37 Replies Latest reply on Jun 12, 2012 1:49 PM by areohbee
    Writing a plugin to create Smart Collections
    John Spacey Level 1
      Hi folks
      Is it possible to use the SDK to create a plugin that creates a Collection Set that contains a number of Smart collections.
      I'd also like to be able to select a Folder and have the plugin use the folder name as one of the parameters in the Smart collections and the title of the Collection Set
      Cheers in advance
        • 1. Re: Writing a plugin to create Smart Collections
          johnrellis Most Valuable Participant
          It should be straightforward.  In the LrCatalog class, see the methods catalog:createSmartCollection() and catalog:createCollectionSet().
          To find out which folder or folders are currently selected, see the method catalog:getActiveSources().
          • 2. Re: Writing a plugin to create Smart Collections
            areohbee Level 6
            You may be interested in:
            Folder Collections:
            http://www.robcole.com/Rob/ProductsAndServices/FolderCollectionsLrPlugin
            Download is source code format.
            It uses dumb collections because there is no way to have smart collection content match folder content - I got close using smart collections, but ultimately had to rely on dumb collections and a background task.
            Still, the original version used smart collections, and the code for it is still mostly in there...
            Cheers,
            Rob
            • 3. Re: Writing a plugin to create Smart Collections
              John Spacey Level 1
              thanks guys
              Yes it looks like it shouldn't be too difficult to get something up and running that meets my needs. I'm pretty experienced in PHP programming, but do need to learn LUA.
              • 4. Re: Writing a plugin to create Smart Collections
                areohbee Level 6
                The "closures" feature of Lua, among other things, makes it a delightful language to program with, in my opinion. - very simple, but very powerful - a shining example of good programming language design, in my opinion.
                Enjoy!
                Rob
                • 5. Re: Writing a plugin to create Smart Collections
                  John Spacey Level 1
                  Ok, I'm admitting defeat at an early stage ...
                  I think I've managed to return the array of selected sources from catalog:getActiveSources()
                  However I can't find any documentation on the actual structure of this array or how to access it
                  The docs for catalog:getActiveSources() say
                  Returned:
                  (array of LrCollection, LrCollectionSet, LrPublishedCollection, LrPublishedCollectionSet or LrFolder)
                  • 6. Re: Writing a plugin to create Smart Collections
                    Don McKee
                    Hi John,
                    Try something like this:
                    local sources = catalog:getActiveSources()
                    for _notUsed, source in ipairs(sources) do
                        if source:type() == 'LrCollection' then
                           -- do something
                        elseif source:type() == 'LrCollectionSet' then
                           -- do something
                        elseif source:type() == 'LrPublishedCollection' then
                           -- do something
                        elseif source:type() == 'LrPublishedCollectionSet' then
                           -- do something
                        elseif source:type() == 'LrFolder' then
                           -- do something
                        end
                    end
                    Does this help?
                    -Don
                    • 7. Re: Writing a plugin to create Smart Collections
                      John Spacey Level 1
                      Thanks Don, that helps enormously.   I'm still having trouble extracting the source names though.  Guessing from source:type() I tried getting the names by trying source:name() or source:title() but it didn't work.   Sorry about these possibly dumb questions, but I can't find any documentation on the structure of the array.
                      • 8. Re: Writing a plugin to create Smart Collections
                        Don McKee Level 1
                        Hi John,
                        The array is just a Lua array (e.g. sources[1], sources[2], ...) that, according to the Lightroom SDK doc contains one of the listed objects.  Also referring to the SDK doc for the objects, they all have a "getName()" method.  Is that what you're looking for?
                        -Don
                        • 9. Re: Writing a plugin to create Smart Collections
                          John Spacey Level 1
                          Ahh getName()
                          I  tried this by inserting  sourceName = source:getName() in your code abvoe @  -- do something and I got the followimg error
                          "An internal error has occoured: We can only wait from within a task"
                          • 10. Re: Writing a plugin to create Smart Collections
                            Don McKee Level 1
                            What object were you looking at?  For example, the LrPublishedCollection's getName() method documentation includes:
                            This function must be called from within an asynchronous task started using LrTasks.
