Akil is a quality engineer for the Premiere Pro team. He has a strong background in audio in Premiere Pro.
                                          • 18. Re: Adjust Gain by... (CS6)
                                            I'm just an editor since '99 with a huge loan for an apartment
                                            Pleased to meet you!
                                            You have quite a huge list of capabilities
                                            • 19. Re: Adjust Gain by... (CS6)
                                              Thank you. Pleased to meet you too. If you want to know more, here's my LinkedIn: http://www.linkedin.com/in/kevinjmonahan
                                              I've been editing bits of tape together since the early 80's.
                                              • 20. Re: Adjust Gain by... (CS6)
                                                Kevin, please take my respect
                                                • 21. Re: Adjust Gain by... (CS6)
                                                  Sure. I added you on LinkedIn.
