3 Replies Latest reply on Jun 4, 2012 11:04 PM by Chris Cox
    Photoshop CS6 freezing on Mac OS 10.6.8
    JosephatKudos
      Hi one of our Macs (OS 10.6.8) is freezing when we try using Marquee Selection or Feathering or Cut and Pasting in a PSD file using Photoshop CS6. Basically we have to hard reboot the Mac as we get no error message, just a locked up computer. All the other Macs are exactly the same but don't have this issue.
      The file has no fonts in it, it is just an image with Layers that have no Effects. File size is 900MB.
      All updates for both CS6 and Mac OS have been run and all is up to date.
      Please advise.
        • 1. Re: Photoshop CS6 freezing on Mac OS 10.6.8
          gator soup Level 4
          it would probably help to note which Mac you have, ram, video card, additional plugins, font situation, system haxies, drawing tablets, working off network disks, ect...
          if you ran Disk Utility> Repair Disk, Repair Permissions, and a maintenance utility like Cocktail OSX to clear out the caches (especially fonts)
          after that, try a New User account to rule out user preferences
          that may be a clue to someone else but it sounds like you have some work to do ruling out hardware if the above doesn't help (and the install is otherwise ruled out)
          • 2. Re: Photoshop CS6 freezing on Mac OS 10.6.8
            JosephatKudos Level 1
            Here are the base specs (serial info deleted). We're running the file off the hard drive and there are no additonal plugins. We use a standard font library but as I said, file has no text/fonts in it. It's completely locking up while using the marquee selection tool.
            Cleared user preferences too when starting PS.
            Gonna try a fresh reinstall and see if that fixes it, if it doesn't I think there is something wrong with the Mac itself because we have 6 more identical machines and they are not having this issue.
            Hardware Overview:
              Model Name:          iMac
              Model Identifier:          iMac11,3
              Processor Name:          Intel Core i7
              Processor Speed:          2.93 GHz
              Number Of Processors:          1
              Total Number Of Cores:          4
              L2 Cache (per core):          256 KB
              L3 Cache:          8 MB
              Memory:          8 GB
              Processor Interconnect Speed:          4.8 GT/s
              Boot ROM Version:          IM112.0057.B00
              SMC Version (system):          1.59f2
            Graphics/Displays:
            ATI Radeon HD 5750:
              Chipset Model:          ATI Radeon HD 5750
              Type:          GPU
              Bus:          PCIe
              PCIe Lane Width:          x16
              VRAM (Total):          1024 MB
              Vendor:          ATI (0x1002)
              Device ID:          0x68a1
              Revision ID:          0x0000
              ROM Revision:          113-B9710C-238
              EFI Driver Version:          01.00.417
              Displays:
            iMac:
              Resolution:          2560 x 1440
              Pixel Depth:          32-Bit Color (ARGB8888)
              Main Display:          Yes
              Mirror:          Off
              Online:          Yes
              Built-In:          Yes
              Connection Type:          DisplayPort
            Serial-ATA:
            Intel 5 Series Chipset:
              Vendor:          Intel
              Product:          5 Series Chipset
              Link Speed:          3 Gigabit
              Negotiated Link Speed:          3 Gigabit
              Description:          AHCI Version 1.30 Supported
            WDC WD1001FALS-40Y6A0:
              Capacity:          1 TB (1,000,204,886,016 bytes)
              Revision:          05.01D06
              Native Command Queuing:          Yes
              Queue Depth:          32
              Removable Media:          No
              Detachable Drive:          No
              BSD Name:          disk0
              Rotational Rate:          7200
              Medium Type:          Rotational
              Partition Map Type:          GPT (GUID Partition Table)
              S.M.A.R.T. status:          Verified
              Volumes:
              Capacity:          209.7 MB (209,715,200 bytes)
              Writable:          Yes
              BSD Name:          disk0s1
            Macintosh HD:
              Capacity:          999.86 GB (999,860,912,128 bytes)
              Available:          684.48 GB (684,475,437,056 bytes)
              Writable:          Yes
              File System:          Journaled HFS+
              BSD Name:          disk0s2
              Mount Point:          /
            • 3. Re: Photoshop CS6 freezing on Mac OS 10.6.8
              Level 7
              If the whole machine locks up, you have 3 possibilities: bug in the OS, bug in a low level driver, or defective hardware.
              Bad RAM, bad VRAM, and bad GPUs are the most common causes.