                            Did you do that?
                            -Don
                            • 11. Re: Writing a plugin to create Smart Collections
                              John Spacey Level 1
                              I was looking at the object LrFolder in the returned array
                              I tried to get the name of the selected folder like this:
                                  end
                              /Adobe Lightroom 4 SDK/API Reference/modules/LrFolder.html#folder:getName
                              which says:
                              folder:getName() Retrieves the name of this folder.
                              First supported in version 3.0 of the Lightroom SDK.
                              Return value
                              (string) The name.
                              and mentions nothing about 'an asynchronous task started using LrTasks.' whatever that is
                              Stumped
                              • 12. Re: Writing a plugin to create Smart Collections
                                areohbee Level 6
                                Lots of stuff only works in an asynchronous task.
                                The first thing I do in response to a menu or button is create an asynchronous task to process it, with an error handler attached to the processing context (LrFunctionContext).
                                That way, I never have to worry about something needing to be done from an asynchronous task, because *everything* is being done from an asynchronous task.
                                If you want to make sure another instance of the task doesn't get started before the other is finished, you can use recursion guarding.
                                I don't use the LrRecursionGuard, but it's one possibility.
                                Rob
                                • 13. Re: Writing a plugin to create Smart Collections
                                  John Spacey Level 1
                                  Where can I learn about how to create an asyncronous task?
                                  This is where I am at so far. I'm able to show a dialog box that lists the types of active sources
                                  https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/543743_424084167624887_174437144_n.jpg
                                  I modified one of the SDK programmers guide tutorials thus:
                                  ShowSources.lua
                                  local LrFunctionContext = import 'LrFunctionContext'
                                  local LrBinding = import 'LrBinding'
                                  local LrDialogs = import 'LrDialogs'
                                  local LrView = import 'LrView'
                                  local LrColor = import 'LrColor'
                                  local LrTasks = import 'LrTasks'
                                  local LrApplication = import 'LrApplication'
                                  MyHWLibraryItem = {}
                                  -- function to interrogate active sources array
                                  function read_activeSources_array( sources )
                                      source_type = "Active Sources:\n"
                                          for i, source in ipairs( sources ) do
                                                  source_type = source_type .. i .. " is a Collection\n"
                                                  source_type = source_type .. i .. " is a folder\n"
                                              end
                                              --local sourceName = source:getName()    -- this produces ***ERROR***
                                          end
                                          return source_type
                                  end
                                  -- ***ERROR*** "An internal error has occoured: We can only wait from within a task"
                                  function MyHWLibraryItem.showCustomDialog()
                                  -- body of show-dialog function
                                  LrFunctionContext.callWithContext( "ShowSources",
                                      function( context )
                                          catalog = LrApplication.activeCatalog()
                                          local path = catalog:getPath()
                                          --string = LrTasks.startAsyncTask( read_activeSources_array( sources ) )
                                          display_string = read_activeSources_array( sources )
                                      -- create view hierarchy for dialog box
                                      local f = LrView.osFactory() -- get the view factory object
                                      local c = f:column { -- the root node
                                          f:row { -- Display contents of active sources Array
                                              f:static_text {
                                                  text_color = LrColor( 0, 0, 1 ),
                                                  alignment = "Left",
                                                  -- add title with binding later
                                                  title = display_string
                                      local result = LrDialogs.presentModalDialog(
                                          title = "Show Sources",
                                          contents = c, -- the view hierarchy we defined
                                      end )
                                  end
                                  • 14. Re: Writing a plugin to create Smart Collections
                                    areohbee Level 6
                                    LrFunctionContext.postAsyncTaskWithContext is my personal favorite, since you can create the task and the processing context in one swipe that way.
                                    Put that at the outermost level.
                                    Then assign a cleanup, or error handler to the context, so errors don't just silently abort, or at least that's what used to happen to button handlers, unless Adobe changed that in Lr4 (I haven't checked).
                                    I simply check/set a variable upon entry, then clear it in the cleanup handler to implement recursion guarding, which I have rolled into a set of classes which I use in my plugin framework.
