7 Replies Latest reply on Jun 7, 2012 9:25 PM by Steverock58
    Synchronisation in ACR7.1/Bridge CS6
    Steverock58
      I previously raised this issue with CS6 Beta and ACR7.0.  The issue hasn't been fixed, but I have found a work-around.
      The Issue was that when I open a whole batch of images to create their XMP Recipe files, the synchronsiation of the adjusted settings to all selected files was not occurring.  This is still the case with ACR7.1.  When I select multiple files within ACR and start changing sliders, these changes are only applied to the first file which appears in the preview panel.  In previous versions of ACR in CS5, simply selecting multiple files and adjusting settings automatically applied those changes to all files selected (except for Local Adjustments like the Gradient tool).
      Now, I've found that if I select all these files in ACR 7.1 and click on Default, they will all synchronise to default.  Then I can start moving the sliders again and these changes will then synchronise to all files selected.
      Why the change?  Surely if I have multiple files selected and then adjust a slider, I mean to have those changes applied to all the selected files?  Why do I have to change them all to default and then start making changes?
      I edit in particular ways that means that I might be trying to synchronise different groups of files to different settings.  For instance I might be editing the sharpness of all files with a particular camera/lens combo, and then be editing the noise for certain ISO settings/camera combos.  I might be vignetting poarticular shots taken indoors without flash, and then some taken indoors with flash.
      I can't do my editing thios way now, becaue I have to return then to default first, to get ACR to let me synchronise them again.  This is a pain and is making my wedding editing take longer and longer....
      The first tiome I raised this issue, Jeff helpfully referred it as a bug to Adobe.  Hopefully they fix this, or I'll have to go back to CS5 to do my editing.
        • 1. Re: Synchronisation in ACR7.1/Bridge CS6
          b2martin_a Level 2
          Thanks for the input, tha'st the way I work also.  I am converting a large number of images from PV2010 to PV2012 and like to switch between the two to see if the image is improved with PV2012.  I could do this with ACR 7.0 by clicking on 'Image Settings" for PV2010 since the xmp file used that process and clicking on "Custom Settings" to see the PV2012 I was adjusting.  When I switched to ACR 7.1 Release Candidate this did not work - it switched back to PV2010 when I selected "Image Settings", but if I tried to switch back to PV2012 "Custom Settings" was already checked, but the settings were PV2010 settings and identified as custom settings - my PV2012 adjustments were gone.  I reported this, but when ACR 7.1 was released the problem was not corrected.
          I found with ACR 7.1 that if I changed from the "Basic Panel" to any other panel before I selected "Image Settings" for the first time it worked and I could then switch back to the Basic Panel for that image and it worked correctly - just like ACR 7.0.  I don't know if this would help you or not.
          You might consider making your default ASA specific and generating a default for every ASA your camera can select with noise and sharpening already in the default.  If you do this, when you open the RAW file for the first time it will automatically select the correct default based on the ASA for that image.  I do this for my D700 and it saves a lot ot time.  The D700 has 41 ASA values it can select when in Auto ASA.  I have a folder with 41 images (one at each ASA) and I set the default for each image with the sharpening and noise adjustments I want for that ASA and click Done to generate XMP files.  I then select all images in ACR and select each one at a time and click to save a new Default.  You can also make it serial number specific if you have more that one of the same model camera - you just need a set of images with each camera to set defaults for all cameras.
          • 2. Re: Synchronisation in ACR7.1/Bridge CS6
            Steverock58 Level 1
            Thanks for your input on this.  The problems I'm having are related to the Basic Settings Tab too, but no with swapping back and forward between 2010 and 2012.  Maybe they want everyone to move to Lightroom to do their RAW editing, but it worked fine doing in Bridge until this new CS6.  It's a bit frustrating.
            • 3. Re: Synchronisation in ACR7.1/Bridge CS6
              b2martin_a Level 2
              Maybe you should change back to ACR 7.0 unless you need ACR 7.1 for some reason, and maybe it will be corrected for ACR 7.2.  I have changed back to ACR 7.0 and I can make changes to one image and then select all or any images I want and synchronize them without problems while in the Basic Panel.  I think this is just an ACR 7.1 issue.
              • 4. Re: Synchronisation in ACR7.1/Bridge CS6
                AnnShelbourne Level 2
                Perhaps using the Select All and Synchronize button (with selected functions) would solve your problem?
                • 5. Re: Synchronisation in ACR7.1/Bridge CS6
                  Steverock58 Level 1
                  No, it doesn't unfortunately.
