5 Replies Latest reply on Jun 5, 2012 1:48 PM by Matthew.Fry
    Possible to export text to .wcml format?
    Matthew.Fry Level 1
      I have found several different scripts for exporting text from an InDesign page into .txt, .rtf and .doc. I am wondering if it is possible to export text to a .wcml format.
        • 1. Re: Possible to export text to .wcml format?
          These scripts do nothing else than call on InDesign's built-in export capabilities. Since it has no filter for "wcml", there is nothing existing to call upon.
          Perhaps you could write your own, if it's a basic text based format, but Googling brings up "West Coast Main Line" and "WCML FM", so if it's either a railroad format or some music file, you're out of luck.
          • 2. Re: Possible to export text to .wcml format?
            Dirk Becker Level 4
            If I remember that correctly, wcml is just WoodWing's brew of icml.
            Dirk
            • 3. Re: Possible to export text to .wcml format?
              Larry G. Schneider Adobe Community Professional & MVP
              My search brought this
              • 4. Re: Possible to export text to .wcml format?
                Loic.Aigon Adobe Community Professional
                I am happy to see I wasn't the only one confused with the google results on WCML
                • 5. Re: Possible to export text to .wcml format?
                  Matthew.Fry Level 1
                  We are using WoodWing's Content Station and Smart Connection.
                  We recently lost several months worth of articles from the system. So I am pulling articles off of the InDesign pages using the script listed below (ExportAllText.jsx), which exports all of the text from the page to either a .txt or .rft document. Since our articles in WoodWing are .wcml, I was hoping I could export the text in this format.
                  There are 2 modifications I would like to make on the script:
                  1. I want to name the exported text file the same name of the InDesign page (example: vds-06.04-a1) instead of having to input a name each time.
                  2. I want to do away with the dialog box and set it to export to .txt (or .wcml) and add the separator line.
                  Thanks.
                  if(app.documents.length != 0){
                            if(app.documents.item(0).stories.length != 0){
                                      myGetFileName(app.documents.item(0).name);
                  //========================= FUNCTIONS ===========================
                  function myGetFileName(myDocumentName){
                            var myFilePath = File.saveDialog("Save Exported File As:");
                            if(myFilePath != null){
                                      myDisplayDialog(myDocumentName, myFilePath);
                  function myDisplayDialog(myDocumentName, myFilePath){
                            //Need to get export format, story separator.
                            var myExportFormats = ["RTF", "Tagged Text", "Text Only"];
                            var myDialog = app.dialogs.add({name:"ExportAllStories"});
                            with(myDialog.dialogColumns.add()){
                                      with(dialogRows.add()){
                                                with(dialogColumns.add()){
                                                          var myExportFormatDropdown = dropdowns.add({stringList:myExportFormats, selectedIndex:0});
                                                var myAddSeparatorCheckbox = checkboxControls.add({staticLabel:"Add separator line", checkedState:true});
                            var myResult = myDialog.show();
                            if(myResult == true){
                                      var myExportFormat = myExportFormats[myExportFormatDropdown.selectedIndex];
                                      var myAddSeparator = myAddSeparatorCheckbox.checkedState;
                                      myDialog.destroy();
                                      myExportAllText(myDocumentName, myFilePath, myExportFormat, myAddSeparator);
                            else{
                                      myDialog.destroy();
                  function myExportAllText(myDocumentName, myFilePath, myExportFormat, myAddSeparator){
                            var myPage, myStory;
                            var myExportedStories = [];
                            var myTempFolder = Folder.temp;
                            var myTempFile = File(myTempFolder + "/tempTextFile.txt");
                            var myNewDocument = app.documents.add();
                            var myDocument = app.documents.item(myDocumentName);
                            var myTextFrame = myNewDocument.pages.item(0).textFrames.add({geometricBounds:myGetBounds(myNewDocument, myNewDocument.pages.item(0))});
                            var myNewStory = myTextFrame.parentStory;
                            for (var i = 0; i < myDocument.pages.length; i++) {
                                      myPage = myDocument.pages.item(i);
                                      for (var t = 0; t < myPage.textFrames.length; t++){
                                                myStory = myPage.textFrames[t].parentStory;
                                                if (!IsInArray(myStory.id, myExportedStories)) {
                                                          //Export the story as tagged text.
                                                          myStory.exportFile(ExportFormat.taggedText, myTempFile);
                                                          myExportedStories.push(myStory.id);
                                                          //Import (place) the file at the end of the temporary story.
                                                          myNewStory.insertionPoints.item(-1).place(myTempFile);
                                                          //If the imported text did not end with a return, enter a return
                                                          //to keep the stories from running together.
                                                          if(i != myDocument.stories.length -1){
        if(myNewStory.characters.item(-1).contents != "\r"){
        myNewStory.insertionPoints.item(-1).contents = "\r";
        if(myAddSeparator == true){
        myNewStory.insertionPoints.item(-1).contents = "----------------------------------------\r";
                                                } // if not exported
                                      } // for text frames
                            } // for pages
                            switch(myExportFormat){
                                      case "Text Only":
                                                myFormat = ExportFormat.textType;
                                                myExtension = ".txt"
                                                break;
                                      case "RTF":
                                                myFormat = ExportFormat.RTF;
                                                myExtension = ".rtf"
                                                break;
                                      case "Tagged Text":
                                                myFormat = ExportFormat.taggedText;
                                                break;
                            myNewStory.exportFile(myFormat, File(myFilePath));
                            myNewDocument.close(SaveOptions.no);
                            myTempFile.remove();
                  function myGetBounds(myDocument, myPage){
                            var myPageWidth = myDocument.documentPreferences.pageWidth;
                            var myPageHeight = myDocument.documentPreferences.pageHeight
                            if(myPage.side == PageSideOptions.leftHand){
                                      var myX2 = myPage.marginPreferences.left;
                                      var myX1 = myPage.marginPreferences.right;
                            else{
                                      var myX1 = myPage.marginPreferences.left;
                                      var myX2 = myPage.marginPreferences.right;
                            var myY1 = myPage.marginPreferences.top;
                            var myX2 = myPageWidth - myX2;
                            var myY2 = myPageHeight - myPage.marginPreferences.bottom;
                            return [myY1, myX1, myY2, myX2];
                  function IsInArray(myString, myArray) {
                            for (x in myArray) {
                                      if (myString == myArray[x]) {
                                                return true;
                            return false;