                                    You can see said framework (elare plugin framework) in any of my plugins (e.g. http://www.robcole.com/Rob/ProductsAndServices), all of which include source code, and you can use the framework by going here:
                                    https://www.assembla.com/spaces/lrdevplugin/
                                    R
                                    • 15. Re: Writing a plugin to create Smart Collections
                                      Don McKee Level 1
                                      From the sample plug-ins included with the SDK, and the SDK doc.  But, basically,
                                      LrTasks.startAsyncTask(function()
                                      end)
                                      would run all of your code in a task.
                                      -Don
                                      • 16. Re: Writing a plugin to create Smart Collections
                                        Don McKee Level 1
                                        Oh, and what Rob said.
                                        -Don
                                        • 17. Re: Writing a plugin to create Smart Collections
                                          areohbee Level 6
                                          Yeah, - what Don said too.
                                          Just remember that recursion guarding can become an issue when everything is done asynchronously, since impatient users or those with twitchy fingers may get 3 or 4 of the same things going at once if not careful. Obviously, if there isn't enough time to click twice before the first/next (modal) dialog box comes up..., it's a non-problem. But if processing takes more than a fraction of a second...  (Next up: LrProgressScope...).
                                          Also, tasks don't abort when reloading the plugin, until they're finished, *if* they finish. It's possible to have multiple instances of the same task running with different environments...
                                          I use LrShutdownPlugin to set a global shutdown flag and check it in async loops, so plugin reloads happen gracefully. (I wish LrTasks.sleep would automatically return a code upon a plugin reload / shutdown (like java...), but since it doesn't, I implemented my own sleeper in the framework).
                                          PS - There is some new shutdown handling which I've yet to investigate. Since it would be ignored in Lr3, it's hardly worth using unless plugin is Lr4 only.
                                          My apology in advance if this is too much too soon - maybe return to this thread and re-read if you start having problems...
                                          Also, as Obewankanobee said: read the docs, Luke...
                                          Rob
                                          • 18. Re: Writing a plugin to create Smart Collections
                                            John Spacey Level 1
                                            HURRAH! You guys Rock! Thanks ever so much. https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/481157_424096430956994_427450149_n.jpg
                                            I did
                                            end)
                                            And then modified my function to
                                                            source_type = source_type .. i .. " is a Collection called " .. sourceName .. "\n"
                                                            source_type = source_type .. i .. " is a folder called " .. sourceName .. "\n"
                                                            --source_type = source_type .. sourceName .."\n"
                                                        end
                                                    end
                                                    return source_type
                                            end
                                            Rob, errors seem pretty verbose in LR4.1 when something has gone wrong an error dialog appears everytime on the cide I've been mangling
                                            I've bookmarked your site and the assembla site
                                            Thanks again peeps
                                            • 19. Re: Writing a plugin to create Smart Collections
                                              John Spacey Level 1
                                              Rob
                                              Cheers Rob
                                              I am reading the docs as much as possible. I'm not finding them that intuitive to be honest, but I am trying to source the answers myself before coming here and shouting 'Help!      I hadn't even heard of LUA a few days ago so it is a bit of a jump in the deep end
                                              • 20. Re: Writing a plugin to create Smart Collections
                                                areohbee Level 6
                                                Thanks again peeps
                                                Congrats, and you're welcome.
                                                In some cases, Lightroom provides the error handling, in other cases - it doesn't.
                                                I no longer remember which cases it does, and which cases it doesn't, since I always provide my own.
                                                One case I do remember is button handlers. You *must* handle errors in button handlers or they will just silently malfunction, or at least that's true for Lr3-.
                                                Oh yeah, change handlers (ui property observers) and ui validator functions are 2 more cases that need error handlers (unless you don't mind silent failure upon error).
                                                R
                                                • 21. Re: Writing a plugin to create Smart Collections
                                                  areohbee Level 6
                                                  John Spacey wrote:
                                                  Cheers Rob
                                                  Hi John,
                                                  Yeah, the docs are perhaps best digested along with a big dose of experience.
                                                  Enjoy (I think Lua is great).