                  • 6. Re: Synchronisation in ACR7.1/Bridge CS6
                    This may be OS related because I do not have this problem: the ACR sliders in multiple file mode work exactly as they have always done.
                    I am using Bridge CS 6 / ACR 7.1 on a MacPro running OSX 10.6.8.
                    Try re-setting your Prefs and see if that fixes it.
                    • 7. Re: Synchronisation in ACR7.1/Bridge CS6
                      Steverock58 Level 1
                      I've done that as well.  The problem first appeared in the Beta version.  I uninstalled that and installed the retail version later.  The problem still exists when editing large batches of images.  I'm using Windows 7 setup as follows:
                      Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
                      Operating System: Windows 7 64-bit
                      Version: 6.1 Service Pack 1
                      System architecture: Intel CPU Family:6, Model:7, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
                      Physical processor count: 4
                      Processor speed: 2666 MHz
                      Built-in memory: 8190 MB
                      Free memory: 5301 MB
                      Memory available to Photoshop: 7244 MB
                      Memory used by Photoshop: 70 %
                      Image tile size: 128K
                      Image cache levels: 4
                      OpenGL Drawing: Enabled.
                      OpenGL Drawing Mode: Advanced
                      OpenGL Allow Normal Mode: True.
                      OpenGL Allow Advanced Mode: True.
                      OpenGL Allow Old GPUs: Not Detected.
                      Video Card Vendor: NVIDIA Corporation
                      Video Card Renderer: GeForce GTX 560/PCIe/SSE2
                      Display: 1
                      Display Bounds:=  top: 0, left: 0, bottom: 768, right: 1360
                      Video Card Number: 1
                      Video Card: NVIDIA GeForce GTX 560
                      OpenCL Unavailable
                      Driver Version: 8.17.12.9610
                      Driver Date: 20120229000000.000000-000
                      Video Card Driver: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
                      Video Mode: 1360 x 768 x 4294967296 colors
                      Video Card Caption: NVIDIA GeForce GTX 560
                      Video Card Memory: 1024 MB
                      Video Rect Texture Size: 16384
                      Serial number: 91198969378158921412
                      Application folder: G:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
                      Temporary file path: G:\Users\STEVEV~1\AppData\Local\Temp\
                      Photoshop scratch has async I/O enabled
                      Scratch volume(s):
                        P:\, 298.1G, 210.0G free
                        C:\, 931.5G, 385.2G free
                        B:\, 931.5G, 187.7G free
                      Required Plug-ins folder: G:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
                      Primary Plug-ins folder: G:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
                      Additional Plug-ins folder: not set
                      Installed components:
                         A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                         ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
                         adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
                         AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
                         AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
                         AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
                         AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
                         AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
                         AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
                         AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
                         adobe_caps.dll   Adobe CAPS   6,0,29,0
                         AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
                         ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
                         aif_core.dll   AIF   3.0   62.490293
                         aif_ocl.dll   AIF   3.0   62.490293
                         aif_ogl.dll   AIF   3.0   62.490293
                         amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
                         ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
                         AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
                         AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
                         Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
                         BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
                         boost_date_time.dll   DVA Product   6.0.0
                         boost_signals.dll   DVA Product   6.0.0
                         boost_system.dll   DVA Product   6.0.0
                         boost_threads.dll   DVA Product   6.0.0
                         cg.dll   NVIDIA Cg Runtime   3.0.00007
                         cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                         CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
                         CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
                         data_flow.dll   AIF   3.0   62.490293
                         dvaaudiodevice.dll   DVA Product   6.0.0
                         dvacore.dll   DVA Product   6.0.0
                         dvamarshal.dll   DVA Product   6.0.0
                         dvamediatypes.dll   DVA Product   6.0.0
                         dvaplayer.dll   DVA Product   6.0.0
                         dvatransport.dll   DVA Product   6.0.0
                         dvaunittesting.dll   DVA Product   6.0.0
                         dynamiclink.dll   DVA Product   6.0.0
                         ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
                         FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
                         filter_graph.dll   AIF   3.0   62.490293
                         hydra_filters.dll   AIF   3.0   62.490293
                         icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                         icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                         image_compiler.dll   AIF   3.0   62.490293
                         image_flow.dll   AIF   3.0   62.490293
                         image_runtime.dll   AIF   3.0   62.490293
                         JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
                         libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                         libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
                         LogSession.dll   LogSession   2.1.2.1640
                         mediacoreif.dll   DVA Product   6.0.0
                         MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
