9 Replies Latest reply on Jun 8, 2012 12:50 PM by WacoPhotog
    Indesign not installing correctly
    WacoPhotog
      Hi, I need help with installing my Indesign CS5.5. I have Photoshop CS5 and Lightroom v3.3 installed already. The machine runs Windows 7 x64 with 8GB RAM on a Core i5 CPU.
      I tried rebooting and running as administrator to no avail. There is no antivirus installed that could block anything from installing.
      Here is the log:
      Exit Code: 6
      -------------------------------------- Summary --------------------------------------
      - 2 fatal error(s), 13 error(s), 13 warning(s)
      WARNING: DS013: Payload {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB 3.0.0.0 is already installed and the session payload {45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB 3.1.0.0 has no upgrade/conflict relationship with it.
      WARNING: DS013: Payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK 3.0.0.0 is already installed and the session payload {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK 3.1.0.0 has no upgrade/conflict relationship with it.
      WARNING: DS013: Payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp 1.0.0.0 is already installed and the session payload {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0 has no upgrade/conflict relationship with it.
      WARNING: DS013: Payload {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule 3.0.0.0 is already installed and the session payload {AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule 3.1.0.0 has no upgrade/conflict relationship with it.
      ERROR: DS013: Verifying payload integrity : Failed with code 1
      WARNING: DW031: Payload:{2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 3.0.0.0 has been updated and has been selected for repair. The patch {42774483-D33C-46F7-8B20-FD0B1A3DAC25} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 will be uninstalled now.
      WARNING: DW031: Payload:{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 has been updated and has been selected for repair. The patch {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 will be uninstalled now.
      WARNING: DW031: Payload:{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 has been updated and has been selected for repair. The patch {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All 6.3.0.0 will be uninstalled now.
      ----------- Payload: {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0 -----------
      WARNING: DF054: Unable to read Adobe file version for file path 'C:\Program Files (x86)\Adobe\Adobe Extension Manager CS5.5\AdobeOwlCanvas.dll'(Seq 28)
      ERROR: Error code: 1(Seq 28)
      ----------- Payload: {32C78855-194D-4E66-9EB5-D6DC1C418D79} Adobe Hunspell Linguistics Plugin CS5.5 1.0.0.0 -----------
      WARNING: DF054: Unable to read Adobe file version for file path 'C:\Program Files (x86)\Common Files\Adobe\Linguistics\5.5\Providers\Plugins2\AdobeHunspellPlugin\\AdobeHunspellPlugin.d ll'(Seq 2)
      ERROR: Error code: 1(Seq 2)
      ----------- Payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation 1.0.0.0 -----------
      ERROR: DF040: Failed to add Font 'C:\Windows\Fonts\ChaparralPro-BoldIt.otf'. Error: 2(Seq 21)
      ERROR: DW063: Command ARKFontCommand failed.(Seq 21)
      ----------- Payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation 1.0.0.0 -----------
      ERROR: DF040: Failed to add Font 'C:\Windows\Fonts\AdobeMingStd-Light.otf'. Error: 2(Seq 10)
      ERROR: DW063: Command ARKFontCommand failed.(Seq 10)
      ----------- Payload: {4883A813-2805-4FA8-A91C-073BA7B2667A} Adobe Linguistics CS5.5 5.5.0.0 -----------
      FATAL: DS003: Cannot extract 'C:\Download\InDesign5_5\Adobe InDesign CS5.5\Adobe InDesign CS5.5\payloads\AdobeLinguistics_3_5_All\Assets2_1.zip' to 'C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{4883A813-2805-4FA8-A91C-073BA7B2667A}'. Error: Error 183 Cannot create a file when that file already exists.