                                                  Rob
                                                  • 22. Re: Writing a plugin to create Smart Collections
                                                    John Spacey Level 1
                                                    Right tonight's takst is to come up with a routine to create collection sets and collections based upon those fodler names. I shall go and digest as much documentionation as possible before shouting for help
                                                    • 23. Re: Writing a plugin to create Smart Collections
                                                      John Spacey Level 1
                                                      Excellent! On a roll tonight. Managed to create a collection set containing a number of Smart collections!   Only issue I have now is finding an existing collection set of a known name and using that as a parent to the newly created collection set.
                                                      • 24. Re: Writing a plugin to create Smart Collections
                                                        areohbee Level 6
                                                        I have a number of plugins that deal with collections which may have some good example source code:
                                                        FolderCollections
                                                        CollectionAgent
                                                        Stacker
                                                        SQLiteroom
                                                        LrFourB
                                                        PublishServiceAssistant
                                                        R
                                                        • 25. Re: Writing a plugin to create Smart Collections
                                                          John Spacey Level 1
                                                          Thanks Rob
                                                          I've already had a look in your FolderCollections.lua and there was some helpful code in there I'll check out the others soon
                                                          tongiht I've written a recursive function that gets an activeSource's parent and then gets the parent's parent, and so on until the 'root' is reached. The recursive function adds the succesive parents to an Array. ( a table in LUA speak I believe )
                                                          -- Function to create array of folder of collection parental structure
                                                          function MyHWLibraryItem.CreateParentStructure( source, parent_table,  x )
        local source_parent = source:getParent()
        --add to parent table ( array )
        parent_table[x] = source_parent
        if parent_table[x] ~= nil then -- parent exists
        x=x+1
        -- call itself to interrogate further up the parent branch
        parent_table = MyHWLibraryItem.CreateParentStructure( source_parent, parent_table,  x )
        else -- parent doesn't exist - top of branch
        parent_table[x] = false
        end
        return parent_table
                                                          end
                                                          Interesting to note that I couldn't get this to work until I realised I couldn't assign an element of the array a value of "nil" ( which is returned when getParent() finds no parent ) and had to assign it a value of 'false' instead.
                                                          I think your Folder Collections plug deals with recreating path structures so I'll take another look at that shortly
                                                          • 26. Re: Writing a plugin to create Smart Collections
                                                            areohbee Level 6
                                                            Looks good John.
                                                            A couple lua-y things to note:
                                                            You can assign nil to an array, but:
                                                            * ipairs stops on the first nil.
                                                            * #tbl counts items (at positive integer indexes) up unitl the last nil.
                                                            I mean, assigning non-nil values (e.g. false) is probably the preferred approach in this case, but just so ya know:
                                                            #{ x=1 } == 0 -- is true
                                                            #{ 1, nil, 3 } == 3 -- true too
                                                            #{ 1, nil } == 1 -- also true
                                                            #{ x=1, 2 } == 1 -- true
                                                            { x=1, 2 }[1] == 2 -- true
                                                            local x = {}
                                                            x[0] = 1
                                                            #x == 0 -- true
                                                            for i,v in ipairs{ 1, nil, 3 } do
        local nothing = 1 -- executes only once
                                                            end
                                                            R
                                                            • 27. Re: Writing a plugin to create Smart Collections
                                                              John Spacey Level 1
                                                              Cheers Rob very helpful
                                                              • 28. Re: Writing a plugin to create Smart Collections
        John Spacey Level 1
        Hi peeps.
        Just about finished. Seems to be working OK. Just gotta tidy up the dialog box. I'll post the code when done.
        • 29. Re: Writing a plugin to create Smart Collections
        areohbee Level 6
        Standing by... (thanks).
