13 Replies Latest reply on Sep 10, 2006 9:37 PM by namon96
    odd error message...
    r_tist Level 1
      Have you ever heard of this? What can I do to gain access as I need to modify the page(es)?
      "Making this change would require changing code that is locked by a template or a translator. The change will be discarded."
      Please advise, I'd appreciate your advice...perhaps there's another .asp page contained within this site that controls all the pages so the change I make will reflect on all pages contained within the site??
      THANKS!
        • 1. Re: odd error message...
          Level 7
          It sounds like a template has been applied to that page... you should be
          able to see template tags in your code if there is. Not sure what a
          translator is... sorry.
          Andrew
          "r_tist" <webforumsuser@macromedia.com> wrote in message
          news:ectu1f$6bh$1@forums.macromedia.com...
          > modify
          > the page(es)?
          > template
          > page
          > make
          > THANKS!
          • 2. Re: odd error message...
            Level 7
            What is it you are trying to change?
            Does your child page validate?
            Murray --- ICQ 71997575
            Adobe Community Expert
            (If you *MUST* email me, don't LAUGH when you do so!)
            http://www.dreamweavermx-templates.com - Template Triage!
            http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
            http://www.dwfaq.com - DW FAQs, Tutorials & Resources
            http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
            > modify
            > the page(es)?
            > template
            > page
            > make
            > THANKS!
            • 3. Re: odd error message...
              r_tist Level 1
              I should mention that this site was designed with frames...is that what you mean when you say "parent & child"?
              I am simply looking to add anoher button link for a new web page to the homepage...but obviously, this update needs to be on every page. S o perhaps there's another key page with just this interface design, which would then update all the pages of the site if I make the change here?? --what d' you think?
              I appreciate your help!
              • 4. Re: odd error message...
                r_tist Level 1
                Any advice? I researched the net & a lot of people have complained about this DW issue. I'm not sure what the fix might be, if any!
                Please help...thanks!
                • 5. Re: odd error message...
                  Level 7
                  > Any advice?
                  please give a link to the page.
                  If you give a link to a frameset- say which FRAME in it is giving the error.
                  • 6. Re: odd error message...
                    r_tist Level 1
                    Here's the link: www.beekley.com
                    I am simply trying to modify the left hand button panel...trying to add another button in there.
                    But, I get that error message so I do not want to play about with it until I understand why it won't allow me to make changes.
                    Thank you!
                    • 7. Re: odd error message...
                      r_tist Level 1
                      Please help...something to do with templates or template control?
                      THANKS!
                      • 8. Re: odd error message...
                        Level 7
                        I see no templates used anywhere.
                        Are you using templates, then "exporting without markup"?
                        If yes, please upload a copy of a page that does give this error message,
                        with the template comments intact.
                        A random guess is the commented out <td>
                        • 9. Re: odd error message...
                          namon96
                          I've got a similar problem.
                          Templates worked fine until this morning when I got
                          "Making this change would require changing code that is locked by a template or a translator"
                          I couldn't add anything to my child pages, however I tracked it down to an #include on the template page which has been working OK for weeks
                          As soon as I remove the include all worked fine
                          I replaced the include file with a simple html file with no tags, just the word Hi
                          Again when I go back to my child pages, nothing works
                          Take out the simple include from the template file and all is OK again
                          Any ideas on this bug
                          • 10. Re: odd error message...
                            Level 7
                            > word Hi
                            does the included file contain JUST Hi
                            or is it a complete html document, with Hi in the body section?
                            restating- does the included file contain it's own <html><head> and <body>
                            tags? It shouldn't, it should contain only the html tags that are correct
                            syntax for where it is included into other files.
                            • 11. Re: odd error message...
                              namon96 Level 1
                              no head - no body tags - no tags at all, just the word Hi
                              The strange thing is all my includes up until this morning were working fine, including those that served up database records. I went to work on one of the child pages and got the error message and after looking at some of the posts here, tracked it down to the include files.
                              I remove all include files from the Template and all is OK
                              I put a simple footer include with no html just the word Hi and page goes faulty again
                              • 12. Re: odd error message...
                                Level 7
                                > faulty again
                                Can you post a link to the page so Dr. Murray can have a look at it?
                                Ideally 1 to template and a second link to the misbehaving child?
                                Bonnie
                                in California
                                8 ^ )
                                • 13. Re: odd error message...
                                  namon96 Level 1
                                  Strange, the problem appeared out of the blue one day and disappeared the next day and hasn't come back since!