                         msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                         msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                         msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                         msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                         msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                         msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                         msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                         msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                         pdfsettings.dll   Adobe PDFSettings   1.04
                         Photoshop.dll   Adobe Photoshop CS6   CS6
                         Plugin.dll   Adobe Photoshop CS6   CS6
                         PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
                         PSArt.dll   Adobe Photoshop CS6   CS6
                         PSViews.dll   Adobe Photoshop CS6   CS6
                         SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
                         ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
                         tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                         tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                         TfFontMgr.dll   FontMgr   9.3.0.113
                         TfKernel.dll   Kernel   9.3.0.113
                         TFKGEOM.dll   Kernel Geom   9.3.0.113
                         TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                         updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
                         WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
                         wu3d.dll   U3D Writer   9.3.0.113
                      Required plug-ins:
                         Accented Edges 13.0
                         Adaptive Wide Angle 13.0
                         ADM 3.11x01
                         Angled Strokes 13.0
                         Average 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Bas Relief 13.0
                         BMP 13.0
                         Camera Raw 7.1
                         Chalk & Charcoal 13.0
                         Charcoal 13.0
                         Chrome 13.0
                         Cineon 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Collada 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Color Halftone 13.0
                         Colored Pencil 13.0
                         CompuServe GIF 13.0
                         Conté Crayon 13.0
                         Craquelure 13.0
                         Crop and Straighten Photos 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Crop and Straighten Photos Filter 13.0
                         Crosshatch 13.0
                         Crystallize 13.0
                         Cutout 13.0
                         Dark Strokes 13.0
                         De-Interlace 13.0
                         Difference Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Diffuse Glow 13.0
                         Displace 13.0
                         Dry Brush 13.0
                         Eazel Acquire 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Embed Watermark 4.0
                         Extrude 13.0
                         FastCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Fibers 13.0
                         Film Grain 13.0
                         Filter Gallery 13.0
                         Fresco 13.0
                         Glass 13.0
                         Glowing Edges 13.0
                         Grain 13.0
                         Graphic Pen 13.0
                         Halftone Pattern 13.0
                         HDRMergeUI 13.0
                         IFF Format 13.0
                         Ink Outlines 13.0
                         JPEG 2000 13.0
                         Lens Blur 13.0
                         Lens Correction 13.0
                         Lens Flare 13.0
                         Liquify 13.0
                         Matlab Operation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Measurement Core 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Mezzotint 13.0
                         MMXCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Mosaic Tiles 13.0
                         Multiprocessor Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Neon Glow 13.0
                         Note Paper 13.0
                         NTSC Colors 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Ocean Ripple 13.0
                         Oil Paint 13.0
                         OpenEXR 13.0
                         Paint Daubs 13.0
                         Palette Knife 13.0
                         Patchwork 13.0
                         Paths to Illustrator 13.0
                         PCX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Photocopy 13.0
                         Photoshop 3D Engine 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Picture Package Filter 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Pinch 13.0
                         Pixar 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Plaster 13.0
                         Plastic Wrap 13.0
                         PNG 13.0
                         Pointillize 13.0
                         Polar Coordinates 13.0
                         Portable Bit Map 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Poster Edges 13.0
                         Radial Blur 13.0
                         Radiance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Read Watermark 4.0
                         Reticulation 13.0
                         Ripple 13.0
                         Rough Pastels 13.0
                         Save for Web 13.0
                         ScriptingSupport 13.0
                         Shear 13.0
                         Smart Blur 13.0
                         Smudge Stick 13.0
                         Solarize 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Spatter 13.0
                         Spherize 13.0
                         Sponge 13.0
                         Sprayed Strokes 13.0
                         Stained Glass 13.0
                         Stamp 13.0
                         Sumi-e 13.0
                         Targa 13.0
                         Texturizer 13.0
                         Tiles 13.0
                         Torn Edges 13.0
                         Twirl 13.0
                         Underpainting 13.0
                         Vanishing Point 13.0
                         Variations 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Water Paper 13.0
                         Watercolor 13.0
                         Wave 13.0
                         WIA Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         Wind 13.0
                         Wireless Bitmap 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                         ZigZag 13.0
                      Optional and third party plug-ins:
                         Color Mechanic Pro 2, 0, 0, 0
                         HDRMergeUI 12.0
                         Topaz Adjust 5 10.0
                         Topaz DeNoise 5 10.0
                      Plug-ins that failed to load: NONE
                      Flash:
                         Mini Bridge
                         Kuler
                      Installed TWAIN devices: NONE