        R
        • 30. Re: Writing a plugin to create Smart Collections
        John Spacey Level 1
        Here ya go - A huge thanks to you chaps for all your help!.
        local LrLogger = import 'LrLogger'
        local myLogger = LrLogger( 'libraryLogger' )
        myLogger:enable( "logfile" ) -- or "print"
        -- Logger function
        function MyHWLibraryItem.outputToLog( message )
        myLogger:trace( message )
        end
        -- Function to extract names from parent table
        function MyHWLibraryItem.Path_String_From_Parent_Table( parent_table )
        -- stuff goes in here
        local path_string =""
        for y, source in ipairs( parent_table ) do
        if source ~= false then
        parent = source:getName()
        else
        parent = "ROOT"
        end
        if y == #parent_table then
        path_string = path_string .. parent .. "/.."
        else
        path_string = path_string .. parent .. "/"
        end
        end
        return path_string
        end
        x=x+1
        end
        return  parent_table
        end
        function( context )
        local source_type
        local source_name
        local source_parent
        local source_parent_name
        local collection_set
        --local folders = catalog:getFolders()
        source_type = "Active Sources:\n***********\n\n"
        -- analyse source table
        -- Create table for parent structure of source
        local parent_table = {}
        source_name = source:getName()
        x=1 -- init counter for parent table
        -- call recursive function
        parent_table = MyHWLibraryItem.CreateParentStructure( source, parent_table, x )
        -- now reverse the parent table
        local y=1
        local z = #parent_table
        local parent_table_rev = {} -- create empty rev table
        for a = z , 1, -1 do
        parent_table_rev[y] = parent_table[z]
        y=y+1    z=z-1
        end
        parent_table = parent_table_rev
        -- end reverse parent table
        -- create path string from parent_table
        source_parent_name = MyHWLibraryItem.Path_String_From_Parent_Table( parent_table )
        local name_and_parent_display = "\"" .. source_name .. "\" \n          Parent(s) = " .. source_parent_name .."\n"
        smart_coll_report = ""
        -- ********* CREATE COLLECTION SETS and SMART COLLECTIONS *****************
        -- create collection set hierarchy
        for i = 1, #parent_table do
        MyHWLibraryItem.outputToLog( "STEP = " .. i )
        if i==1 then -- root
        --do nothing
        else
        --create collection set
        if parent_table[i-1] == false then
        MyHWLibraryItem.outputToLog( "parent table = FALSE." )
        parent = nil
        else
        --parent = parent_table[i-1]
        MyHWLibraryItem.outputToLog( "parent name = " .. parent:getName() )
        end
        catalog:withWriteAccessDo( "Create Collection Set 2" , function( context )
        parent = catalog:createCollectionSet( parent_table[i]:getName() , parent , true )
        end)
        MyHWLibraryItem.outputToLog( "collection set created. Name = " .. parent:getName() )
        end
        end
        catalog:withWriteAccessDo( "Create Collection Set 1" , function( context )
        -- Create new collection set
        collection_set = catalog:createCollectionSet( source_name , parent )
        if collection_set ~= nil then
        smart_coll_report = smart_coll_report .. "               Collection Set '"..source_name.."' created OK\n"
        else
        smart_coll_report = smart_coll_report .. "               Collection Set '"..source_name.."' ALREADY EXISTS!\n"
        end
        -- create Smart Collections for ratings
        local smart_collection_set_1 = catalog:createSmartCollection( "<2", {{criteria="rating",operation="<",value=2},{criteria="folder",operation="all",value=sourc e_name}}, collection_set )
        local smart_collection_set_2 = catalog:createSmartCollection( "2+", {{criteria="rating",operation=">=",value=2},{criteria="folder",operation="all",value=sour ce_name}}, collection_set )
        local smart_collection_set_3 = catalog:createSmartCollection( "3+", {{criteria="rating",operation=">=",value=3},{criteria="folder",operation="all",value=sour ce_name}}, collection_set )
        local smart_collection_set_4 = catalog:createSmartCollection( "4+", {{criteria="rating",operation=">=",value=4},{criteria="folder",operation="all",value=sour ce_name}}, collection_set )
        if smart_collection_set_1 ~= nil then smart_coll_report = smart_coll_report .. "               Smart Collection '<2' created OK\n" end
        if smart_collection_set_2 ~= nil then smart_coll_report = smart_coll_report .. "               Smart Collection '2+' created OK\n" end
        if smart_collection_set_3 ~= nil then smart_coll_report = smart_coll_report .. "               Smart Collection '3+' created OK\n" end
