2 Replies Latest reply on Jun 5, 2012 12:42 AM by paule82
    Access BorderContainer in NavigatorContent
    paule82
      I have the following (simplified) structure:
      <s:NavigatorContent id="profileContent" label="{detailsProfile.label}" width="100%" height="100%">
                      <s:BorderContainer id="bprofileContent" name="bprofileContent" width="100%" height="100%" cornerRadius="3" borderWeight="1" dropShadowVisible="true">
                          <detailsmodify:MusicServiceDetailsProfile id="detailsProfile" isOverrideListNecessary="false"
        readOnly="{_isReadOnly}"/>
                      </s:BorderContainer>
                  </s:NavigatorContent>
      How can I access the BorderContainer or even better the UI component (MusicServiceDetailsProfile)? I tried different ways:
      profileContent.getChildByName("...") -> name of BorderContainer or UI component returns null
      profileContent.contentGroup.getChildByName("...") -> name of BorderContainer or UI component returns null
      var borderContainer:BorderContainer = navigatorContent.getElementAt(0) as BorderContainer; -> IndexOutOfBoundsException
      Does anybody know how to acces one of the two nested components?
      Thanks a lot in advance!!
        • 1. Re: Access BorderContainer in NavigatorContent
          Matt LeGrand
          Hey Paul,
          You're on the right track.  The contentGroup is a spark Group.  So use the getElementAt method and you've got it.  Code should look like this:
          var bc:BorderContainer = profileContent.contentGroup.getElementAt(0) as BorderContainer;
          var ui:UIComponent = bc.getElementAt(0) as UIComponent;  // or this could be MusicServiceDetailsProfile
          // And you could use this to set a style or something cooler.
          bc.setStyle('backgroundColor', 0x00FF00);
          Hope this helps,
          Matt
          • 2. Re: Access BorderContainer in NavigatorContent
            paule82 Level 1
            Hi Matt,
            thanks for your response.
            But unfortunately I already tried this and I get the following exception:
            [Fault] exception, information=RangeError: Index 0 is out of range.
            at spark.components::Group/checkForRangeError()
            at spark.components::Group/getElementAt()
            It can't be so difficult to get the nested elements but I can't figure out how to do it ...
