5 Replies Latest reply on Apr 12, 2018 5:04 AM by Homeboy
    Change Lasso Tool Points
    Lilsilly
      I want to fine adjust the selections done with the Lasso Tools but can not find out how to do it.
      I imagine that I can select the create points and manipulate them. Am I dreaming?
      Help much appreciated.
        • 1. Re: Change Lasso Tool Points
          HowardPinsky Level 4
          You're able to adjust paths that were created using the Pen Tool, but because the Lasso tools do not create vector shapes/paths, there are no points. You can, however, use the add/subtract options on your Options Bar to modify a current selection.
          • 2. Re: Change Lasso Tool Points
            Lilsilly Level 1
            Thanks Howard Pinsky for your quick response.
            While creating the selection with the Lasso tool it looks like it creates vector points.
            That's bad if it does not.
            I have used the add/subtract option and it is not much to my liking.
            Is there another way to create a selection as a vector shape? How can I do it with the pen tool? I cn drwa with the penciI tool but can not see how to manipulate the pencil tool either and the help menue is of no help.
            • 3. Re: Change Lasso Tool Points
              the_wine_snob Level 9
              To fine-tune a Selection, whether created with the Lasso, the Magnetic Lasso, etc., just go to the Paths Palette, and look for the little "arrowhead in a circle," to open up the Paths Options. Select Make Work Path, set the Threshold, and you have a Path, from that Selection. Using the Add/Subtract Tool (expand the Pen Tool to see all the options), you can tweak, as much as wish.
              If you then wish to go back to a Selection, use that same Options menu to Make Selection.
              I use this workflow constantly, as I will use a Selection Tool to "rough in" the Selection, convert that to a Path, and with the magnification pretty high, refine that with the Pen Tools (and its variations).
              • 4. Re: Change Lasso Tool Points
                Lilsilly Level 1
                Hi Bill Hunt,
                I can follow your great instructions and I can see what you mean. I do it similar in Xara.  However, I can not find the Path Pallette or any "arrowhead in a circle".
                Any help welcome, thanks.
                • 5. Re: Change Lasso Tool Points
                  Homeboy Level 1
                  Unfortunately, selecting the Options Bar "New", "Add to Selection" icons don't let me correct the parts that don't adhere to the desired object. Each option makes new line points.
                  All I want to do is move the incorrect parts so they abut nicely as the rest of the outline I've drawn.
