• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
jpeg saving opptions
New Here ,
Jun 04, 2012 Jun 04, 2012
When I save an image as a jpeg, there are three opptions: 1. Baseline Standard, 2. Baseline Optimised, 3. Progresive. Can anyone explain the differences apart from file size?
TOPICS
Import and export
Views
109.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 04, 2012 Jun 04, 2012
From the photoshop help manual:
In the JPEG Options dialog box, select the options you want, and click OK.
Matte
Offers matte color choices to simulate the appearance of background transparency in images that contain transparency.
Image Options
Specifies the image quality. Choose an option from the Quality menu, drag the Quality pop-up slider, or enter a value between 0 and 12 in the Quality text box.
Format Options
Specifies the format of your JPEG file. Baseline (“Standard”) uses a format recognize
Votes
Translate
Translate
Community Expert ,
Matte
Image Options
Format Options
Specifies the format of your JPEG file. Baseline (“Standard”) uses a format recognized by most web browsers. Baseline Optimized creates a file with optimized color and a slightly smaller file size. Progressive displays a series of increasingly detailed versions of the image (you specify how many) as it downloads. (Not all web browsers support optimized and Progressive JPEG images.)"
In my experience almost all browers people use now support the Baseline Optimized option, which is what i usually use if the jpeg is bound for the web.
Those format options don't really mean much if your not planning to use the jpeg on the web and you'll get even smaller file sizes by using File>Save for Web
Votes
Translate
Translate
Report
Report
Guest
The short answer is to use "Baseline (Optimized)" for saving JPG files.
The long answer(s) can be found by searching the Web for "baseline standard", but here's what you need to know about PSE's JPG saving options:
JPG is a "lossy" method of compressing image files -- it throws away image data before doing the compression, so set your "Quality" option to "Maximized". That is the key setting for image quality.
"Baseline (Optimized)" might reduce file size slightly (2% or so), and might be incompatible with viewers using old technology. "Optimized" might produce better colours, but that might not be perceptable.
"Progressive" means that the image is rendered as scan lines (like the old-fashioned TVs used) so that a browser will quickly show a reduced quality image of half the scan lines while it resolves the complete image.
Personally, I never use JPG -- each time a JPG is saved you lose more and more image data because of the lossy compression algorithms. I use PNG, which is lossless.
Ken
Votes
Translate
Translate
Report
Report
New Here ,
Thanks for the info, I've decided to use png myself after reading your posting. However, when saving the files it asks if I want to save interlaced or not... What does this mean?
Keith.
Votes
Translate
Translate
Report
Report
Guest
The same as that "Progressive" option for JPGs.  Use non-interlaced.
Ken
Votes
Translate
Translate
Report
Report
New Here ,
Jun 16, 2016 Jun 16, 2016
When saving jpegs in Photoshop as photos to print (and not to use on the web) what is the best format saving option here?
Votes
Translate
Translate
Report
Report
Community Expert ,
You should save the jpeg as a psd or tif.
Repeatedly saving a file as a jpeg reduces the image quality with each save because jpeg
uses compression to keep the file size small, but quality suffers because of the compression.
Jpeg is a destructive file format suited for the web or email.
Psd and tiff are non destructive, meaning the image quality doesn't deteriorate with each save.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Sep 29, 2016 Sep 29, 2016
Thanks for this thread I've learnt few things today. I have a question though.
Should I check the "Embed Color Profiie: sRGB IEC61966-2.1" box or keep it uncheck while saving as PSD, JPG or PNG or any other format.
Please see the attached image for better understanding.
Votes
Translate
Translate
Report
Report
Community Expert ,
Check Embed Color Profile
Votes
Translate
Translate
Report
Report
Thank you! Can you help me again about saving image as PNG. In the image below which option should I choose to get the best possible image for the web.
Thank you very much!
Votes
Translate
Translate
Report
Report
Community Expert ,
Rather than use File>Save As>PNG
Try File>Export>Export As or File>Export> Save for Web
With either of the above options, you have more choices to get the smallest png file size.
Using File>Save AS>PNG saves all the metadata, which can result in very large file sizes.
Votes
Translate
Translate
Report
Report
Okay but the problem is when I try to save the way you said Photoshop doesn't let me save it as the original Photoshop file size because of the large width & length. Is there anyway it can be resolved?
I've attached a screenshot below where the file size was shrunk to about 91%. The file's original size is 1920x8932 px.
Votes
Translate
Translate
Report
Report
Community Expert ,
You don't an image that big for posting on the web, do you?
Save for web has a limit to the file size it accepts.
For web posting, most people reduce the image size to something less than 1500 pixels on the long side.
Also, using jpeg for posting on the web is better, since the file size is way smaller than a png.
Votes
Translate
Translate
Report
Report
I actually do need to export big size images for clients to see how my templates are, which are usually 1920px wide. Those images shown in a websites, I'd like my images to be in best quality for viewing. In that case should I export as JPG or should I save it as PNG?
Votes
Translate
Translate
Report
Report
Community Expert ,
Sep 30, 2016 Sep 30, 2016
For both the png an jpeg try File>Export As
Then you can compare the file sizes and decide for yourself if one or the other is better, i.e., file size versus quality.
Png images of that size may take a longer than practical time to load on a web page, depending on how fast ones internet connection is.
Jpegs will be of lower quality, though maybe not so much as to notice, while pngs will be of the best quality, but much bigger file sizes.
Votes
Translate
Translate
Report
Report
Okay. Thank you very much!
Votes
Translate
Translate
Report
Report
Advocate ,
Oct 08, 2019 Oct 08, 2019
Your better off using save for Web. The save as command and using JPEG is horribly bad, it hardly makes any difference, even when setting it to low. When using Saves for Web, files will be about 60% smaller. Not sure why this is, it seems like the Saves JPEG method doesnt work properly.
What i do find strange is that i read there thinking of dropping the Sve for Web command, its very old and slow. Hope they come with a good alternative, because saves as is just not good in my opinion.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Save for Web strips the metadata unless specified otherwise, while save as>jpeg does not strip any metadata which can sometimes be quite large due to Ancestors Metadata and thus the different jpeg compression options seem to make little difference.
https://community.adobe.com/t5/Photoshop/Inflated-JPG-File-Size-Photoshop-Document-Ancestors-Metadat...
Votes
Translate
Translate
Report
Report
