1. Re: How do I save a PDF as dynamic?
Jaison.Sunny Jun 5, 2012 1:17 AM (in response to mbeck123)Please specify in which event and what code you have used?
2. Re: How do I save a PDF as dynamic?
TundraSteve Jun 5, 2012 3:15 AM (in response to Jaison.Sunny)If you do a save as you'll see the option to save the PDF as dynamic but that shoud not have any affect on a script to the dropdown
3. Re: How do I save a PDF as dynamic?
mbeck123 Jun 5, 2012 9:24 AM (in response to TundraSteve)That is my problem. When I save as there is no option in the drop down menu to save my PDF as dynamic. It only has 3 static options. I've changed the PDF render format to dynamic in the form properties default tab and now i'm trying to figure out why I can't save the pdf as dynamic.
4. Re: How do I save a PDF as dynamic?
AlHolden Oct 19, 2012 1:59 PM (in response to TundraSteve)Same issue here: LiveCycle Designer ES2 (9.0.0.2...)
There are tons of Adobe help pages and documentation which say to save your file as a "dynamic PDF".
But no such option exists when I try to save. I only see:
"Adobe Static PDF Form"
"Adobe Dynamic XML Form"
"Adobe XML Form"
"Adobe LiveCycle Designer Template"
What conditons exist - or setting is required - for this "Dynamic PDF" option to appear? I would think that it was merely a case of casual transposition of terms - or some other typo - but this specific term "Dynamic PDF" seems to be very popular on the web; so it must exist (or have existed) somewhere in Adobeland at some point!
5. Re: How do I save a PDF as dynamic?
Greig at Lands May 15, 2013 10:18 PM (in response to AlHolden)Hi,
I just had this exact same problem. I went into File > Form Properties > Defaults and changed the Target Version at the top of defaults to a later version. In my case I changed it from Acrobat and Adobe Reader 6.0.2 or later to Acrobat and Adobe Reader 9 or later and then went to Save As to find the dynamic option was now available.
Hope this helps,
Greig
