5 Replies Latest reply on Jun 6, 2012 12:51 PM by Golferguy08
    authorizing computer
    madmacs80
      how do you authorize your computers for ereaders after downloading the Adobe Digital software?
      I downloaded it then hit continue, but didn't get any place to set up computer for downloading books, can anyone help me?
        • 1. Re: authorizing computer
          Jeff A Wright Adobe Employee
          Moving this discussion to the Adobe Digital Editions forum.
          • 2. Re: authorizing computer
            Level 4
            It's kind of the other way.
            Once you've registered with Adobe and then installed ADE on your computer,
            it's ready to go.
            When you get an ereader, then you have to go to their website and register
            it with them.  That process puts a small ID file on the ereader, which ADE
            will use.  It makes it much easier if you use your Adobe ID when you
            register the ereader.
            ADE will recognize ereaders 'automagically' - you don't need to do anything
            to ADE to tell it you have an ereader.  Just plug the ereader into your
            computer and make sure your computer finds it and shows it - usually as an
            external hard drive.  Then, start ADE.  Your ereader should show up on the
            bookshelf, which is the left hand panel of the Library view screen.  You
            then can transfer ebooks to it by dragging the title and dropping it onto
            the ereader.
            Things to look for: make sure your ereader is supported by ADE.  Kindles
            are not, along with a bunch of 'generic' ereaders, Android tablets, phones
            and Apple products.  THIS
            LINK<http://blogs.adobe.com/digitalpublishing/supported-devices> will
            take you to the list of supported devices.  Also, when you go to disconnect
            your ereader, use your computer's routines for 'ejecting' the ereader, such
            as Windows 'Safely Remove Hardware' icon on the START bar.  Then, don't
            pull the plug until your ereader says it's finished updating its content.
            Hope this helps!
            • 3. Re: authorizing computer
              Golferguy08
              Where on Adobe.com do I register my eReader?  I have 2 Barnes & Nobel eReaders; one is the original Nook and the other is Color Nook.  Both are in the list of ADE supported devices.
              • 4. Re: authorizing computer
                Level 4
                You register your ereaders with B&N, not on Adobe.com.  When they are
                registered, B&N will write a small ID file to them, and this file is read
                by ADE.
                • 5. Re: authorizing computer
                  Golferguy08 Level 1
                  Both of my e-Readers were registered with B&N.com in 2010.  Somehow, ADE doesn't recognize my Color Nook (purchased and registed after the original Nook).