        if smart_collection_set_4 ~= nil then smart_coll_report = smart_coll_report .. "               Smart Collection '4+' created OK\n" end
        end
        end ) -- end of catalog:withWriteAccessDo FUNCTION
        -- create display string
        source_type = source_type .. i .. " Folder: " .. name_and_parent_display .. smart_coll_report .. "\n"
        source_type = source_type .. i .. " Collection Set: " .. name_and_parent_display  .. smart_coll_report .. "\n"
        elseif source:type() == 'LrCollection'  then
        source_type = source_type .. i .. " Collection: " .. name_and_parent_display .. smart_coll_report .. "\n"
        source_type = source_type .. i .. " Published Collection: " .. name_and_parent_display .. smart_coll_report .. "\n"
        source_type = source_type .. i .. " Published Collection Set: " .. name_and_parent_display .. smart_coll_report .. "\n"
        end
        end
        display_string = source_type
        f:static_text {
        text_color = LrColor( 0, 0, 0 ),
        alignment = "Left",
        title = "Create Rating Smart Collection Sets",
        end )
        end
        end)
        • 31. Re: Writing a plugin to create Smart Collections
        areohbee Level 6
        Looks good, but I wrapped it in a plugin and tried it, and I can't tell what happened (couldn't find any new collections, nor was there a UI message presented (after I approved the initial prompt I mean), nor any logged messages). I'm not sure what was supposed to happen.
        R
        • 32. Re: Writing a plugin to create Smart Collections
        John Spacey Level 1
        Hmmm interesting. Works fine here ....
        What should happen is for any sources you select the routine will create an identical structure of collection sets and smart collections based upon ratings of pics in those sources as:
        local smart_collection_set_1 = catalog:createSmartCollection( "<2", {{criteria="rating",operation="<",value=2},{criteria="folder",operati on="all",value=source_name}}, collection_set )
        local smart_collection_set_2 = catalog:createSmartCollection( "2+", {{criteria="rating",operation=">=",value=2},{criteria="folder",operat ion="all",value=source_name}}, collection_set )
        local smart_collection_set_3 = catalog:createSmartCollection( "3+", {{criteria="rating",operation=">=",value=3},{criteria="folder",operat ion="all",value=source_name}}, collection_set )
        local smart_collection_set_4 = catalog:createSmartCollection( "4+", {{criteria="rating",operation=">=",value=4},{criteria="folder",operat ion="all",value=source_name}}, collection_set )
        So for the red ticked slected folder source Dubau LR then the red encircled collection set/smart collection structure is created:
        https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/523608_426639240702713_216228329_n.jpg
        • 33. Re: Writing a plugin to create Smart Collections
        areohbee Level 6
        I tried it using a folder source and it worked. Previous test was using a collection as source.
        Unfortunately, for me, the smart collection folder criteria casts too wide a net (sometimes includes photos from other folders). Same will be true for other users. This is why I changed FolderCollections to use dumb collections instead - there is no way to reliably define smart collection criteria to limit photos to those of a single corresponding folder, or at least no way that John Ellis or I could figure.
        Otherwise, nice job!
        Cheers,
        Rob
        • 34. Re: Writing a plugin to create Smart Collections
        John Spacey Level 1
        Thanks Rob.
        [i]"there is no way to reliably define smart collection criteria to limit photos to those of a single corresponding folder,"[/i]
        In my working catalogues ( not the test catalogue shown in the screenshots ) all my folders have unique names starting with the Date and then a 2 digit number ( for multiple shoots on the same day ). then a decription   i.e  yyyy-mm-dd_xx_description
        And then using smart collections which with a rule:  "Folder -> Contains All - > yyyy-mm-dd_xx_description" you always ensure you only get photos from that folder
        • 35. Re: Writing a plugin to create Smart Collections
        areohbee Level 6
        Right-o: unique folder names will do it. And, I may resort to unique folder names at some point, just for this reason (assuming Adobe does not robusten the SDK enough come Lr5). Just thought you should know, in case you plan on making this plugin available to others...
        Cheers,
        Rob
        • 36. Re: Writing a plugin to create Smart Collections
        John Spacey Level 1
        It would be nice if the Object ID of the folder was available to Smart Collections.   After all this would allow the user to rename a folder and without hving to rename any relevantSmart collection rules
