1 Reply Latest reply on Jun 4, 2012 9:34 AM by nw42
    Cannot import .mov file
    lipyo77
      I wish to import a .mov file into PremierePro CS5.5, but I get an error message saying "The file has no audio or video streams".  The same happens when I try to run this through Media Encoder 5.5.
      The file plays fine on VLC and Quicktime, so I'm pretty confident the correct codecs are installed, and I have the latest updates for all video software.
      The full media spec of the file is as follows:
      Video: MPEG-1/2 (xd5c), 1920x1080, 25fps, Planar 4:2:2 YUV
      Audio: PCM S24LE (42ni), stereo, 48kHz, 24 bits/sample
      Originated from Sony XDCAM H422 1080i50 (50Mb/s) - it was a .xmf but transcoded into .mov for use in FCP6/7 but now I want to run this (at home) on PPro 5.5.
      Operating System: Mac OSX 10.7.3.
      Please can I have a straight answer, rather than links to PC software or links that no longer exist.
      P
        • 1. Re: Cannot import .mov file
          nw42 Level 2
          Sony XDCAM as you said - original comes in an MXF container and is natively supported by Adobe Premiere.
          But If you put your footage on your Mac with FCP into a "special magical FCP XDCAM" that only a Mac with FCP installed can play - then you loose...
          1. You can transcode all your clips with FCP into Prores or DNXHD or something the rest of the world can read.
          2. I had a silimalr situation with footage from a client: A- I could read the 4 channel audio with Premiere and was able to transcode the video with FFMPEG comand line into something more compatible...
          hope this helps...
          nw42
