1 Reply Latest reply on Jun 12, 2012 8:21 AM by robopenguin
      • 1. Re: How do I increase the left margin in the TOC?
        robopenguin
        You could check Rick Stone's Skinny on Skins file and see if it is mentioned in there.
        If not, you could try the steps below. I don't know if this is the best way to do it, but it does appear to work:
        1. After generating webhelp, go to the output folder, and then open the whtdhtml.htm file in a text editor.
        2. Find the following line of text:
                  <body topmargin="2" leftmargin="2" marginwidth="0" marginheight="0" bgproperties="fixed" bgcolor="white" scroll="auto">
        1. Change the value of the leftmargin property to a larger number. For example, leftmargin="10".
        2. Save the file.
        3. View your webhelp.
        Note that your changes will get overwritten when you next generate webhelp.