      ----------- Payload: {EE85C227-0148-4825-B659-6A1E142571EE} Adobe Bridge CS5.1 4.1.0.0 -----------
      FATAL: DS003: Cannot extract 'C:\Download\InDesign5_5\Adobe InDesign CS5.5\Adobe InDesign CS5.5\payloads\AdobeBridge4.1-mul\Assets1_1.zip' to 'C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{EE85C227-0148-4825-B659-6A1E142571EE}'. Error: Error 0
      ----------- Payload: {857CC5F0-040E-1016-A173-D55ADD80C260} Adobe InDesign CS5.5 Application Base Files 7.5.0.0 -----------
      WARNING: DF054: Unable to read Adobe file version for file path 'C:\Program Files (x86)\Adobe\Adobe InDesign CS5.5\AGM.dll'(Seq 43)
      ERROR: Error code: 1(Seq 43)
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050:  - Adobe Linguistics CS5.5: Install failed
      ERROR: DW050:  - Required Common Fonts Installation: Install failed
      ERROR: DW050:  - Recommended Common Fonts Installation: Install failed
      ERROR: DW050:  - Adobe Bridge CS5.1: Install failed
        • 1. Re: Indesign not installing correctly
          Just a guess, but is your InDesign installer an upgrade version?
          • 2. Re: Indesign not installing correctly
            WacoPhotog Level 1
            Yes, it is an upgrade.. Strangely enough, it did not ask me for my previous serial number during installation.
            Any ideas for a solution?
            • 3. Re: Indesign not installing correctly
              Doesn't look like if found a qualifying product. Is the prefious edition installed? Are you sure you bought the right upgrade product? Suites can only upgrade to suites, point products can updat to the same point product or to a suite, but you need to purchase the correct one.
              You may want to run the cleaner tool to be sure there's no detritus left from the failed attempt, then try again: CS Cleaner Tool for installation problems | CCM, CS6, CS5.5, CS5, CS4, CS3
              • 4. Re: Indesign not installing correctly
                WacoPhotog Level 1
                I am trying to install it on my laptop. I have the same configuration on my PC, but it didn't give me any issues there. The only thing that I can think of is that at one point I had a trial of version 5 installed on my laptop, but I uninstalled that after the trial ran out and I got my 5.5 upgrade (I have CS4 already, just not installed on my laptop. I guess I can uninstall all my adobe products, run the cleanup and start with InDesign first, then Photoshop and then Lightroom (which seems to be the least sensitive).
                • 5. Re: Indesign not installing correctly
                  WacoPhotog Level 1
                  Ok, so I removed all Adobe products, ran the cleanup tool, rebooted and fist installed my CS4, which went fine, then ran the upgrade to CS5.5.... Still errors, but less:
                  Exit Code: 6
                  - 2 fatal error(s), 9 error(s), 1 warning(s)
                  ----------- Payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 2.0.0.0 -----------
                  WARNING: DF029: ARKServiceControl::StartService: Service not started/stopped SwitchBoard. Current State: 0 Exit Code: 0 Service Specific Exit Code: 0(Seq 1)
                  • 6. Re: Indesign not installing correctly
                    It's the same 2 fatal errors, though. Not sure what to tell you. The first error is saying the linguistics package is already extracted and can't be overwritten, the second is an error trying to install Bridge, and I don't know what error code 0 means. This is the sort of thing that up until May would have been eligible for free installation support from Adobe, but I'm not sure about now.
                    • 7. Re: Indesign not installing correctly
                      Manish-Sharma Employee Moderator
                      We would like to know you are installing the software from the DVD or its a downloaded version ?
                      Secondly , When you go to 'C:\Windows\Fonts\" folder , do you have AdobeMingStd-Light.otf and ChaparralPro-BoldIt.otf file or folder present.?
                      • 8. Re: Indesign not installing correctly
                        WacoPhotog Level 1
                        I removed the two fonts and cleaned the AdobeTemp folder but no go.. still errors out. It is a download version.
                        • 9. Re: Indesign not installing correctly
                          WacoPhotog Level 1
                          I copied the installation files from my original download folder on my PC again to my laptop and tried the install again. It seems that the installation folder on the laptop had gotten corrupted. I was able to install after I copied the files again.
                          Thanks for the help!
